    [REQ] time machine for layers
    2 Posts 2 Posters 357 Views 2 Watching
    • bagateloB Offline
      bagatelo
      It would be possible to create a plugin that freeze layers of components, and materials and groups in the hidden layers, making "Make Unique" in each component, something like time machine for layers? All this with just a few keyboard shortcuts?
      That would be interesting when we are modeling organic stuff and want to keep a history of these objects as backup. Or wanting to keep several lines of possibility models of architecture.
      It is also interesting when we do a lot of modifications that alter an object "A", but then we do other profound changes in other objects "B", "C", or "D", for example, and then we change your mind about the object "A". We want object A back as it was before changing objects "B", "C", "D". However, if we press keys Control Z, we will lose changes to objects "B", "C" and "D".
      Can you understand me?
      http://origin.arstechnica.com/reviews/os/mac-os-x-10-5.media/time-machine-prefs.png
      http://origin.arstechnica.com/reviews/os/mac-os-x-10-5.media/time-machine-mode.jpg
        matt.gordon320
        You could try the "Archiver" plugin that TIG produces, as I believe that it does something similar to what you're describing. I've never gotten it to work quite right, but then I haven't really invested much time into actually learning how to use it properly.
        http://forums.sketchucation.com/viewtopic.php?t=18179
        Hope that helps,
        Matt
