    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 95.9k Views 31 Watching
    • N
      Niffler
      Hello, sdmitch,
      Thanks for the reply. I'm sorry, I used the wrong phrase and confused the menu bar with the toolbar (considering that, well the majority of my tools are found under Tools on the menu bar).
      I'm pretty sure that the plugin I'm using is yours (it's found under the menu bar, Plugins > Bolt Maker). I'm just pretty frustrated. I managed to get the plugin to work once on SketchUp 8 but, since then, any time I click on the Bolt Maker button under the Plugins menu, the dialogue box for using it wouldn't even appear; its as if I never clicked on it at all.
      I apologize if my original post was a bit combative; it's frustrating having a vastly time-saving plugin on my system that doesn't work for whatever reason.
      So, can you help me? Have you encountered this problem before with your program, or know of anything that would cause the plugin to only work only once? I appreciate any help you can render.
      • kenK
        ken
        Note, I also have the same problem. I just didn't mention the problem as I use the bolt maker dynamic component. However, I do wish your plugin would work.
        What is does on my machine, it will work one to two times than that is the last it will work. One time removed the txt file and it work one more time. But as of now it does not function each and every time.
        I hope you get this sorted out as I use a lot of bolts.
        Thank you for your work and the plugin.
        Ken
        • N
          Niffler
          Thank you, Ken! It's good to know I am not alone in my plight!
          I have since deleted and reinstalled using the version of Bolt Maker found on sdmitch.blogspot.com. When I went to use that one, the dialogue box appeared normally. I then went to use the plugin, but it would not recognize my created groups as actually being groups. I then clicked out of the Bolt Maker dialogue box to make another component, in the hopes that would work, and then went to reopen Bolt Maker. Nothing happened; same problem as before.
          I closed down SketchUp and replaced the Bolt Maker.rb file with a backup I had made earlier. I am unsure if it was designed for 7 or 8, but I replaced it. Now, no matter how many times I delete the .rb file, restart my system, and reinstall using a new file downloaded directly from blogspot, the program will not work.
          This may be a silly question, but where is this .txt file in SketchUp associated with Bolt Maker? I may try deleting that as well when I reinstall, but there is no .txt file that I can see under C:\Program Files\Google\Google SketchUp 8\Plugins
          Also, I'm running Vista, and, unlike all other times, the last couple times I went to delete the .rb file, User Account Control did not pop up to ask me for permission to delete the file. Weird...
          • kenK
            ken
            Here is the txt file, "Bolt Maker7.txt".
            Ken
            • sdmitchS
              sdmitch
              Niffler, The .txt file is automatically created when it doesn't exist and just keeps the last input parameters for future runs.
              The only problems I have had with the plugin relate to the .start_operation/commit_operation block but those are not active in the plugin I posted.
              If you would please open the Ruby Console before running the plugin and post any errors that appear there.
              http://sdmitch.blogspot.com/
              • N
                Niffler
                Greetings Sdmitch,
                As you requested...
                Error: #<ArgumentError: Cannot convert "0.167'
                " to Length>
                C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:48:in to_l' C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:48:in dialog'
                C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:41:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:25:in new'
                Niffler
                • N
                  Niffler
                  Greetings Sdmitch,
                  As you requested...
                  " to Length>
                  Niffler
                  [UPDATE] I have found it! I found the bug!
                  Last night, I went into my old system and deleted all remenants of Bolt-maker.rb from SketchUp8/Plugins. I then copied the latest version of Bolt-maker.rb I had downloaded from sdmitch.blogspot.com.
                  I fired-up SketchUp 8, and clicked on Bolt-maker 7 in the menu bar. It worked! Now, I was very cautious about the parameters I set. So I stayed with the 1/4 inch bolt-size.
                  After a number of dry runs, I was finally able to confidently create a half-dozen bolts "joining" those plates. Great!
                  Now, I decided to push the limits. I clicked the Boltmaker7 (button) in the menu bar. After the dialog box appeared, I set the bolt's size to 2 inches. The plugin worked. However, when I went to repeat my thought experiment, the dialog box failed to appear, which is good, too.
                  I clicked open the Ruby Console. After I clicked the Bolt-maker7 (button), the same error appeared as it had in the lines above.
                  Sdmitch, made a good program, but needs to adjust the parameters of the bolt sizes from: Tiny to Colossal (for all you D&D fans). I think that might set it right.
                  Peace
                  • N
                    Niffler
                    Greetings All,
                    I was thinging again about a phenomenon from Bolt-Maker. What doesn't make sence to me is that if I deleted Bolt-Maker.rb from the SketchUp/Plugins folder, shutdown my computer, purged my RAM, rebooted Windows, downloaded a "new" copy Bolt-maker.rb from sdmitch.blogspot.com, then reinstalled that program into the SketchUp/Plugins folder, fired-up SketchUp 8, clicked 'Plugins' on the menu bar, then clicked Bolt-maker, you would expect it to work wouldn't you? Of course you would expect it to work?
                    Nope!
                    My question is: what the heck is happening that is telling my computer that the Bolt-maker program is still broken?
                      driven
                      Hi Niffler,
                      did you follow advice Jim gave you? http://forums.sketchucation.com/viewtopic.php?f=323&t=40172&start=15#p356486
                      I can't see that in the list of things you've tried, and it's the most likely culprit.
                      • N
                        Niffler
                        @driven said:
                        Hi Niffler,
                        I appreciate your concern Driven. However, I do not know if you are referring to the 1st challenge I had, had not loading Bolt-maker in properly or the latest 'bug' that's revealed itself. The details to that excursion are on the previous page.
                        I am sure sdmitch will be able to pull a rabbit out of his hat on this one.
                        Peace
                          driven
                          if you downloaded a new copy it may need to be modified as well, I had to change the version I have for it to function.
                          I also know Sam is away for the next ten days and may not be checking-in...
                          • N
                            Niffler
                            Alright, alright you've wound me up. What do I need to do to 'modify' Bolt-maker? It there a way to modify the program to also accept bigger numbers to prevent it from buggering-up?
                            [EDIT] Okay, I've just realized what you meant, driven. Yeah, I looked at the instructions Jim posted and have looked in a freshly downloaded copy of Bolt Maker. The change that Jim suggested had already been made, so something else is causing my error. I apologize if I appeared not to have read other's attempts to help me.
                            Also, I noticed that the instructions in the comments said that the bolt width parameter was 1.5 * maximum. Pity that I cannot get this to work with new copies of the file on my Vista system; it's as if the text file that tells the program its last setting is still there, but crafting new versions of that file with more modest parameters hasn't caused it to work there.
                            Any assistance is appreciated.
                            Peace
                            • G
                              GarryD
                              Maybe Im missing something simple. When I make, or try to make, a bolt I get to the stage where I have to orbit to see the reverse side. When I do so I cant get back to bolt maker to select the exit point...... πŸ˜•
                              • sdmitchS
                                sdmitch
                                If you are using the Orbit Tool as opposed to orbiting with the mouse wheel, press the Esc key to exit Orbit Tool.
                                • K
                                  kenS
                                  I also have the problem of bolt maker not working anymore, where it used to work fine for ages, and I must admit a great program.
                                  A few hicups with extra entities, appearing and various things I had to complete with erase and push/pull, but I was driving through 3 different shapes, and sometimes it didn't like putting bolts through the flange of a steel angle joined to 2 flats.
                                  Anyway I think that I have found the problem of the program not working.
                                  I work in mm, and somewhere along the line I changed the precision to 0.
                                  So delete the .txt file, and change the precision to at least 0.0 this then seems to work for any size bolt.
                                  • N
                                    Niffler
                                    Greetings KenS,
                                    Yes, like some plugins, it has its quarks. However, I uninstalled the plugin from the Google root directory, rebooted the system, installed a new version, fired-up SketchUp...nothing happened. It doesn't like to play in Vista, but it will work in my other system with XP.
                                    I liked this plugin for all the neat stuff I could do with it. However, my bright, sun-filled days ended when I attempted to create a five-inch, MONSTER BOLT! Seriously, that's what happened and the plugin died...forever. 😲
                                    End of the story.
                                    My question to Boltmaker's author is: what has this plugin installed onto my system that prevents the system from running any copy of Boltmaker I had previously installed?
                                    Please, please someone help me, I want to have my life back. πŸ˜’
                                    • sdmitchS
                                      sdmitch
                                      Neffler and all, Why plugin Bolt Maker tends to be flaky is as much a mystery to me as you. I can assure you that Vista is not the problem since I developed Bolt Maker on a Vista system. As to size of bolts, I have made them from 1mm to 5" diameter without a problem. There is nothing "hidden" in the plugin that prohibits any version from running regardless of how many you have installed.
                                      • N
                                        Niffler
                                        Greetings Sdmitch,
                                        "Oh happy days, oh happy days" β˜€ The sun is shinning! I downloaded your latest Boltmaker plugin into my Vista system, fired-up Sketchup, clicked-on Boltmaker and it works!! I even tried a five-inch, monster bolt and that worked.
                                        Now, for the bad news. πŸ˜•
                                        Sorry for raining down on your parade, mate. When boltmaker first opened, I was greeted with the error message:
                                        "Error occurred when reading bolt_data file." πŸ‘Ώ
                                        Sorry!
                                        • sdmitchS
                                          sdmitch
                                          neffler, The error message you mentioned is one of the things I added to the latest version. I found that while testing and changing units from inches to millimeters and back again that it caused an error on one occasion when reading the defaults from the previous run. My guess is that this read error is what was causing the plugin to not run for you previously since I had not coded for this posibility. After dismissing the message, the plugin should run normally. I added this message just so you would know that and help explain why the defaults presented might not be what you expected or last entered.
                                            Jim
                                            Wow, Sam - I just checked out your blog and you have quite a collection of plugins going on there!
                                            • 2 / 6
