    Plugin to create all possible lines between points
    6 Posts 3 Posters 636 Views 3 Watching
    • liquid98L
      liquid98
      My first question:
      I have a set of construction points, which coordinates I want to catch in an Array.
      How do I do that?
      Second question:
      I want to draw al the possible lines to connect all the cpoints in that Array.
      I think I have to use line = entities.add_line point1,point2
      But how do I iterate through the couples in the array?
      Examplearray = [A, B, C]
      Gives me these three couples / lines:
      AB
      AC
      BC
      And of course BA CA and CB but these are duplicate lines..
      But how to automate this process??
      Thanxs for your input!
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • fredo6F
        @liquid98 said:
        My first question:
        How do I do that?
        Second question:
        AB
        AC
        BC
        1. For the first question, you have to tell how is the "set of construction point", i.e., is it a list of Point3d? if so, you get the [x, y, z] of a Point3d <pt> with pt.to_a
        2. For the multi-connection, use that code
        def messy_connect_points(entities, list_points)
           n = list_points.length - 1
           for i in 0..n
               pti = list_points[i]
               for j in i+1..n
                   entities.add_line pti, list_points[j]
        • sdmitchS
          sdmitch
          if the construction points are in the model
          mod = Sketchup.active_model
          ent = mod.entities
          sel = mod.selection
          pts=[];#initialize the points array
          #find all the construction points
          ent.each{|p| pts.push p.position if p.is_a?(Sketchup;;ConstructionPoint)}
          #draw all possible lines
          for i in 0...pts.length-1
            for j in 1...pts.length
              ent.add_line(pts[i],pts[j])
          http://sdmitch.blogspot.com/
          • liquid98L
            liquid98
            Hi Sam and Fredo,
            Thnx for your help! Exactly what I was after..
            @Sam
            why the ; ??
            Thnx
            • sdmitchS
              sdmitch
              force of habit. the ; just seperates multiple statements on a single line. In this case the # is used to comment the remainder of the line.
              • liquid98L
                liquid98
                Sam,
                Well, I'm supposed to know the use of the ; but i forgot..
                Again thanx for your help. The Math part was easier than the constructionpointarraycreation. πŸ˜„
