    How to Connect Ruby to MySQL
    12 Posts 5 Posters 2.4k Views 5 Watching
    • H Offline
      hchitrakar
      I tried to connect Ruby to MySQL following the instructions of this link, http://www.tutorialspoint.com/ruby/ruby_database_access.htm.
      But, I could not go beyond installation. Whenever I tried to run the script which is the following:
      %(#800000)[#!/usr/bin/ruby -w
      require "dbi"
      begin
      # connect to the MySQL server
      dbh = DBI.connect("DBI:Mysql:TESTDB:localhost",
      "testuser", "test123")
      # get server version string and display it
      row = dbh.select_one("SELECT VERSION()")
      puts "Server version: " + row[0]
      rescue DBI::DatabaseError => e
      puts "An error occurred"
      puts "Error code: #{e.err}"
      puts "Error message: #{e.errstr}"
      ensure
      # disconnect from server
      dbh.disconnect if dbh
      end]
      It says 'warning:mismatch indentations, no file to load and many more.........'.
      Can anyone help me with this problem? My computer has windows7 as OS.
      Thanks.
      • Dan RathbunD Offline
        Dan Rathbun
        @hchitrakar said:
        #!/usr/bin/ruby -w
        1) ... this is the "shebang" for a Unix-like Ruby install. Windows does not "read a file's first line, then decide what program to use for the file."
        Windows uses file associations... and on Windows, most developers prefer to associate their "rb" files with the editor that they use to program with.
        2) Do you even have a FULL Ruby installation on your computer ?? (Microsoft would NEVER distro their OS, with an Open Source scripting language that they didn't invent (or have a large part in the development of... the brats!)
        If not.. and your on Sketchup v8+
        Ruby Binary Installer:
        • Ruby (v1.8.6-p287) Windows One-Click Installer
        3) Get my !loadpaths.rb script, and either use it... or a condensed version of what it does to push the Ruby lib paths into the $LOAD_PATH array.
        THEN ... you'll be ready to use standard libs to connect to a database...
        I'm not here much anymore.
        • H Offline
          hchitrakar
          Can you show me how to extract tables of MySQL in Ruby?
          • TIGT Online
            hchitrakar !
            You just "reported" the last post!
            I don't think you meant to do that - please use the Reply button.
            πŸ˜’
              Dan Rathbun
              FYI : It may be more to your benefit, to ask basic / standard Ruby questions, or how to deal with extended Ruby libraries, in one of the "normal" Ruby forums.
              Ruby-Forum
              Online Community that helps beginners learn Ruby, and coders solve Ruby coding problems since 2005
              Ruby-Forum (www.ruby-forum.com)
              You can also do a search first to see if your question has already been asked (and most likely it has.) Replies often have code samples included.
                Dan Rathbun
                NO.. sorry.
                I have no idea which dB interface library that you will choose !!
                You will need to read the instructions or study the methods of the library that you choose to use.
                If the Ruby standard libraries do not have what you want, you may need to use a 3rd party library gem.. so check rubygems.org
                And you will need to know and understand Ruby first...
                see: Ruby Newbie's Guide to Getting Started
                  Jim
                  Is this for a personal project, free plugin, commercial plugin? If you use extra libraries, do you plan on distributing them with the plugin?
                  They way I would do it is to use a WebDialog to communicate with the database through php scripts on the server, but this may not be applicable to your requirements.
                    Dan Rathbun
                    @jim said:
                    The way I would do it is to use a WebDialog to communicate with the database ...
                    Windows is distro'd with the TDC.ocx (Tabular Data Control Active-X extension,) that can link to dB tables and CSV files, etc. A change in the data is immediately seen in the webpage element so linked.
                    About Microsoft Tabular Data Control
                      Jim
                      That's really interesting, Dan. It deserves a more in-depth look into the potential.
                        Dan Rathbun
                        Here's an example page, that lists HTML colors. Click on any column heading, and the table resorts by that column. (One of the most useful features of dynamic HTML tables using the TDC.)
                        Dynamic Color Reference
                        One drawback, is that it's deprecated beginning with IE9... But, Sketchup is using the WebBroswer control that runs in EmulateIE7 mode by default. So it should work as long as the user has the **tdc.ocx** file on their computer. (It's located in "C:\WINDOWS\system32" on XP.)
                        And then you can also force the browser mode via a META tag:
                        %(#8000BF)[<META http-equiv="X-UA-Compatible" content="IE=7" > <!-- can be: IE=5,IE=7,IE=EmulateIE7,IE=8,IE=EmulateIE8,IE=9 -->]
                        .. just in case they change the default mode, in the future.
                        Refering to: META Tags and Locking in Future Compatibility
                        By default, Internet Explorer 8 uses EmulateIE8 mode to display pages loaded from the Internet Zone. Web pages loaded from the Intranet Zone or with the Web Browser control are displayed in EmulateIE7 mode. These defaults can be changed.
                        and ...
                        EmulateIE7 mode tells Windows Internet Explorer to use the <!DOCTYPE> directive to determine how to render content. Standards mode directives are displayed in Internet Explorer 7 Standards mode, and Quirks mode directives are displayed in IE5 mode. Unlike IE7 mode, EmulateIE7 mode respects the <!DOCTYPE> directive.
                        If Microsoft had just released a cross-platform cross-browser version, it wouldn't need to be deprecated. (Perhaps someone else in the OpenSource community has??)
                        It would be nice if we had compatible TDC controls for both Trident and WebKit. Oh wait a min... I actually just loaded that sample page in Chrome, and it works fine !!
                        I'd like to know what happens on a Mac, in Safari, when that page is loaded...
                        • tbdT Offline
                          tbd
                          Dynamic Color Reference works perfectly as it uses plain javascript.
                          Examples that use TDC will not work as .ocx is windows only.
                          http://plugins.ro
                            Dan Rathbun
                            Thanks Tavi.. dang it.. dat's a bummer... oh well then it's SQLite3
