    DC instance make unique
    22 Posts 3 Posters 2.1k Views 3 Watching
      You could scale instances of any component using a [random] transformation ?
      I'm still not clear what you are trying to do with this.
      If you look at AutoCAD concrete hatching it is NOT random.
      It is a 'tiled' set of random looking line patterns, so why not make a big tile-able concrete-hatching component of edges, add it and then repeat it X/Y and then explode all, intersect t with a face, then trim to remove unwanted edges and finally remove all residual faces ?
      there are no CAD PATTs that are random they all tile, some just have a bigger 'repeat' to fool you... πŸ˜’
      • jolranJ
        jolran
        Gulp 😲 I did not think of making them only tileable. I'm a disaster...
        I was stuck in my mind thinking of DC to do it all.
        OK so from this on, if things go better. Step 1 make "manual" stamp tool. Step 2 "inbuilt" library, like your 2dtools hatches. So the rule here IF the user wants to make own patterns, is NO subcomponents?
        I don't think it's a good idea to ditch the manual stamp tool idea. That could be useful as well, for precision.
        Alright, will try what you say. Thanks TIG for putting me on the right track. πŸ‘
        • jolranJ
          jolran
          Ehum, actually the problems remain using non nested components. If I tile components there are multiple, no?
          The problem was exploding nested components. Now it is exploding multiple components.
          If I put the components inside a group and explode the group.entities(iterate) only 1 component get's exploded.
          I get constant splats following advice on this page. http://forums.sketchucation.com/viewtopic.php?f=180&t=38925&p=343823&hilit=group+from+selection#p343823
          This is what I do: (first I iterate through selection and add to arrays: faces[], edges[], componentinstances[])
          Then
          #comps=array of componentinstances
          	      gp2=ents.add_group(comps)
                    cents=gp2.entities
                     cents.each{|e|   # does NOT like gp2.to_a CRASH!
          	      next if not e.valid?
          		  e.explode if e.class==Sketchup;;ComponentInstance
          Probably doing some fundamential misstake, but cannot find any relevant info about this particular problem..
          I can only imagine it has to do with the fact that I am adding several components to the group.
          OR maybe it doesent work to run instances through an iterator? The iterator think's the instances are the same object? BUG?
          That makes no sence though... πŸ˜•
          • jolranJ
            jolran
            I got it. Stupid missunderstanding. 😍
            If comps is an array of entities I add to the group. It's THEM I should explode. Not give the group entities a new name and
            try to explode that object.
            	if comps
                      comps.each{|e|   # does NOT like gp2.to_a CRASH!
            It's funny I always find the solution 1 min after typing it on this forum.
              Never use ents.add_group() with amy objects within the ()... UNLESS ' ents' is the active_entities.
              If it's not then you must add objects to the ents AFTER creating the group as an 'empty group ()'...
              • jolranJ
                jolran
                Ok, thanks for reminding me. It even say so in the API, groups should not be created that way.
                But I don't know how to do otherwise, if not creating some new entities..
                So how do I do it in this case. gp2=ents.add_group(). How do I add comps to gp2? comps=gp2.entities will not work will it?
                  gp=ents.add_group()
                  assuming comp1 is a component-instance
                  comp2=gp.entities.add_instance(comp1.definition, comp.transformation)
                  comp1.erase! so it's 'moved' into the group.
                  OR if it's just a definition and you have a transformation called 'tr'...
                  comp=gp.entities.add_instance(definition, tr)
                  IF it's s group it's slightly more convoluted to move it into a group that's not in the active_entities...
                  gp=ents.add_group()
                  gp2=gp.entities.add_instance(gp1.entities.parent, gp.transformation)
                  gp1.erase!
                  gp1=gp2
                  you have effectively moved gp1 into gp...
                  • jolranJ
                    jolran
                    Thank's a lot TIG! This is new to me and very useful. This only work's with 1 object, no? But I might have multiple components in an array. I will investigate..
                    Strange I haven't picked this up earlier, been reading this forum very much lately. There is so much to learn...
                    • jolranJ
                      jolran
                      This did the trick! I mean created multiple instances inside group.
                      if comps
                      		    cents=gp2.entities
                                   comps.each{|e|
                      	         cents.add_instance(e.definition, e.transformation)
                      	        cents.each{|e|
                      	        #if e.class==Sketchup;;ComponentInstance #obselete?
                                  e.explode
                      Edited: Aahh heck... Faced with the same problem again. Can only explode 1 instance in the group..
                      And if I explode the group gp2.explode it crashes. Added the change to the snippets..
                      • jolranJ
                        jolran
                        Yeyy! Now I have exploded all instances inside the group. Changed from cents.each to cents.to_a.each
                        I know about that method. Stupid did not think about doing that earlier...
                        Main thing here. Working with instances it is important to get them exploded?
                        Even if I added 2 instances to gp .Exploded 1 of the instances. Then made a group copy like gp1=gp.copy.
                        I got splats erasing first group called gp.
                        Now when every entities is exploded, I can remove the original group safely after copying it.
                          Stop iterating entities collections that you will be changing during the iteration !
                          Fix the list with entities.to_a then all is well even when you explode/erase or otherwise change things... πŸ˜„
                          • jolranJ
                            jolran
                            Yes πŸ˜„
                            Anyway. Now it's possible to collect edges, faces even materials etc. Nice!
                            • Dan RathbunD
                              Dan Rathbun
                              @tig said:
                              If it's a DC whenever you add an instance of it it's already made unique! It's a DC thing.
                              This is not true in manual mode. Adding another instance from the Components dialog, does just that.
                              Afterward... editing one of then, edits them all.
                              So.. NEW Question:
                              I do not see a dedicated boolean API method to test a Group or ComponentInstance for uniqueness.
                              I suppose it would be ...
                              obj.definition.instances==0
                              for a ComponentInstance
                              .. and for a Group:
                              model.definitions.any?{|d| d.group? && d.instances.length==0 && d.instances.include?(obj) }
                              I wonder if any of us would like a way to always force a definition to clone itself, so that all instances are always unique.
                              maybe a force_unique attribute?
                              I'm not here much anymore.
                              • jolranJ
                                jolran
                                Interesting reading.
                                That confuses me how groups work in SU. It feels like they are Component "light", where they logically(in my head) should only be a group of geometry, and not more than that.
                                I guess uniqueness has an importance when working with nested DC's. Sometimes find them hard to explode.
                                • Dan RathbunD
                                  Dan Rathbun
                                  Sometimes I confuse myself, as well.
                                  ](http://code.google.com/apis/sketchup/docs/ourdoc/group.html)":1yyw26bz]Groups in SketchUp are very similar to Components, except that there is no instancing of groups. That means that you always will have one and only one of each of your groups.
                                  Now that's not correct.
                                  1. Take an empty model. (It helps to purge the "person" component.)
                                  2. Draw a cube, and group it.
                                  3. Then select it, and choose "Copy" from the Edit menu.
                                  4. Then select Paste from the edit menu, and put the copy somewhere.
                                  5. Do it again, so there are 3 of them.
                                    Then in the console:
                                    d = Sketchup.active_model.definitions d[0]
                                  #Sketchup::ComponentDefinition:0x6227580
                                  d[0].group?
                                  true
                                  puts d[0].instances
                                  #Sketchup::Group:0x62487bc
                                  #Sketchup::Group:0x62487a8
                                  #Sketchup::Group:0x6248794
                                  Of course, they share the same primitives...
                                  g = d[0].instances g[0].entities.to_a == g[1].entities.to_a
                                  true
                                  @jolran said:
                                  It feels like they are Component "light", where they logically (in my head) should only be a group of geometry, and not more than that.
                                  Your on the correct track ....
                                  ](http://code.google.com/apis/sketchup/docs/ourdoc/group.html)":1yyw26bz](In the actual implementation, SketchUp keeps track of groups as a special kind of Component that combines properties of definitions and instances, ...
                                  If you compare the method lists, between Group and ComponentInstance, you'll see they have nearly the same methods.
                                  The difference? A Group cannot be saved out to a file (directly) for use in other models, and it's easier to get at a ComponentInstance's definition, because there's an API method for it.
                                  • jolranJ
                                    jolran
                                    That's all very interesting, and probably quite important for us new to Sketchup Ruby to understand how groups and components works.
                                    I was wondering about behaviors? I noticed that if you have a face, draw a square on it and 3pl click to select. Then make a group out of that, it will behave like a cutting component onto that face. You can even unglue it if you rightclick.
                                    However there is no "glue_to" method for groups in the API.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Right.. and you should not use a Group, for the job of a ComponentInstance.
                                      Groups are best used for temporary editing both manual and in scripting.
                                      By collecting objects together into a Group, you can:
                                      • move them from one edit context to another,
                                      • protect them from being modified by crossing edges,
                                      • apply a tranform to a set of objects all at once (where they move, scale or rotate all together.)
                                      I would say, that when you get a "set" of objects the way you want, and then wish to use that set multiple places in the model, it's best to then convert them into a ComponentInstance. Especially if your going use scripting, to manipulate them, or glue them to faces.
