    Mine cart -- correct?
    21 Posts 7 Posters 3.2k Views 7 Watching
      agamemnus
      I made a mine cart for an little graphic I wanted to make. It's not fancy or textured (as yet?). I'm somewhat concerned/interested in whether it's actually physically correctly done or whether it'll just fall apart/break/etc...
      I did leave out some details that I know should be there -- I'm thinking the axle should probably have wedges (like a screw) in order for the lug nuts and wheels to be replaced in and out.
      I'm especially concerned about the bottom part of it. I saw some other models and they seemed to have too few beams/support, but I dunno.
      I suppose it needs some handles, but I'm not entirely sure as to where to put them.
      Possibly the wheels are a bit too small in relation to the rest of it.
      Here it is:
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      • hellnbakH Offline
        hellnbak
        I doubt there are any mine cart experts here, how much research have you done online for info?
        • tademaT Offline
          tadema
          Quite a few images here http://www.flickr.com/search/?q=mine+cart&f=hp
          John
          • hellnbakH Offline
            hellnbak
            John
            Wow, some of those are kinda cool. I might model some of the old weathered ones just for kicks
              agamemnus
              You never know. ๐Ÿ˜„
              Thanks for the link.
              • unigamiU Offline
                unigami
                John
                More proof that if you search for any object in Flickr, you will find at least one version made in Legos!
                • hellnbakH Offline
                  hellnbak
                  And if you use Bulk Image Downloader, you can automatically download as many of those images as you want. If I set it to download 10 pages of the thumbnails, it downloads them all as full size images, which I can sort thru at my leisure. Really useful for all the reference photos I use.
                    Here are some from my country.
                    • numbthumbN Offline
                      numbthumb
                      @agamemnus said:
                      Bonus: Also, perhaps a large sliding door on either the front-bottom or back-bottom of the minecart (where the "plate" is?), enabling the balls to roll out? โ“ ๐Ÿ’š
                      Unfortunately, I canยดt help you with Sketchy Physics. But I think that the (standard) minecart features a hinged design that allows its base to rock back and forth, so it can be dumped to either side.
                      Something like this:30-cu.ft.Minecar.jpg
                      So much for the sliding door ๐Ÿ˜„
                      Comfortably numb...
                        agamemnus
                        I see.
                        I'll assume that it would have to be set on either side, otherwise tons of stuff will be left behind if the mechanism is in the middle.
                        The mechanism in the illustration seems very complex geometrically. Would help to see a better view...
                        It would have to be something more complex than your typical bucket hinge; there would be great pressure with just one little welded tube at the point of contact (at both sides) and we can assume that these mine carts weigh a lot when full.
                        I guess I would need to do quite a bit of remodeling now to add that or something similar. ๐Ÿ˜
                          numbthumb
                          Sorry, I donยดt have a better drawing. But there are lots of images in those links Gaieus and others have posted - it doesnยดt look that complicated to me.
                          Some more images here:
                          http://www.railroadmichigan.com/miningequipment.html
                          Keep up the good work!
                          Comfortably numb...
                          • hellnbakH Offline
                            hellnbak
                            If you don't want to make a model that complex, there are several variations shown in the site that numbthumb referenced that look to be a lot simpler as far as the dumping function.
                              agamemnus
                              It's all visual gibberish to me. ๐Ÿ˜•
                              I found something relatively clean --
                              http://www.railroadmichigan.com/miningdelaware01.jpg
                              It looks like it is just a simple hinge, but again it is hard to tell. It might be a hinge with some sort of spike (like: "|__" ) controlled by a slight push in the right way + gravity + a hard break metal thingy to keep it from hitting the wheels? I dunno!
                                numbthumb
                                I donยดt know. If it helps, here are some more pics: http://www.wildcatmines.com/photos.html
                                If you are really determined to reconstruct it to the last detail, youยดll have to visit the nearest museum ๐Ÿ˜„
                                Comfortably numb...
                                  agamemnus
                                  I guess there are a lot of different types.
                                  I'll give it a whirl and try to come up with something from my eemageenashun.
                                    agamemnus
                                    And the frame below the cart is still conveniently hidden from view! Anyway, I guess what I have will do.
                                    I'm now trying to add some Sketchy Physics, but, ugh.
                                    I added a part of a conveyor belt with some balls. (attached to this post) I would like the conveyor belt to move (the rollers are hidden inside!), depositing the balls into the mine cart. Can anyone help?
                                    mine cart and conveyor scene.skp
                                    • hellnbakH Offline
                                      hellnbak
                                      Looking good. I assume there is going to be a release mechanism and handles of some sort?
                                      • hellnbakH Offline
                                        hellnbak
                                        Also, the side of the cart would need some sort of reinforcement where it strikes the frame or it would get deformed pretty quickly. Just an observation
                                          agamemnus
                                          I do have a sort of handle on the side of each hinge. Perhaps this mine cart is fairly big and handles on top of each side would be too high to reach? ๐Ÿ˜„
                                          Edit: no lock/release mechanism; that's an issue, I guess. Not really sure how I would add it. ๐Ÿ˜
                                          As for the cushions: Sure, makes sense. I added cushions to the model above.
                                            agamemnus
                                            Here it is with a hinge and rounded bottom. It swivels to slightly more than 90 degrees before touching the wheel axle supports. The hinge is actually friction-less with the addition of permanent + magnets welded on both part of the hinge covering and the hinge itself. ๐Ÿ˜„
                                            mine cart and conveyor scene 2.skp
