    Some Roman World Heritage stuff
    25 Posts 9 Posters 4.9k Views 9 Watching
      Roger
      Gai, where did you get the un-shadowed textures and how did you achieve the roughness at wall intersections? Are the individual edges modeled or did you do a lot of post? What kind of finish would the walls have had when the building was occupied?
      Nice work.
      http://www.azcreative.com
        Thanks guys (and sorry for the late replies but I was away then had a bunch of guests this week).
        Roger: which texture do you mean? As for the finish: there is no trace of anything so the walls would be simple stone (and/or mixed with bricks).
          Roger
          I was referring to the way the grout lines cut into the surface as you go around corners. In other words, where walls meet is it a geometrically straight line or are the bricks delineated in 3D space?
            bjornkn
            Didn't he write that it was a photo of a physical model?
            Looks like a very interesting project to work on anyway - physical or 3D!
              Roger
              Sorry about that. He did note that in very very small ensy weensy super small microscopic written on the head of a pin type. My bad.
                bjornkn
                Yes, he was obviously trying to hide the fact that it was a photo by using that tiny font 😉
                Photo or 3D - that model is impressive anyway!
                  Ah, ok, sorry. Yes, I also wrote that I wish to catch up with that quality.
                  There was an architecture professor here who modelled many of these buildings by laying those stones and bricks one by one (at 1:20 scale). He even made the bricks and roof tiles of real, Roman bricks! 😲
                  Now while some of his models are not archaeologically correct, they are still awesome and are in the exhibition. 👍
                  As for your question however; those grout lines could be rendered with displacement actually. Need a very nice texture first of all of course.
                    Well, another version of the above model - now rendered in Twilight and grass aded in PP. I'd prefer the first version as the grass coming up a bit onto the walls make it more realistic looking but since we found some traces of bare ground immediately around the building (probably also due to dripping rain from the roofs and all), I had to PP that ground in, too. Now it looks rather fake and as if the whole building were just floating there but as you say, the client is always right.
                    Some irregularities here and there on the walls (like the stones mixed with some bricks) would be nice but the walls were definitely not striped as in the first picture.
                    I have yet to model another dozen of them this week. 😲
                    • mitcorbM Offline
                      mitcorb
                      Hi, Gaieus:
                      I am just guessing, (believe me, I am no render expert) but maybe some atmospheric effects to soften the starkness of the stone walls could make the building "settle down"? Also, maybe the point of view and the way the hill falls off seem to contribute to the unwanted floating effect?
                      Edit: Perhaps, randomly add some baldness here and there that extends further from the dripline?
                        In fact, probably even the current "sky" will be removed (like here). The more random and extensive, bare blotches may be a good idea. (Good that I have the file with a bunch of layers so I can experiment without screwing up the final image) 😄
                        • mitcorbM Offline
                          mitcorb
                          Hi, Gaieus:
                          It seems the front steps may need some "blending"?
                            They are actually huge stones (5 in a row) and I even rounded their edges and correctly UV mapped them but this is not visible from here. 😞
                            • mitcorbM Offline
                              mitcorb
                              Hi, Gaieus:
                              Do you have any historical data to suggest how the upper edges of the terra cotta caps on the buttresses interfaced with the stone? This transition is an age old problem as far as moisture protection goes, especially in today's pallette of materials. There certainly would not be any immediate problem in solid stone masonry, but leaching of the mortar due to continual moisture would certainly become a problem in 50 years or so. I understand the Romans actually developed a form of hydraulic concrete. Perhaps they had a similar mortar?
                                I really have no idea. Most probably these details are what have been repaired several times even on existing buildings and the original has not survived. Here, in Hungary, they still use the technique (on older buildings) that they simply smear a thick layer of mortar in places like that hoping the owner will not notice. 😄
                                • mitcorbM Offline
                                  mitcorb
                                  Well, mortar itself has some waterproofing abilities for the very short term. But it is extended cycles of saturation and drying that does the damage.
                                    Yeah, I have just checked the building in the neighbouring lot and that mortar is all cracked. I guess maintenance is always needed...
                                    • H Offline
                                      Hepf
                                      Yahhh ... ok I'll have to go and try some textures on my work, your models look quite good, but also time consuming ...
                                        Indeed. First finding the right texture then applying it correctly (like around arches, corners...) indeed often takes longer than the whole modelling phase. But eventually it can add quite a great deal of realism to the model.
                                          Okay, playing around in Lumion... This is the same building (not much has changed) but now I built some dozen of the other ones.
                                          Then an overview of the whole site (some material tweaking will still be needed here and there)
                                          For the time being, not each is fully elaborate (I just had to render a big poster so shovelled all the models together). Not all the chapels we know of are in the image - only the ones that can be visited (there are some 10 more).
                                          Now I need to add the whole town (to the south) and we are ready. 😄
