    Dojo
    42 Posts 20 Posters 4.1k Views 20 Watching
    • soloS
      Between projects and playin' again.
      Was quick to model, texturing actually took longer than modeling. ๐Ÿ˜‰
      http://img856.imageshack.us/img856/3942/dojoj.jpg
      Rendered with Thea, used the 'Glare' option with 50% radius for godrays.
      http://img62.imageshack.us/img62/7291/dojo1resized.png
      http://img703.imageshack.us/img703/3818/dojo2resized.png
      • dereiD
        derei
        Wow, is very expressive! I can hear the silence !
        How did you achieved that "volumetric light" effect?
        DESIGNER AND ARTIST DEREI.UK
        • soloS
          Thanks,
          I wanted to use the 'medium' method in Thea but that would increase render time, I did not want to render more than 2 hours (original size 2000x)so I used the 'glare' option after render (in Thea) I believe it worked pretty well, I could use PS and add dust but thought it looks okay without it.
            Read between the images
              Pete, can you show SU textured image?
              • soloS
                Sure, As you can see I mostly used the bump maps instead of diffuse maps in SU, that way I can map easier, and in Thea I link the diffuse (little trick I use to keep model size down as bumps weight less than diffuse and easier to see for mapping)
                http://img36.imageshack.us/img36/9223/dojosu.jpg
                  Why not normals maps? I always thought they were superior.
                  Nice tip though. ๐Ÿ‘
                  • soloS
                    I usually swop out the grey scale bumps for normals in Thea for close materials, otherwise grey ones work fine (I do set the contrast higher in Thea for grey maps however)
                    I use Paintshop X4 and Pixplant2 to create all my normals, spec, displacement and bumps as well as make textures seamless if needed.
                    • Z
                      Zacchia
                      Hi Solo
                      Like it a lot!! Maybe also because I practice Karate...
                      ๐Ÿ’š
                      • pbacotP
                        Sensei!
                        • allanxA
                          allanx
                          Nice render Solo, it feels like there's gonna be a showdown of Samurai's...I love the model very clean and organized.
                          allanx
                          Portfolio
                          • L
                            lapx
                            Yea, solo . Nice work! Fantastic mastery of textures. You need some wrestlers in the scene now;)
                            How long have you been using Thea? I thought you used Vray as well?
                            • mitcorbM
                              mitcorb
                              Excellent work, Sensei ๐Ÿ‘
                                Roger
                                I can hear the click of bamboo shinai on steel face masks. And the smell a lot of sweat.
                                http://www.azcreative.com
                                • artysmediaA
                                  artysmedia
                                  I'm waiting to the fight between Neo and Morpheus! ๐Ÿ’š
                                  Great render as ever! ๐Ÿ‘
                                  Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                  Blog: Artysmedia
                                    meak
                                    beautiful atmosphere
                                    solo sensei ๐Ÿ˜„
                                    • soloS
                                      I'd say about two years if not longer, I was involved with the beta from the first beta version.
                                      I did, I never owned Vray (think struggling freelancer) but learned from the trial version and was part of beta testing also,then the beta testing changed and one needed a license to continue which I never had so that was the end of my Vray days.
                                      • michaliszissiouM
                                        michaliszissiou
                                        Excellent render-modelling peter!!!
                                        Always practical solutions, expected from you. A great lesson.
                                        • daleD
                                          dale
                                          masterfully done as per usual, and nice hints for Thea.
                                          • N
                                            nomeradona
                                            very nice athmosphere. nice render and lighting. I wish you put now some samurai characters model in artisan.. keep on playing because when you play we see the best from you.
                                            • 1 / 3
