    Is there a ceiling function like in excel?
    20 Posts 5 Posters 5.1k Views 5 Watching
      Jim
      my_num = 0.17578125 frac = 16.0 # 1/16th (radix, specifically) rounded_num = (my_num * frac).round / frac
      • Chris FullmerC Offline
        That can't be right, you didn't even have to make any special methods to do that 😳 πŸ˜†
        • Dan RathbunD Offline
          Dan Rathbun
          This is for measurements?
          One limitation within Sketchup, is that the precision is limited to 0.001", no matter what the model units are set to.
          So using a fractional float of 0.1875" may get rounded by Sketchup. Will it be 0.187" or 0.188" ??
          I would suggest that you decide what it will be in your 'rounding' method...
          I'm not here much anymore.
            Jim
            @Chris -Been there - just passing it along.
              Here's Jim's clever solution made into a method...
              def roundtofraction(num, frac)
                num = num.to_f
                frac = frac.to_f
                return (num * frac).round / frac
              Usage:
              my_num = 0.17578125
              my_frac = 16
              my_num=roundtofraction(my_num, my_frac)
              0.1875
              • F Offline
                Frankn
                Dude you're a genius! That is awesome!
                Thank you!!
                • F Offline
                  Frankn
                  Chris don't feel bad even after doing this thing called 'programming' for the last few weeks I'm still getting the hang of methods, classes and all that jazz!! 😳 πŸ˜†
                  • F Offline
                    Frankn
                    Yes Dan, this is for measurements.
                    I didn't know that limitation about Sketchup, interesting. But I'm not building a plane here just cabinets, vanties and that kind of thing, but I just don't like seeing that ~ and this script programming is addictive! You just keep adding on features and stuff you can do, I think I might have a problem. πŸ˜†
                    Thanks for the info
                    • F Offline
                      Frankn
                      >   num = num.to_f
                      >   frac = frac.to_f
                      > end
                      Usage:
                      my_num = 0.17578125
                      my_frac = 16
                      0.1875
                      Thanks yet again TIG! πŸ˜„
                        Yeah TIG, thanks for wrapping it into its own method, now it feels at least slightly over-engineered πŸ˜„
                          Anything to prolong the embarrassment πŸ˜‰
                            πŸ‘ πŸ˜„
                              Dan Rathbun
                              Just a note to remind all..
                              ... that now with Ruby in the 1.8.6 branch, we have both a ceil() and a floor() method defined for the Float class.
