    Check out this extremely talented modeler
    67 Posts 19 Posters 11.7k Views 19 Watching
    • hellnbakH Offline
      hellnbak
      @tfdesign said:
      Now try applying textures to each part! πŸ˜† πŸ˜‰
      Textures I can work with -- Rendering is completely beyond me. I hope I didn't offend anybody by playing with Jason's render. You've got to be so careful nowadays πŸ˜•
      • david_hD Offline
        david_h
        When I first saw the Headline of this Thread, I thought for sure it would be featuring ME, but alas. . . twas not to be. πŸ˜’ πŸ’š
        This stuff is just amazing.
        I hate him.
        JK.... πŸ‘ πŸ‘ πŸ‘
        • jason_marantoJ Offline
          jason_maranto
          No offense taken -- I'm easy πŸ˜‰
            turbobrad
            Wow, simply incredible. With detail like this there must be one in his garage that needs put back together. πŸ‘
            BradE
            Dean3Design
            • hellnbakH Offline
              hellnbak
                dbalex
                (indeed great model)
                http://www.bocostudio.com
                • X Offline
                  xrok1
                  Very nice! with all that knowledge of engine detail you'd think the modeler would know that the 427 is a chev engine though. Ford makes the 429 !? 😳
                  • david_hD Offline
                    david_h
                    whatever. . .The real question. . .can he come buy and fix my Mazda? πŸ’š
                    • hellnbakH Offline
                      hellnbak
                      Wiki:
                      The Ford Single Overhead Cam (SOHC) 427 V8 engine, familiarly known as the "Cammer", was released in 1964 to recapture NASCAR dominance from the Chrysler 426 Hemi engine. The Chrysler 426 used extremely large block casting that dwarfed the earlier 392 Hemi. The Ford 427 block was closer dimensionally to the early Hemis than to the elephantine 426 Hemi: the Ford FE bore spacing was 4.63 in (117.6 mm) compared to the Chrysler 392's bore spacing of 4.5625 in (115.9 mm). The Ford FE's deck height of 10.17 in (258.3 mm) was lower than that of the Chrysler 392 at 10.87 in (276.1 mm). For comparison, the 426 Hemi has a deck height of 10.72 in (272.3 mm) and bore spacing of 4.8 in (121.9 mm); both Chrysler Hemis have decks more than 0.5 in (12.7 mm) taller than the FE.
                      The engine was based on the ultra high performance 427 side-oiler block, providing race-proven durability. The block and associated parts were largely unchanged, the main difference being use of an idler shaft instead of the camshaft in the block, which necessitated plugging the remaining camshaft bearing oiling holes.
                      • urgenU Offline
                        urgen
                        O-O-O amazing model! 😲 πŸ‘ ... the first very fast test in hypershot πŸ˜• ...no post prosessing...
                        --pupil forever...------
                        • hellnbakH Offline
                          hellnbak
                          Wow, very nice! But where are the other two parts of the engine (it's a three-part download)?
                          • hellnbakH Offline
                            hellnbak
                            It's been a long time since I've worked on an engine, and I've never worked on a Cammer, but shouldn't there be bolts here?
                            Or is is bolted from below before assembly, and these are just the top of the threaded holes?
                            • X Offline
                              xrok1
                              My bad. 😳
                              Should've know something with that much detail had a real world reference. πŸ’š
                              • JMJOhioJ Offline
                                JMJOhio
                                Hello Everyone...
                                I'm JMJ-Ohio (Jim Jeffries) and I live in Brookville, Ohio. I want to thank hellnbak for introducing my work to this forum. Did'nt know SketchUcation existed until he contacted me. The "Cammer" was my first real project using SketchUp and I relied more on countless hours at the tube and stubbornness than on talent. The monkey can paint a masterpiece if given enough time and bananas. πŸ˜†
                                I have been involved with machinery and mechanisms for 40+ years, being employed as a mechanical designer and project engineer. I retired 2 years ago, thus allowing me time to catch-up on home projects and play on the computer. But, I rejoined the work force last month so play time will now be very limited.
                                The Ford 427 SOHC project. No, I didn't have any blueprints or have an engine in my garage. Online research netted numerous technical articles that included critical dimensions and data. I also downloaded and printed hundreds of photos. The combination of known dimensions, proportional measuring of photos and deduced dimensions via detail relationships allowed the picture to come together. A thorough understanding of the function and construction of the subject item is a vital part in allowing the creation of realistic images.
                                I am pleased with the results of my efforts, but my models are not practical due to their resultant file sizes.
                                I envy those of you who can create works that please the eye, are portable in size and don't take hundreds of hours to produce. There are many very talented artists and craftsmen out there and when I see their work it encourages me to try harder and learn new ways to do things.
                                Have added a few more screen shots.
                                p.s. -- no bolts from the top in those carb holes. Your second observation is correct.
                                Internal detail
                                Internal detail
                                In the 32 Highboy
                                • mitcorbM Offline
                                  mitcorb
                                  Welcome, JMJOhio:
                                  Thanks for responding/ joining. You will find a friendly community here.
                                  • soloS Offline
                                    Welcome to SCF Jim.
                                    That model is insane, the amount of detail is staggering, you must suffer from OCD to create such a master piece.
                                    Hope to see more in the future.
                                    • hellnbakH Offline
                                      hellnbak
                                      Hi Jim, glad you decided to check us out. I think you'll find these forums very helpful, there's a real sense of community here. In fact your work is even more impressive knowing that you did it all without benefit of these forums and the incredibly knowledgeable and helpful experts here. Usually someone just starting out with SU has any number of questions, and they turn here for the answers. I know I couldn't have gotten very far without them.
                                      Thanks for the new photos, your incredible engine is even more detailed internally than I thought. Are there any parts that you didn't make? Wouldn't be surprised if you modeled a torque wrench to make sure everything was snugged to specifications πŸ˜†
                                      So, what made you decide on this particular engine, did you have some experience with it at some point in your life? And why so much detail? Prior to this model, SU engines (at least the ones posted to the warehouse) were only modeled externally, at least to my knowledge. What made you decide to go the whole nine yards with this, or is that just the way you work? I too like a lot of detail with my models, but I could never hope to achieve this level of detail.
                                      I'm really looking forward to seeing your finished '32 Highboy. Like I mentioned to you, I had been working on my own '32, a 3-window. Was making it stock (I like my cars that way), but after I checked out what you had posted mine started to resemble a tinkertoy, sorta lost interest in it. It's all your fault 😒
                                      Really sorry to hear that you won't be able to spend as much time working with your SU models, but hope you'll share any future accomplishments. Let me know what you're thinking about coming up with next so I won't bother to tackle the same thing.
                                      From your online name, I assume you live, or lived, in Ohio. I too am a buckeye, born and raised in a little one-stoplight town called Fredericktown. I call Michigan my home now, although with another lake-effect Winter setting in I wish I was back "down south" in Ohio.
                                      Well, I'm sure you'll get a lot of questions from others here on the forum, especially concerning your methods, just wanted to welcome you.
                                      I attached some photos of a couple of different versions of my '32, thought you might be willing to offer some advice.
                                      (oh, did I mention that I kinda like your work?)
                                      • JMJOhioJ Offline
                                        JMJOhio
                                        I think your center of gravity is to high. They look a little bit roll-over prone.
                                        I'm in Brookville, northwest of Dayton.
                                        I followed drag racing pretty closely during the 60's & 70's and this engine made it's presence known. NASCAR banned it and NHRA loved it.
                                        The detail. As mentioned earlier, OCD runs in the family.
                                        • hellnbakH Offline
                                          hellnbak
                                          Took a few minutes to play with your "Stub Timing Sprocket", and by reducing it to four smaller components, got it down from 966kb to 99kb, almost a 90% reduction. This could apply to a lot of your components, don't know how much it would reduce your size overall but it would certainly help.
                                          • JMJOhioJ Offline
                                            JMJOhio
                                            Very good point. I have been using more sub-components lately, but your example breaks the final component into more chunks than I would have created. Thanks.
                                            I also need to break the habit of using to many arc and circle segments when they are not necessary.
                                            • 2 / 4
