    Extending SketchUp entities
    16 Posts 5 Posters 2.1k Views 5 Watching
      Anton_S
      Why won't you just edit the face class and fill it with your "MyPrettyFaceClass" functions?
      Ex:
      Class Sketchup::Face #"MyPrettyFaceClass" functions end
      Did I got you right?
      • Dan RathbunD
        Dan Rathbun
        Because the API Police will haul him off to Ruby Jail !!
        I'm not here much anymore.
          Ex:
          Because it'd be the same as adding methods to the global namespace. If I add a method "foo" - it could easily be overwritten by another author who also wanted to add his pretty method foo to the Face class.
          • fredo6F
            @thomthom said:
            Is there a way to extend a Sketchup::Entity so only the reference you hold is extended?
            Example:
            ` sel = Sketchup.active_model.selection
            face = sel[0]
            face.extend( MyPrettyFaceClass )
            face.is_a?( MyPrettyFaceClass )
            true
            sel[0].is_a?( MyPrettyFaceClass )
            true`
            This is not what I want. What I'd like to do, if possible, is to extend just the reference face, and not the object it points to.
            Did I explain that clearly? πŸ˜•
            It seems to me there is no difference between the object and the reference to the object in Ruby (so sel[0] is strictly equivalent to face).
            • Dan RathbunD
              Dan Rathbun
              Yes.. extend() is supposed to do this when applied to an instance object... any instance methods in the mixin module are supposed to become singleton methods.
              @thomthom said:
              Example:
              sel = Sketchup.active_model.selection face = sel[0] face.extend( MyPrettyFaceClass ) face.is_a?( MyPrettyFaceClass )
              true
              This is weird that you did not get an TypeError exception raised. The docs indicated clearly that the argument to include() and extend() are supposed to be a mixin Module (or a list of them.)
              After you "mixin" a Class... that class becomes the superclass ? And the face is no longer a subclass of Sketchup::Face ??
              That's just not right... perhaps you found a Ruby core bug ? What version and patchlevel (and platform,) did you see this on?
              • Dan RathbunD
                Dan Rathbun
                Just for kicks...
                On PC, SU 8.0M1, Ruby v1.8.7-p299 :
                face.extend(Dan)
                %(#400000)[Error: #<TypeError: (eval):0:inextend': wrong argument type Class (expected Module)>]`
                  I meant module. I just types up a fake example.
                  Regardless, .extend on an entity will affect all scripts trying to access it.
                  • Chris FullmerC
                    What about keeping your own collection of your own special faces. I guess this is what you're trying to avoid?
                    face = sel[0]
                    MyPrettyFaces.add( face )
                    MyPrettyFaces.is_pretty?( face )
                    true`
                    • Dan RathbunD
                      Dan Rathbun
                      Now if you wish to automate this, similar to a mixin, you need to write your own "Extender" submodule within your namespace:
                      module TT;;Extender
                        def self.add_method_has_dictionary?(obj)
                          unless obj.is_a?(Sketchup;;Entity)
                            raise(TypeError,"wrong argument type #{obj.class.name} (expected Sketchup;;Entity subclass)",caller)
                          Object.instance_eval %q[
                            def obj.has_dictionary?(dict_name=nil)
                              return false unless ( dicts = self.attribute_dictionaries() )
                              dict_name = '' if dict_name.nil?
                              unless dict_name.is_a?(String)
                                raise(TypeError,"wrong argument type #{dict_name.class.name} (expected String)",caller)
                              dicts.any?{|dict| dict.name == dict_name }
                            end # def
                        end # def add_method_has_dictionary?(obj)
                      end # module TT;;Extender
                      Then to use:
                      face = sel[0] %(#400000)[>> #<Sketchup::Face:0x62c6090>] TT::Extender.add_method_has_dictionary?(face) %(#400000)[>> nil] face.respond_to?(:has_dictionary?) %(#400000)[>> true]
                      • Dan RathbunD
                        Dan Rathbun
                        Adding a singleton method to a SINGLE instance object is quite easy:
                        face.is_a?(Sketchup::Face)
                        true
                        def face.has_dictionary?(dict_name=nil)
                          raise(TypeError,"wrong argument type #{dict_name.class.name} (expected String)",caller) unless dict_name.is_a?(String)
                          @dan rathbun said:
                          ` face.respond_to?(:has_dictionary?)
                          true`
                          And if another script was to iterate over the face, would it then get a non-extended version of the face entity?
                          • Dan RathbunD
                            Dan Rathbun
                            @thomthom said:
                            true`
                            No it would get THE instance object, with all it's inherited instance methods, AND any singleton methods (including the newly attached :has_dictionary? method.)
                            UNLESS after using the method, you decided to unattach it somehow... IF Ruby allows doing that.
                            I don't think it does.. because undef_method() and remove_method() are private class methods, and are not inherited by the instances.
                            But what's the big deal? It's better than modifying the base API class, isn't it?
                            Your other option is to create yourself a mixin module, that you mixin to YOUR OWN modules, that creates private methods, such as:
                            ent_has_dictionary?(entity,dict_name)
                            • Dan RathbunD
                              Dan Rathbun
                              However .. I'm beginning to form a concept in my mind.. how perhaps scripters could create custom instance methods for any API class, without actually modifying the class... more thought and experimentation will be required.
                                If my script iterate the entities in a model and extends them with my mixin module - then I wouldn't want to affect other scripts. It'd be the same as modifying the base class.
                                • Dan RathbunD
                                  Dan Rathbun
                                  We'll yes.. if you end up defining a new singleton method for EVERY Sketchup::Entity subclass instance in the model(s), then it would be comparable to extending all the classes themselves.
                                  Also.. a singleton method, is in effect, a single instance override of any inherited method of the same name, so (referring to my previous example,) if Google later ended up adding a :has_dictionary? method to the API Sketchup::Entity superclass, my example would be overriding that method, on an individual instance basis.
