    [Plugin] Ruby Console Pro #2
    12 Posts 5 Posters 9.7k Views 5 Watching
    • Chris FullmerC Offline
      Hey, I like the looks of thei Martin. I have used Jim's plugin devoutly for a long time (since my first days programming for SU). I can't do without a multi-line editor. I've used Alex's a bit, but I dnot like some of the things it does (specifically wraps everything into a single undo - I want to control that on my own!).
      Anyhow, this looks great. I like the F-keys macros. I would use that a lot I'm sure.
      I'll be looking forward to this release, thanks!
        MartinRinehart
        Bug: NameError:
        If you Save or Load, then Cancel, you get a NameError and the Save/Load terminates. That's exactly what you wanted when you clicked Cancel, so this one's harmless. Will be fixed next time I UL the file. For now, ignore it.
          MartinRinehart
          Updated 5/21. New file in original post.
            ok, I'm finally getting this installed and I'm using it. Or well, I've used it for about 15 minutes. first impressions are that I like it in general. I keep hitting the init button instead of the exec button. So it might be nice to have a larger exec button, and maybe not placed right next to the init button.
            I am also not sure that I like that 'enter' executes the code. I generally never want my code to execute until I'm redy to hit the execute button. Perhaps <ctrl>+<enter> could be execute. That might be nice.
            I am still undecided on that output screen. I thinik I like it though. I have not used it enough to really know what I think. But I do like how it shows the returned info from each line of code. That is kind of handy.
            So far so good Martin,
              hmm, also it seems to kick out errors for any "end" statement:
              end # #<SyntaxError: (eval):1:inprocess': compile error\n(eval):1: syntax error>`
              • Dan RathbunD Offline
                Dan Rathbun
                Is this 'plugin' still valid ?
                .. or is it superceded by the one in the Plugins forum?
                [Plugin] Ruby Console Pro with SketchTalk in Motion++
                .. or does one use THIS edition if they do not care for the 'SketchTalk in Motion++' features ??
                I'm not here much anymore.
                  Jim
                  Hey Dan, didn't you say you were working on a webdialog console, too? How's that coming?
                    Dan Rathbun
                    Many of my ideas were implemented by Alex. I was working instead on a Win32 native version. I may switch to writing it in C or C++ as I want to do some things using MFC objects, such as docking the toolbar inside the console window (currently it follows the window and "snaps" itself to the upper left corner.)
                    I have the font handling working OK (need to fix the height sizing a bit to account for different dot pitches.) I can switch between the Google OEM font (Courier New), "Normal" user font, and a "Custom" user font (for say a large bold font used only for classroom lecture, as an example.)
                    I have the "memory" location working (and solved the issue when then user closes the console with the "X" button,) as well as 3 custom locations the user can set by double-clicking on a numbered button.
                    Looks like this, except I added a timed reload button (a gem with a clock,) after the reload button (the one with the double load arrows.)
                    • jolranJ Offline
                      jolran
                      That looks good, Martin and Dan. Thumbs up for all developpers of these kind of tools.
                      If I would could wish for 1 feature that is missing(or I have overlooked) in all these editors, is the capability
                      to fold methods or conditionals etc. When getting longer scripts that helps a lot.
                      But having longer scripts is maybe not what these "inside Sketchup" code editors was created for, so just a thought of mine.
                        Dan Rathbun
                        A console and an editor are two different things.
                        I'm on Windows, and I suggest using NotePad++, it has block folding.
                        • jolranJ Offline
                          jolran
                          Ok, I see.. I do use notepad ++ as well. To be more precise then, my wish was for folding methods in console.
                          But I get your point.
