    [Plugin] QuadFaceTools
    680 Posts 116 Posters 745.0k Views 116 Watching
    • McGyverM
      McGyver
      This seems to be a very cool and powerful tool...
      I can't seem to use the UV mapping tool on anything but a Sandbox mesh though... Is this only meant to be used with a mesh made using sandbox? How was the model in the demo video in the original post or that Viking boat made (outside SketchUp or using Artisan)? I tried mapping a sphere with the ends cut off , but it wont work... it appears to be made of quads... are they not the right kind of quads? The Video makes it look very simple, but it just does not seem to want to work on anything other than a sandbox mesh...
      Following instructions in video, this is the best rest I can get.
      Visit My ShareCG Freebie Gallery
        Are you using SketchUp 6? (your profile indicate so - is is up to date?) I know it says it works for 6, but there might be some stuff I've added lately that breaks that.
        Do you see anything in the Ruby Console?
          hmmm... your screenshot seem to indicate you are on 8... due to the coloured overlay....
          Can you by any chance made a small video of what you do?
          • McGyverM
            McGyver
            You are correct, I am using SU8 now, I had forgotten to update the profile data, sorry.
            I don't really know how to make a video demo (or even if mac really has anything like that)... but I could explain.
            1- using the "spheretool" (by Jim Foltz), I create a sphere... in this case about 12' diameter with 24 segments...
            2-I then exploded it.
            3-I made a small 4 sided plane and applied (to it) the material I'd like to use on the sphere. I did this to be sure the material was definitely being "used" and SU knew it was there... in pervious tries I just loaded the material and selected it without it being used in anything else and it did not work... when looking at the video (the first video) I noticed one of the models in the background may have had the material being used, applied to it, so I figured it probably won't hurt and might be required for it to work right...
            4-Since this was an experiment to see how to use the plugin I saved the file at this point so I would not have to repeat the whole process if SU crashed (which it did several times while doing this) or if the attempt fails.
            5-I select the material
            6-I choose the "UV map selected quads" tool (it now tells me to "Pick a vertex for origin or an edge for U direction") and I then click on the model when the little orange square shows up on it (originally I was trying for a specific area I wanted it be at, but at this point I'm not fussy, I just want it to work)... I usually choose an area around the equator on or near one of the axis lines (it does not seem to matter where since the results are always more or less the same).
            7-The tool shows a green line on the surface of the model and tells me to "pick an edge for V direction"... I do so.
            8-It then does the red and green lines on the surface of the model and nothing else... From the video I assume the material should mapped onto the surface and now all I have to do is scale it using the green and red "handles"... I notice in the video the tool now tells you to "set U and V mapping scale"... I get no such message.
            I have tried many different things between steps 4 and 5... I have tried converting the quads, triangulating them, I have tried triangulating and untriangulating them, smoothing and unsmoothing the quad edges, unsmoothing and smoothing the quad edges... Tried for about two hours to get results... since the whole process from start to failure takes only like 20 seconds or less, I've made quite a few attempts and different variations on attempts.
            I'm using a 2 GHz Intel Core 2 Duo Mac running OS 10.5.8 and this is being done in the latest version of SU8 (free)...
            While experimenting, SU crashes about 4 out of 10 tries... each "try" being opening up the file, failing to get the result and closing the file without saving and re-opening it. At some point during or just after the process there is a crash.
            I just want you to know (thomthom) that I appreciate this plugin and I'm not complaining... I assume it is either me, some conflict with some other plugin I have AND/OR the fact that I use an Apple product (which at this point I'm kind of tired with their lack of compatibility and high price)...
            Also, sorry if this is a long read... I tried to be as descriptive as possible.
            Also this is the most common message I get in the ruby console:
            Error: #<TypeError: nil can't be coerced into Float>
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:856:in /' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:856:in point_on_axis'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:386:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:1126:in push_tool'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:1126:in `onLButtonDown'
            Anyway... thank you for your time!
            • B
              Ben Ritter
              Thomas, thank you for all your updates and for sharing.
              • McGyverM
                McGyver
                I just wanted to add an update... I decided to give it a try in SU6 and it works without any problems... just like in the video.
                Actually the only thing that appears different is that I can't rotate around the model while in "scale texture" mode... if I choose the rotate tool, it leaves scale mode and I'm stuck with whatever it was at when it dropped it.
                But at least I can use it!!
                This is more or less what I was trying to do
                • pbacotP
                  McGyver,
                  I just wanted to note that I tested the quad faced texture on a sphere in SU8 Pro on a Mac, and it worked fine AFIK. I was able to scale etc. However I created a sphere using follow me (I didn't want yet another plugin, just for this test).
                  Peter
                  • dfswyfD
                    dfswyf
                    This is a fantastic plugin I have ever seen! Thank you so much!
                      When do you get this?
                      Also, are you using v0.6?
                      It works when you use the middle mouse button to orbit. Does the UV Mapping tool behave differently from other tools? I mean, how do you return to the tools if you explicitly activate the Orbit tool?
                      (I assume you meant Orbit tool when you said Rotate tool...)
                        Yea, the material must be in the model already, because Ruby plugins cannot address materials from the libraries. I thought the user would get a messagebox about this. I'll look into that.
                        Do you get an error message in the console at that point instead?
                        What part of the process are you referring to? You get a crash when closing the model?
                        Most common - are there more? Error messages are some of the most useful bit of information I can get to work with. Please post any that might appear - as there should be none.
                        • pbacotP
                          Thom If I may interject, I cannot use the middle button that way. However if I choose orbit drawing a line for example, then choose the line tool again, SU returns to the drawing process where I left off. If you orbit and then re-select the tool icon, this tool starts again at the beginning of the process (though you have the results from the previous try). So it IS different in that way, on a Mac. Peter
                            hmm... will have to look into that.
                            • McGyverM
                              McGyver
                              Answers:
                              1- After the operation has failed... This is the message that appears in the ruby console. I usually close the model after that, so there are no other messages in regards to that attempt/session.
                              2- No I am using the previous version. based on what was written it seemed either version would work for what I wanted to do.
                              3- I forgot that the middle mouse button can do that (I read that somewhere and thought "Really?... cool I've got to remember that!" and promptly forgot it)... I just checked it and it works properly with the UV Mapping tool in SU6... and probably in 8 too... it did not map the sphere but I could orbit the model without loosing the scaling lines (Red and Green)...
                              4-Yes, I did mean Orbit... that was pretty stupid of me.
                              • McGyverM
                                McGyver
                                Answers:
                                1- Yes that is the point where it gives the error message. Since I usually end the session and reopen the model, that is the last message.
                                2- The crash can come at any time... I've had it crash when selecting the UV mapping tool, choosing the quadface tool's select tool, selecting an edge for V direction... even when zooming in (using the middle mouse button scroll wheel). One thing I noticed is if I don't close the model after a mapping attempt fails, SU8 becomes more unstable... some of the Quadface tools (like the select tool and the smooth or unsmooth tools) stop working and little things like orbiting or erasing something will cause a crash...
                                This does not happen in SU6.
                                3- Yes, once or twice it crashed when closing, but that almost seemed random in regards to the other crashes.
                                4-There were two other messages... I'm pretty sure I had tried some variation (like maybe smoothing and unsmoothing the model before I chose the UV mapping tool) when I got the other messages... So the message I listed is probably THE message I get when doing it the way I described... (actually I just tried it five times in SU8 and got the same message each time).
                                I'd just like to say I'm VERY happy I can get this GREAT plugin to work in SU6... I have no problem going back and forth between SU6 and SU8... I do it all the time... some plugins just work better in either 6 or 8... so no worries! I'd also like to add that I a went and mapped several lathed models that were made using the "follow me" tool and they worked perfectly... but once again only in SU6. I could not map them in 8.
                                Thanks again for this wonderful plugin and all your help!
                                  No - please, before trying to debug this any further, update to the latest version of the plugin. (Currently 0.6) I'll be impossible for me to debug against older versions. There's all kinds of fixes etc between versions. You should always keep your software - especially when you experience problems with it.
                                  Update, see if you still have problems. Then we can start looking into anything that might appear.
                                  This plugin should work best in SU8. Jumping out to SU6 is no solution. Get back to me after updating if there are issues.
                                  • McGyverM
                                    McGyver
                                    I updated the the plugin. For Me there seems to be no change. I copied the Ruby Console message again:
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:857:in /' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:857:in point_on_axis'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:387:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:1129:in push_tool'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb:1129:in `onLButtonDown'
                                    After the above attempt I closed the model and tried again... I noticed that if I clicked on the red or green lines, the scaling handles would appear... they don't do anything... but moving them a tiny bit them generates a very large amount of error messages in the ruby console. I don't know if it is of any use but I copied it to a TextEdit file and I am including it with this post. I did not think it would make sense to fill up a huge amount of space in this thread.
                                    Most recent screen showing ruby console and lack of message.
                                    what I mean by scaling handles
                                    screenshot of tool working properly in SU6... Included for comparison (if necessary)
                                    Error message
                                      Trust me, there's lots of changes under the hood. And now the error messages will refer to the correct code which I sit with.
                                      Still not sure why you're getting these errors... it seem similar to some error in 0.3 or 0.4, but I thought I had trapped that and I'd not gotten any report since then...
                                      Can you try one thing: when activating the UV tool and after picking the U and V axis, right click and choose Use Material Size ?
                                        That message indicates that the mesh got poles in it - that the mesh cannot be mapped to a 2d grid. What the UV mapping tool does is map all the quads to a 2d grid co-ordinate in order to texture seamlessly. That means that any poles in the mesh will prevent that.
                                        • jo-keJ
                                          jo-ke
                                          I am using this nice plugin for texturing curtains. It works well in most cases but in this case I have big problems with the mesh. I doesn't map properly. Could you tell me what I have done wrong? I've attached the file below.
                                          the texture should look like this:
                                          http://hitguide.firstmedia.de/wp-content/uploads/2010/12/S118_Eleganza.jpg
                                          1-raffschal.rar
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            Is there any chance to convert it?
                                            or should I wait for your bezier plugin to create my own curtain?
                                            http://www.zz7.de
                                            • 11
                                            • 12
                                            • 13
                                            • 33
                                            • 34
                                            • 11 / 34
