    Changing View with Ruby
    9 Posts 4 Posters 319 Views 4 Watching
      tomot
      I want to create some 2D section rubies, which require either a front/back or right/left orientation
      to be set at the time the ruby is run. How do I incorporate the correct statement?
      Sketchup.send_action(CMD_VIEW_RIGHT).....does not work!
      Sketchup.send_action(viewFront) .....does not work!
      Sketchup.send_action(viewFront:).....does not work!
      Help!
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        Jim
        tomot - use a String (quotes)
        Sketchup.send_action("viewFront:")
          Note as the API doc says... the enclosing "..." AND a terminating ':'
          Sketchup.send_action(****"****viewFront****:"****)
          • Dan RathbunD Offline
            Dan Rathbun
            tomot.. are you on a Mac?
            (It would help if you put your OS and Sketchup version into your profile, so it's displayed beneath your name on every post.)
            This thread belongs in the Developers forum.
            I'm not here much anymore.
              I'll move it...
              EDIT: Moved!
                tomot
                Done!
                tomot
                  tomot
                  Is there a reason why the following Sketchup.send_action("viewFront:") code will work only under def initialize ?
                  def initialize
                       (some code and dialog boxes)
                    if( $view == "Front" )
                      Sketchup.send_action("viewFront;")
                      $orient = Geom;;Vector3d.new(0,1,0)
                      $normal = Geom;;Vector3d.new(0,1,0)
                    end #if
                  end #end initialize
                  But using Sketchup.send_action("viewFront:") code under def create_geometry(p1, p2, view) will not work....why?
                  def initialize
                  end #end initialize
                    end #if
                  end #end create_geometry
                  tomot
                    Dan Rathbun
                    Well, first of all, what kind of class are you writing ?? A Sketchup::Tool class or just a generic class (a subclass of Class?)
                    Secondly... your breaking a cardinal rule of global variables. DO NOT create them only for use by one single plugin, or for only YOUR own use.
                    Create either Constants, or Module or Class variables, within YOUR namespaces. (That way they will not conflict with other sloppy scripts that are using globals of the same name.)
                    Thirdly... when you write a class... and create an instance of that class, your class's constructor method, usually named new(), automatically calls the initialize() method WITHIN the newly created instance.
                    This is why you get an automatic change in the view to "Front", when you make a new instance of your class in the first example, and not in the second.
                      tomot
                      My bad! I only use global variables to confirm values in the Ruby console, If the console could evaluate @ variables I would never, never ever use $ variables.
                      tomot
