    Need help with a complex symmetrical Teaching Hospital model
    75 Posts 11 Posters 9.8k Views 11 Watching
      SonofMoose
      Hello Wo3Dan:
      I have actually previously tried to master Google SketchUp but sadly possess extremely poor 3d perception. This disability has already not only caused me to repeatedly fail the yard test component of my drivers test but also caused me to struggle with all forms of venisection (thereby effectively blighting my clinical career) ....
      I am still (seemingly against all sound judgement) hoping that a master modeler might either take pity on me and/or be sufficiently motivated by the challenge presented to offer their services to our project.
      In all truth, this model does not represent an indispensable component of our proposed application - although it would surely add much value to it. It is therefore a much-cherished luxury that could (as previously suggested) function as a showcase centerpiece for it ....
      I know that many Google SketchUp masters love to model real life buildings. Maybe one of them might instead be prepared to try to create something unique ....
      In summary, you are also most correct in your comment that I have indeed spent a great deal of my time trying to (seemingly unsuccessfully) explain the "rules" (a good term) defining the proposed main THC. Unless I can soon find someone who is prepared to actively assist me in this regard, I think that it will be time to consider closing this already rather lengthy thread that has ultimately (and sadly) delivered nothing.
      I was obviously hugely lucky to have managed to acquire the services of Sandy to create the "single winged" and "single ringed" model adorning the first page of this thread ....
      • BoxB Offline
        I agree with Wo3Dan, your explanations of what you want don't really come together in other peoples heads and I'm sure you would see it all better if you modeled it yourself.
        For example, I took your 100m by 22m with 6m corridors, modular structure and gave it a 3m high wall, as you will see from the attached image and skp file, the overall scale doesn't impress, it's too flat. It does however give you over 500 individual modules, some of which are naturally smaller and cut off by the design.
        I only did this out of curiosity in a spare moment, I'm not interested in taking it any further.
        Hospital.skp
          SonofMoose
          Hello Box:
          I am really impressed with your obviously fairly hastily designed model of my proposed main THC design. While not perfect in the positioning of the individual modules, it certainly does provide one with a good idea of what it could like at a slightly different scale.
          I see that it has already had (iirc) 27 downloads. Is there anyone "lurking" in this thread who would like to try to "run" with this?
          Otherwise I suppose that this might (quite possibly) represent a somewhat appropriate final post for this lengthy and ultimately vainglorious thread .... 😢
            SonofMoose
            Hi there:
            Unless something truly meaningful transpires, this will most probably represent the final post of this thread.
            I have taken the liberty of attaching a (reduced size to meet the requirements of this forum) schematic outline of one of the five identical "double wings" (where each labeled rectangular block is a 110m x 22m module).
            I would like to forward my kindest regards and sincerest gratitude to those people who have contributed to this thread.
            ![A more accurate "double wing" outline](/uploads/imported_attachments/Lhej_TwincruciformTHwingMegaTHC2.png "A more accurate "double wing" outline")
            The above outline placed within Google SketchUp
            A slightly more complex (at the base) outline placed within Google SketchUp
            • charly2008C Offline
              charly2008
              Is that what you want? 3200 Modules in ten floors
              One ex five double wings-1.skp
                SonofMoose
                Hello Charly:
                You are certainly getting a bit closer .... 😄
                Unfortunately a 2d outline (of only one wing) does not easily translate into a fully-fledged 3d model of the entire complex (which consists of five identical wings and the central rings). For instance, the series of (presently flat) square shaped areas situated between the sets of modules are actually internal quadrangles (open spaces) that need to be enclosed within each floor. The internal passageways will also need "cut across" the internal water features (as a series of perspex-lined structures).
                Maybe you can try these (fairly minor) modifications and we might (hopefully) slowly move forward .... 😉
                  SonofMoose
                  Hello Karl, et al.:
                  Please forgive me - but it has taken me ages to see where your above interpretation of my proposed THC model further departs from the original concept .... 😮
                  The inner decagonal rings are totally missing and have been replaced by a small innermost square. Admittedly this solution obviates the possibility of additional deadspace existing between decagonal arrangements of the modules. Maybe we can still attempt this rather tricky aspect of the design which will determine the alignment of the FIVE (and not four) outer double wings .... ??
                  Now perhaps you are beginning to see the inherent difficulty in this design .... 😉
                  • BoxB Offline
                    I suspect we have been seeing the difficulties from the start!
                      SonofMoose
                      Charly:
                      You seem to have included four of the five wings in your models. Therefore not too much is missing. However I do easily appreciate the fact that (as further possible details are inserted into the developing model) its size will most likely continue to soar.
                      Does SketchUp have a predefined limitation in the amount of information (for want of a better term) that it can store?
                      Admittedly, Sandy's earlier (and much simpler) model was developed with 3ds Max 2008 ....
                      Therefore "quo vadis"?
                        charly2008
                        What I want to show you is that the only one wing, with this level of detail, is almost impossible to handle in Sketchup. Perhaps this would be feasible with a CAD software.
                          SonofMoose
                          Extra comment:
                          I was previously informed by a professional architect that many of his colleagues use SketchUp to refine their designs. They then subsequently import the finished SketchUp design into a CAD programme in order to render it. I don't know whether this insight is of any relevance to us ....
                            charly2008
                            @box said:
                            @box said:
                            I agree with you
                              charly2008
                              I think you need a 3D CAD specialist group that is willing to implement your idea.
                                Jeremy, this is an enormous structure. I really doubt that you will find any application that can handle this at the level of detail you envisage. This is just one fifth of it right? This image was taken from the middle. Last time I saw such "visions", it was those of the obsessed dictators from Hitler to Ceausescu (sorry for the comparison) since this would be a whole city in fact.
                                  SonofMoose
                                  Hello all:
                                  I have tried the Autodesk forums - but with no success ....
                                  This is as far as things have gone in a long time. However (if it is deemed impossible to replicate an admittedly far more complex version of Sandy's original model) I am prepared to "call it quits" with this seemingly overambitious aspect of our healthcare education application ....
                                  If there is a "White Knight" lurking in the background, I humbly suggest that s/he "comes to the party" now ....
                                  • BoxB Offline
                                    Jeremy, you seem to be missing the main point here, a white knight isn't what you need, the extent of your project exceeds the capabilities of sketchup.
                                    I have attached a model of one wing mad from components, which helps reduce the file size but does little to help the program cope with the amount of entities it has to "Draw".
                                    It is one wing, one floor and is made from one module that I knocked together in a rough unfinished, and purely made up, construction stage of the building. Admittedly you wouldn't need most of the internal workings that this shows but it gives an Idea of how as you add detail the program struggles. Plus if each module is different then it gets worse, and if you add equipment, colours, textures and so on it will get worse.
                                    Open it up and have a look how it behaves when you try to navigate around it.
                                    TestTHC.skp
                                      SonofMoose
                                      Hello Box:
                                      I have long given up (with SketchUp at least) the possibility of any form of internal walk-through. All I would desire is an external THC model. In fact, the series of internal divisions appearing in my outlines (which are ultimately not essential) are merely an attempt at "correcting" the measurements of the individual wings.
                                      I was hoping that such a "White Knight" would have access to and be proficient with one of the standard professional CAD products. Sadly (and with all due respect) Google SketchUp seems to be a "light weight" freeware product specifically designed for the (admittedly) creative masses. It certainly does not seem to possess the capabilities of its (admittedly hugely expensive) equivalent commercial products specifically designed for the professional market.
                                      They are sadly (but in truth) obviously "chalk" and "cheese" ....
                                      The programme immediately became unresponsive and froze .... 😞
                                      Point taken ....
                                      • BoxB Offline
                                        I'm sorry you were unable to view the file on your computer, perhaps it is one of those lightweight ones designed for the masses.
                                          SonofMoose
                                          Box:
                                          My second attempt was somewhat more successful (I saw the lady with the red jersey). There was still a massive amount of lag ....
                                          I am afraid that is all that I can afford as an unemployed caregiver .... 😞
                                          No disrespect was intended with my earlier comment. It just seems to represent a factual observation ....
                                          • BoxB Offline
                                            I personally think you would be better off looking for a more image based solution.
                                            I'll put a link here for what is known as a Virtual tour.
                                            You can click on it in different places and get more information etc
                                            This one is fairly simple but you can click on the "i" button which takes you to a 360deg image of the space.
                                            I'm using this link simply as an example of one I'm familiar with as it's one of the ships I have been involved with building.
                                            There are many more example available on the internet.
                                            Invalid URL
                                            (www.royalcaribbean.com)
                                            • 4 / 4
