    Check out this extremely talented modeler
    67 Posts 19 Posters 12.5k Views 19 Watching
    • boofredlayB Offline
      boofredlay
      Welcome Jim. Glad you decided to join us.
      • hellnbakH Offline
        hellnbak
        Something that impressed me about your models is the smoothness and fluidity of your wires, pipes, fuel lines, and hoses. I'm assuming you shaped a line and then used follow-me to get the shapes, but I have always had a problem getting them to accurately represent what I want. How do you go about the process, how do you get them to accurately start at point A and end at point B and look like a real wire/hose/whatever would in that situation? It's so difficult (for me) to shape a line in 3d space. I'm probably not explaining myself very well, I seldom do, but I hope you get the gist of what I'm asking.
          boofredlay
          hellnbak, I cannot speak for Jim but I create my wires with the F-spline tool. I did a tutorial about it in CatchUp #3 found here: http://sketchucation.com/catchup/
          • hellnbakH Offline
            hellnbak
            I remember reading about that, and at the time I couldn't understand what was so different from just using the follow-me tool. Now that I've looked at it again I can see where it's a lot different. Gonna give it a try tonite. Thanks! 👍
            • JMJOhioJ Offline
              JMJOhio
              I was in the process of creating cables for the trunk mounted battery in my 32 Ford when you posted this question. Had one finished and ready to start the other. So I saved some screen captures as I created the second one.
              There are two threads in this discussion. The first one is subjective and pertains to the real life behavior of the items you are modeling. I rely on intuition and reference photos while creating a path for the entity. I use the same methods for modeling wires, pipes, lines and hoses but think differently as I develop the paths for the varied materials. Exhaust pipes, fuel lines, brake line and etc. are rigid and retain their mechanically formed or fabricated shape. Hose is semi-rigid to flexible, depending upon type of material and diameter. It is fairly predictable, but you must be conscious of minimum bend radii and sag in between supports. Wire is the most unpredictable and difficult to path for. Heavy gauge, stiff wire behaves like semi-rigid hose, but will have small random kinks in it. Softer, lighter gauge wire starts behaving like a wet noodle.
              The second discussion thread is objective and relates to construction methods and tools used or not used. Eric's CatchUp tutorial is very good guidance. I use a network of lines and planes for my guide construction and then finish the path with tangent arcs instead of splines. The wording of your question leads me to believe that you are not using splines or arcs, just line segments. If that's the case, I understand your difficulty with the 3d construction and lack of predictable results. The splines and the way I construct my arcs creates tangents at each intersection and a resultant smooth flow. My network of lines and planes allow me to maintain control as I bridge 3d space between A and B. Try both methods and see which works best for you. I have not tried "pipe along path", but will take a look at it.
              Start and finish lines perpendicular to A & B
              Network of lines and planes -- Takes me multiple attempts to get this where I want it.
              Arcs added
              Test extrusion -- I like it
              Delete construction geometry, soften edges & add material textures
              Trunk progress
              Plumbing, wiring & piping
              Brake lines, fuel lines, clutch cyl hydraulic lines & etc.
              • ely862meE Offline
                ely862me
                Bravoo!!
                Elisei (sketchupper)
                Come and See EliseiDesign
                • urgenU Offline
                  urgen
                  ....I think there is no objection? 😉
                  http://forums.sketchucation.com/viewtopic.php?f=81&t=33509&p=365243#p365243
                  --pupil forever...------
                  • hellnbakH Offline
                    hellnbak
                    I really appreciate the tips, I think I'll be able to make wires that no longer look like a snake run over by an 18-wheeler. That's one of the fun things about SU, you can always learn better ways of doing things.
                    BTW, your Highboy is looking great! Can't wait to download it (and then delete it out of frustration and jealousy 😆 )
                    My only objection is that you beat me to it! Gonna add a few more photos to the thread tho.
                    • jgbJ Offline
                      jgb
                      I do wires with Pipe-along-path RUBY. Much like JMJ, I start with straight line segments to rough in the route, then apply 6 segment arcs to round the bends. That is the time consuming part, to get them right. When it looks right I PAP using zero inside diam and usually 8 or 12 sides, depending on the detail I want. Wire rope is always 6 sides. Then I smooth/soften all inside segment joins. If I want a more realist look I break the long runs in random places with full circles, and tweak them out of alignment to give the wire a bit of a wavy look.
                      When I get a chance in the next week or so, I will post some images of my Silver Dart project in the Most Impressive thread. It is far from complete, but the engine and landing gear are complete. It's fairly detailed, but not nearly as much as JMJ's engine. I can just imagine the hours it took him to do the timing chain to that level of detail. It took me days to get my chain drive to look only almost good.
                      jgb
                      • hellnbakH Offline
                        hellnbak
                        While JMJ hasn't finished his fantastic '32 Highboy and thus hasn't uploaded it to the Warehouse yet, he's getting close and meanwhile he has posted some photos of it's progress on the warehouse. Here are some of them. (Keep in mind, these are copies of the photos, so they have lost some detail and do not do his work justice)
                        Part of his description -- "Here is the current state of my 32 highboy. Will be adding the following; Windshield wiper arm and blade, clamps on lower radiator hose, front turn signal lamps, seatbelts, interior dome light, rear view mirror, voltage regulator and additional engine wiring."
                        He describes the photo below as "Created this pencil render with shaded highlight in PhotoScape.
                          turbobrad
                          The Highboy model is wonderful. It's nice to see JMJ has joined the forum!
                          BradE
                          Dean3Design
                          • urgenU Offline
                            urgen
                            ....JMJOhio,Thanks once again! 👍
                            ...some edit model for render...fast Hypershot+photosnop....
                            http://funportal.info/smiles/smile288.gif
                            • hellnbakH Offline
                              hellnbak
                              Wow, that looks like it's sitting on a shelf at Batteries-R-Us! Looks great! 👍
                              dang, I wish I could render
                              • mitcorbM Offline
                                mitcorb
                                Me, too. But then, I wish I could model faster and better than I do.
                                  turbobrad
                                  [attachment=0:1m09mo8a]<!-- ia0 -->accu.jpg<!-- ia0 -->[/attachment:1m09mo8a]
                                  Great render urgen.
                                  BradE
                                  Dean3Design
                                  • jgbJ Offline
                                    jgb
                                    I clicked on the "photo" and my Laptop said "Charging!" 😲
                                    jgb
                                    • hellnbakH Offline
                                      hellnbak
                                      • JMJOhioJ Offline
                                        JMJOhio
                                        [attachment=0:3cgd8z0y]<!-- ia0 -->accu.jpg<!-- ia0 -->[/attachment:3cgd8z0y]
                                        Thank you urgen. Great rendering. Can you offer any suggestions/recommendations relative to the model creation process that would reduce the render efforts, (preparation, render specific set-up and post editing) and still offer the best final image. A very broad question and looking for simple answers. Structure, organization, applied materials, imported images, etc...
                                        • urgenU Offline
                                          urgen
                                          @jmjohio said:
                                          ... Can you offer any suggestions/recommendations relative to the model creation process that would reduce the render efforts, (preparation, render specific set-up and post editing) and still offer the best final image. A very broad question and looking for simple answers. Structure, organization, applied materials, imported images, etc...
                                          …JMJOhio, very general indeed… 😒
                                          ....I do not use rendering in my full-time job and, therefore, cannot consult you professionally.. 😒 . Just for fun, I use HYPERSHOT or KEYSHOT… I think you should try to define a goal of the rendered image… Does a particular scenario take place? (Is it a coherent scene?) Or is it just an engineer type of render? May be it is a render for a magazine (like the battery project that I presented above)? 😕
                                          Depending upon the goal of your image, the render program should be adjusted accordingly. HYPERSHOT (KEYSHOT) gives one of the best quality results and is also one of the easiest programs to navigate, but its usage is limited to the rendered object....It was thought to be ultimately easy to use and at the same time produce good quality, just like the most basic camera «Say Cheese» and there you go, photos are ready! 😉
                                          It is suitable for the preparation of some detailed images with a general view, which can be used for advertisement projects or in the area of engineering.In case you are after interior design or scene (with a particular coherence), there are many options out there. VRAY, THEA (very popular in this forum) MAXWELL, and so on… There is always a choice, but I am not sure what level you’re after… I have to warn you, it is very time-consuming and demanding in terms of experience…
                                          @jmjohio said:
                                          ...The monkey can paint a masterpiece if given enough time and bananas. 😆
                                          .... the monkey has to spend hell lot of time... 😉 and eat far more bananas! 😄
                                          ....Best of luck to you! 👍
                                          ..In case you need help with HYPERSHOT (KEYSHOT) or PHOTOSHOP, do not hesitate to ask me and I will answer whenever I have free time.
                                          • andybotA Offline
                                            andybot
                                            Wow Jim. All I can say is wow. That is some really wonderful modeling.
                                            • 3 / 4
