    UV mapping texture software
    19 Posts 4 Posters 2.2k Views 4 Watching
    • soloS
      First is an easy one, a table cloth (very quick model, not to any scale) I supplied the texture also.
      UV test.skp
        What's up with the edges around the centre? Anyway I'll knock something out.
        • soloS
          I used Artisan...
          Here is another, more complicated, it's a bed spread drape in which I used Artisan, TGI and cleanup, this is what I'd use more than often to create such models, yet UV mapping it is almost impossible in SU. Also not to scale.
          bed spread uv test.skp
            Better file πŸ‘
            [flash=800,600:jx9kkg0t]http://www.youtube.com/v/tHGgXlSxRLA[/flash:jx9kkg0t]
            • numbthumbN
              numbthumb
              Rich, I would also like to know how do you UV map such irregular shapes, I mean where do you hide the seams?
              Comfortably numb...
              • soloS
                Okay, you mapped it and you can whistle πŸ˜•
                Can you show how it's done?
                  It was a test before I record the process to see if it's what you want. I'll record it now.
                    Here you go cranky pants...
                    [flash=800,600:3lxjfqo1]http://www.youtube.com/v/q4nDnSg0hgo[/flash:3lxjfqo1]
                      amorp
                      Thanks a lot πŸ˜„
                      From question comparing UV mapping software, it grows to video tutorial πŸ˜„
                        Glad you got some info from it.
                        Pete?
                        • soloS
                          Great stuff Rich, I had that app at one time until I formatted my drive two months ago, need to get it again and use your tutorial and see if I can get a similar result.
                            Well, I just brushed the surface here of what this can do. Let me know if there's anything else you need πŸ‘
