    Ai dwg to SU
    3 Posts 2 Posters 363 Views 2 Watching
      suSteve
      If I create a circle in Ai and export as dwg and then import into SU it has 33 edges. Can I import it as (or easily make it into) a single edge ?
      also what are coplanar faces ?
      thank you
      • cottyC
        cotty
        Plugin weld.rb should help.
        That are faces in one plane (normals are parallel).
        my SketchUp gallery
          suSteve
          thank you cotty. weld works really well and I need to read up more on coplanar (and everything else).
          thanks again
