    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 50.9k Views 16 Watching
    • Chris FullmerC
      This sounds great Thom and TBD and everyone one else who gets involved. I keep being afraid that I might need to learn some of this for my upcoming work.
        What you got cooking?
          Right - attempting to build on Windows.
          I have Visual C++ Express 201 installed and I'm trying to build using nmake. Getting some errors:
          I'm not sure what that means. Though I have a suspicion I need to specify the path to where windows.h is located... Though I don't know where to do so...
            Uploaded my WIP at: https://bitbucket.org/thomthom/sketchup-ruby-c-extension/
            Working on OSX 10.5.
              Note for self: http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/
                Think I got one step further. This thread mentions that vcvars32.bat needs to be run from the prompt: http://social.msdn.microsoft.com/Forums/en-US/Vsexpressvc/thread/325b5459-c469-40d0-bf6d-e3356a2f14cd/
                And this (http://stackoverflow.com/questions/6622869/problem-with-nmake)
                So after I did that I got a different error. Missing crt file...
                  ( Apologies for those with the know-how - I will be posting lots of silly stuff as I work through this. Posting to make a record of what I am doing. "Thinking out loud". )
                    Got it working!
                    Uncommented a #pragma comment(lib, "crt.lib"); I had. TBD's SUExt project had a reference to it. Which is what I based my project on. Seeing how it also referred to #pragma comment(lib, "msvcrt-ruby18.lib"); I just tried to see what happened if I removed the ref to crt.lib. Everything worked fine after that point.
                    Now I wonder what the other lines do:
                    #pragma comment(lib, "kernel32.lib") #pragma comment(lib, "gdi32.lib") #pragma comment(lib, "user32.lib") #pragma comment(lib, "shell32.lib")
                    I'm looking at this tutorial: http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/
                    It made no reference to any of this. ( what is it? Is it really required? )
                    I'm guessing #include <windows.h> is required though.
                      Now... I'd like to find a way to make any output from extconf.rb and make/nmake put everything is a separate directory - for each platform.
                        Huh... I removed all of that stuff completely, as http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/ made no reference to it at all. Worked fine without. Guess it was required due to the way the Pelles C project was set up... ❓
                          Hey Chris, when we get around to writing up the step by step instructions, are you willing to be a guinea pig?
                          • Chris FullmerC
                            Absolutely!
                              Great!
                              I'm writing up a Basic example that shows a little more than Hello World.
                              Then I start on making the step by step Wiki tutorial. I hope people with more know how can fill the in the "why" to much of it. And that people will try it and give feedback on what is unclear and what turns out not to work.
                              • Dan RathbunD
                                Dan Rathbun
                                To do so via the IDE... from the menu Tools > Options...
                                .. brings up the "Options" dialog.
                                Choose "VC++ Directories" from the "Projects and Solutions" branch in the nav tree.
                                You can see the dirs for catagories by selecting the cat from the "Show directories for:" dropdown control:
                                Executable files:
                                Include files:
                                I'm not here much anymore.
                                • Dan RathbunD
                                  Dan Rathbun
                                  Don't forget the "help" topic here:
                                  [Info] C/C++ Ruby extensions & SketchUp plugins
                                  .. and read Adan Nelson's posts (links on the above list.)
                                  • Dan RathbunD
                                    Dan Rathbun
                                    from the info file "win32.readme" in the Ruby C source:
                                    You can NOT use a path name [that] contains any white space characters as
                                    the ruby source directory, this restriction comes from the behavior of include directives of NMAKE.
                                    (- you may call it a bug. -)
                                    • tbdT
                                      tbd
                                      Thom: #pragma comment(lib, "*.lib") adds the libraries to the link phase (that hold imports and functions code)
                                      it was a way to make sure that it will compile even if you create a new project and don't use in mine in PellesC.
                                      http://plugins.ro
                                        Right'o! Gotcha. Been reading more up on C and GCC.
                                        • T
                                          tomasz
                                          Thanks Thomas for the example.
                                          I do not understand what is 'extconf.rb' for. I have compiled my extension under VC++ 2008 without running the file and without using any makefile... Is it bad ? 😕 💚
                                          • tbdT
                                            tbd
                                            extconf.rb - external configuration, it generates the makefile to create the extension. using makefile you can automate builds and tests.
                                            http://plugins.ro
                                            • 2 / 9
