    Groups
    15 Posts 3 Posters 878 Views 3 Watching
    • sdmitchS
      sdmitch
      I did it like this
      step=ent.add_group; sent=step.entities; step.name="Steps"
      rail=ent.add_group; rent=rail.entities; rail.name="Rails"
      face=sent.add_face(p1,p2,p3,p4)
         line=rent.add_line(p4,p5)
      The "Steps" appears, "Rails" do not.
      http://sdmitch.blogspot.com/
        Looks OK...
        Are p4 and p5 valid [different] points ?
        Any newly made group will vanish after a model.commit_operation IF it's 'empty'...
        Do you get any error messages in the Ruby Console??
        • sdmitchS
          sdmitch
          No, no error messages of any kind in the Ruby console. Yes, p4 and p5 are valid points. The adding of the groups was the last thing I was attemping to do after numerous successful runs of the plugin.
            The face adds OK to one group, add the same face to the other using the same points.
            Then you must [?] have both groups albeit that they are on top of each other afterwards...
            Are you sure there are no typos in the actual code ??
            πŸ˜•
            • sdmitchS
              sdmitch
              I copied the code directly from the plugin to my previous response. I add a puts statement and it did show the rail.entites variable rent was empty so I change the statements to add those entities into the step.entities variable sent and everything was there.
              • sdmitchS
                sdmitch
                If I use rail.entities.add_line instead of rent.add_line, I get the error message
                Error: #<TypeError: reference to deleted Group>
                  Make the groups in turn [i.e. not at the same time] and add new geometry to their entities immediately after you make them.
                  See if that helps.
                  I assume you aren't erasing a group in your broader code ??
                  • sdmitchS
                    sdmitch
                    I tried making and re-makeing the groups but didn't have any success with that either. The entities are being created in a loop which complicates things. I finally gave up on the two group idea. It seems apparent that SU doesn't like dealing with more than one group at a time.
                    • Dan RathbunD
                      Dan Rathbun
                      Create and hold refs to the groups and their entities collection OUTSIDE the loop.
                      I'm not here much anymore.
                      • sdmitchS
                        sdmitch
                        Dan, The groups were created outside the loop originally and the entities added inside the loop. All seemed well since there were no errors shown in the ruby console but, dispite adding entities to the second group, they weren't added to to model only the entities added to the first group. I have tested this independently and it works without a problem so was just something weird going on that particular plugin I guess.
                          You can readily make multiple groups and add stuff to any of their entities.
                          Even new groups inside new groups!
                          But if you make a new group in a sub-process and then ignore [i.e. leave it empty] it it will vanish when you leave the sub-process...
                          So just make these groups 'as you need them' and add stuff to their entities early on so that they then subsist...
                          πŸ˜’
                          • sdmitchS
                            sdmitch
                            I renamed the groups steps and rails instead of step and rail thinking that Ruby was confused by step since that is a loop method but it wasn't until I added something to the second group,rails, first that all was right with the world at least as far as this plugin is concerned. I had copied the original loop code into the Ruby Web Console and it ran without modification. It would be interesting to know why.
                              Please don't reuse references or confuse them with methods etc - coding is complicated enough as it is πŸ˜‰
                              I suggest you prefix new groups with a single meaningful letter, and suffix their entities with 'ents'
                              So 'sgroup' > 'sents' and 'rgroup' > 'rents' etc.
                              Then any other reference to 'step' or 'rail' will pass without incident...
                              And you can easily spot the relationship of s=step and r=rail πŸ’­
                              For example, I always call my temporary group 'tgroup' and its entities 'tents'.
