    Nomeradona's Interior (update Mar'12)
    86 Posts 29 Posters 13.2k Views 29 Watching
      Click Draw
      Awesome images and Photoshop work! In image three in your first post, is that bump or displacement used on the red textured backing on the art pc? I have been finally putting some time into V-Ray lately and am actually getting it. Great stuff Nomer!
      Cheers,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • N Offline
        nomeradona
        @frederik said:
        Although the floor material seem a little too shiny/reflective, it sure is a nice render... ๐Ÿ‘
        thanks frederick. i think the specularity was brought more because of the affect specular by the rectangular lights. i think i could see that. thanks for pointing it. โ˜€
        • N Offline
          nomeradona
          @kwistenbiebel said:
          Very nice Nomer.
          I love all the images in this thread. Tasteful, colourful and very skillful.
          Great job ๐Ÿ‘
          thanks christ.. im happy that the man which one of the icon in this field loved these images.
          • N Offline
            nomeradona
            @sepo said:
            Great image Nomer... ๐Ÿ‘ ๐Ÿ‘
            thanks sid as always.
            • N Offline
              nomeradona
              Cheers,
              Jeff
              hi jeff, its actually a bump. i used the normal map by bunkspeed (hypershot) on that particular scene... using normal map on the bump slot is much better than black and white bump based on my experience with both vray and hypershot. yeap indeed once you get the hang of vray, it will be pleasure, the quality and speed factor of this soft is there. remember the initial learning curve is a bit steep but once you conquered the initial slope the remaining is not that steep anymore. so goodluck jeff/
              • N Offline
                nomeradona
                Another view of my Eccletto Pod
                http://farm4.static.flickr.com/3509/4080415898_2c245b615a_b.jpg
                  robert111
                  very nice render nomeradona
                  can you explain how to make ( the style using lines with rendered ) with photoshop plz
                  thanks
                  • N Offline
                    nomeradona
                    robert.. here is the tutorial http://nomeradona.blogspot.com/2011/05/nomeradona-mixed-media-approachsketchup.html
                    • Bryan KB Offline
                      ๐Ÿ˜ฎ
                      • N Offline
                        nomeradona
                        Additional
                        Tatami from Light up site.
                        http://i1180.photobucket.com/albums/x410/adonan1/Japaneseinspired.jpg
                        http://www.sketchupartists.org/wp-content/uploads/2011/05/render-2.jpg
                        http://www.sketchupartists.org/wp-content/uploads/2011/05/render-3.jpg
                        • michaliszissiouM Offline
                          michaliszissiou
                          On this perfectionistic environment, well it's perfect and peaceful. !
                          Two notes,
                          • these are probably your own paintings and they look more interesting to me than any render engine.
                          • This shadow casting, there's some inconsistency on this, no, some unnatural phenomenon. Too blurred effect indicating that sun is near us. Too close...
                          • N Offline
                            nomeradona
                            Two notes,
                            thanks michalis.. no those paintings are not mine they are hai's a friend. I am not sure about how vray sun works. all i did was to increase a bit the size of the sun. But one thing i notice, when the object is far from the area where the shadow is being cast then its blurry. The further it is the more it becomes blurry.
                            • N Offline
                              nomeradona
                              Michalis, btw my paintings has evolved again into another direction. I am setlling with this using woman as generalized subject infusing "alibata" our pre-colonial script. I am using lots of architectural related material like sand, cement putty, coats that protect stell from rusting, waterproof materials to create texture.
                              http://farm6.static.flickr.com/5027/5552105299_027503c0b7_z.jpg
                              more of my work here. http://nomeradonaart.blogspot.com/p/my-art-gallery.html
                                michaliszissiou
                                Nice!!!
                                About renders: These are peaceful environments, I could live there. Though rather a chaos in my home LOL, dogs etc. But not really.
                                You could try some SSS on this plant. And a smaller sun. Too blurred shadow casting from the sun tends to look a bit unnatural in some cases. An emitter could work, but I don't know much about vray. All my knowledge is about Cycles.
                                • N Offline
                                  nomeradona
                                  Nice!!!
                                  in vray i think the sun size can make all those shadows sharper. A value of 1 means completely hard shadow. I think I used a value between 3-5 here. I think you are right with those plant. In vray double sided work as fine to give translucency. thanks for that.
                                  • N Offline
                                    nomeradona
                                    http://nomeradona.files.wordpress.com/2011/03/render-interior-done.jpg
                                    http://nomeradona.files.wordpress.com/2011/03/interior-3.jpg
                                    • N Offline
                                      nomeradona
                                      more
                                      http://i188.photobucket.com/albums/z306/nomeradona/Rendered.jpg
                                      http://4.bp.blogspot.com/-hQybj_dhJGs/T1Cf98TjyYI/AAAAAAAACTw/KYTDbVPyBPM/s640/with+slats.jpg
                                      http://i188.photobucket.com/albums/z306/nomeradona/custom.jpg
                                      • N Offline
                                        nomeradona
                                        a kitchen for ana
                                        http://i188.photobucket.com/albums/z306/nomeradona/nomeradonaforana.jpg
                                        • F Offline
                                          fymoro
                                          Super render, congrats, I come back to Saigon the 11th April, will contact you for a beer there, Cheers, Fred.
                                          http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                                          • stefanqS Offline
                                            stefanq
                                            Well done, Nomer! But why not IES lights?
                                            • 4 / 5
