    Model this: tennis ball
    21 Posts 6 Posters 4.9k Views 6 Watching
    • soloS
      Ah, you used instancing, cool. how many poly's?
      • ely862meE
        ely862me
        I try not to use artisan or other plugins unless necessary(usually they are much more complicated than native tools ) .
        Here i smoothed it a bit in artisan.
        Elisei (sketchupper)
        Come and See EliseiDesign
          For the fur? 128,000 I think
          The fur was an 8 sided tapered cylinder bent with FredoScale resulting in 64 faces. Then instancing in Thea. I'll be honest it was my first attempt at this and if I show the output now I'd need to delete my account here πŸ˜„
          • soloS
            Rich, I decided to challenge SU, and make the hairs using the fur plugin.
            Brought SU to it's knees, so slow that even trying to access menus took long.
            This is just crazy, I'm gonna try export to Thea now.
            • soloS
              That was pretty fast, imported in less than 20 seconds, one minute to set up and 5 minute render.
              http://img40.imageshack.us/img40/4268/tennisthea1.jpg
                πŸ‘
                How did you do logo?
                • soloS
                  :thumb:
                  Intersected the extruded text with model, then put a different color fur on those selected faces and another color on the rest of ball, in Thea I made the fur on the solo faces dark grey/black and the other yellowish green.
                    driven
                    geodesic, intersect with cubiod, TOS [offset], JPP, SU concrete and grass [under translucent lime copy upscaled 1.001]
                    • TaffGochT
                      TaffGoch
                      Β
                      As usual, I probably engaged in over-thinking the geometry. I don't have a tennis ball in front of me, but images online depict arcs that are not parallel.
                      If the diametrically-opposed arcs are NOT parallel (but are angled, as in a baseball,) then the intersection geometry needs a slight adjustment.
                      My SketchUp modeling demonstrates how I would build the two options. I originally worked this out while trying to model a baseball, a couple of years ago.
                      -Taff
                      "Information is not knowledge." -- Albert Einstein
                        driven
                        http://www.pennracquet.com/sites/usenglish/index.html
                        if you really want to know how one is made...
                        • I
                          Ignis
                          Hello everyone. This is my first post here on the forum. I saw this challenge and decided to give it a shot. I think it's a really good challenge that seems simple but in reality can be a bit difficult to accomplish. I think I came up with a really good way to do it that is simple and quick. Hope you all like it. After a few attempts, I realized that the curve around the ball has a certain symmetry to it and can be divided into 8 equal parts. My process is based on that idea. Here we go!
                          First I made a sphere, and erased all but 1/8 of it. I made that section into a component. I then copied and flipped that component to reassemble the sphere. Next, I rotated 1/2 of the sphere 90 degrees.
                          I then opened one of the components and drew the curved line freehand on the surface. I began at the point marked with the red dot. This point is the center point of this arc.
                          After tweaking the line by eye to make sure it flowed smoothly around the ball, I offset the line twice on each side. I attempted to use the "offset on surface" plugin, but it produced unfavorable results, so again I did this freehand.
                          At this point, I exploded all of the components and smoothed the lines where they connected.
                          After scaling the recessed white line a bit to add some dimension, I continued to add materials and soften all remaining edges.
