    Check out this extremely talented modeler
    67 Posts 19 Posters 14.7k Views 19 Watching
    • mitcorbM
      mitcorb
      @dereei:
      I kind of based my comment on noticing the flanges and body of the fuel pump housing had some telltale facets. But the main portion of the work overall is fantastic.
      • jason_marantoJ
        jason_maranto
        This is outstanding -- it's so rare to see modeling like this on the warehouse. I couldn't resist doing a clay render with Maxwell.
        Best,
        Jason.
        • hellnbakH
          hellnbak
          Best,
          Jason.
          And I couldn't resist tweaking your excellent clay render πŸ˜„
          • T
            tfdesign
            Now try applying textures to each part! πŸ˜† πŸ˜‰
            • hellnbakH
              hellnbak
              Textures I can work with -- Rendering is completely beyond me. I hope I didn't offend anybody by playing with Jason's render. You've got to be so careful nowadays πŸ˜•
              • david_hD
                david_h
                When I first saw the Headline of this Thread, I thought for sure it would be featuring ME, but alas. . . twas not to be. πŸ˜’ πŸ’š
                This stuff is just amazing.
                I hate him.
                JK.... πŸ‘ πŸ‘ πŸ‘
                • jason_marantoJ
                  jason_maranto
                  No offense taken -- I'm easy πŸ˜‰
                  • T
                    turbobrad
                    Wow, simply incredible. With detail like this there must be one in his garage that needs put back together. πŸ‘
                    BradE
                    Dean3Design
                    • hellnbakH
                      hellnbak
                        dbalex
                        (indeed great model)
                        http://www.bocostudio.com
                        • X
                          xrok1
                          Very nice! with all that knowledge of engine detail you'd think the modeler would know that the 427 is a chev engine though. Ford makes the 429 !? 😳
                          • david_hD
                            david_h
                            whatever. . .The real question. . .can he come buy and fix my Mazda? πŸ’š
                            • hellnbakH
                              hellnbak
                              Wiki:
                              The Ford Single Overhead Cam (SOHC) 427 V8 engine, familiarly known as the "Cammer", was released in 1964 to recapture NASCAR dominance from the Chrysler 426 Hemi engine. The Chrysler 426 used extremely large block casting that dwarfed the earlier 392 Hemi. The Ford 427 block was closer dimensionally to the early Hemis than to the elephantine 426 Hemi: the Ford FE bore spacing was 4.63 in (117.6 mm) compared to the Chrysler 392's bore spacing of 4.5625 in (115.9 mm). The Ford FE's deck height of 10.17 in (258.3 mm) was lower than that of the Chrysler 392 at 10.87 in (276.1 mm). For comparison, the 426 Hemi has a deck height of 10.72 in (272.3 mm) and bore spacing of 4.8 in (121.9 mm); both Chrysler Hemis have decks more than 0.5 in (12.7 mm) taller than the FE.
                              The engine was based on the ultra high performance 427 side-oiler block, providing race-proven durability. The block and associated parts were largely unchanged, the main difference being use of an idler shaft instead of the camshaft in the block, which necessitated plugging the remaining camshaft bearing oiling holes.
                              • urgenU
                                urgen
                                O-O-O amazing model! 😲 πŸ‘ ... the first very fast test in hypershot πŸ˜• ...no post prosessing...
                                --pupil forever...------
                                • hellnbakH
                                  hellnbak
                                  Wow, very nice! But where are the other two parts of the engine (it's a three-part download)?
                                  • hellnbakH
                                    hellnbak
                                    It's been a long time since I've worked on an engine, and I've never worked on a Cammer, but shouldn't there be bolts here?
                                    Or is is bolted from below before assembly, and these are just the top of the threaded holes?
                                    • X
                                      xrok1
                                      My bad. 😳
                                      Should've know something with that much detail had a real world reference. πŸ’š
                                      • JMJOhioJ
                                        JMJOhio
                                        Hello Everyone...
                                        I'm JMJ-Ohio (Jim Jeffries) and I live in Brookville, Ohio. I want to thank hellnbak for introducing my work to this forum. Did'nt know SketchUcation existed until he contacted me. The "Cammer" was my first real project using SketchUp and I relied more on countless hours at the tube and stubbornness than on talent. The monkey can paint a masterpiece if given enough time and bananas. πŸ˜†
                                        I have been involved with machinery and mechanisms for 40+ years, being employed as a mechanical designer and project engineer. I retired 2 years ago, thus allowing me time to catch-up on home projects and play on the computer. But, I rejoined the work force last month so play time will now be very limited.
                                        The Ford 427 SOHC project. No, I didn't have any blueprints or have an engine in my garage. Online research netted numerous technical articles that included critical dimensions and data. I also downloaded and printed hundreds of photos. The combination of known dimensions, proportional measuring of photos and deduced dimensions via detail relationships allowed the picture to come together. A thorough understanding of the function and construction of the subject item is a vital part in allowing the creation of realistic images.
                                        I am pleased with the results of my efforts, but my models are not practical due to their resultant file sizes.
                                        I envy those of you who can create works that please the eye, are portable in size and don't take hundreds of hours to produce. There are many very talented artists and craftsmen out there and when I see their work it encourages me to try harder and learn new ways to do things.
                                        Have added a few more screen shots.
                                        p.s. -- no bolts from the top in those carb holes. Your second observation is correct.
                                        Internal detail
                                        Internal detail
                                        In the 32 Highboy
                                        • mitcorbM
                                          mitcorb
                                          Welcome, JMJOhio:
                                          Thanks for responding/ joining. You will find a friendly community here.
                                          • soloS
                                            Welcome to SCF Jim.
                                            That model is insane, the amount of detail is staggering, you must suffer from OCD to create such a master piece.
                                            Hope to see more in the future.
                                            • 1 / 4
