    Strange result of a substraction
    14 Posts 5 Posters 562 Views 5 Watching
      macgile
      Hi all
      i tryed this code:
      a = 9.0
      b = -1.8
      a += b
      puts a  # => 7.2 good
      a += b
      puts a  # => 5.4 good
      a += b
      puts a  # => 3.6 good
      a += b
      puts a  # => 1.8 good
      a += b
      puts a  # => 4.44089209850063e-016 BAD RESULT !!!!
      you had an explanation for this strange result?
      regard
      • voljankoV Offline
        voljanko
        This is almost zero 😄
        It is always a risk when you use floats, in all languages.You should never compare float == float if you don't want problems.
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
          macgile
          i dont compare anything !!!
          i have tested with a = a + b the result is same
            Jim
            Much has been written about floating point errors.
            Basically, floating point numbers can not be accurately represented in binary.
            • Dan RathbunD Offline
              Dan Rathbun
              That is because the Ruby interpreter converts
              a += b
              to
              a = a + b
              before the expression is evaluated.
              I'm not here much anymore.
              • voljankoV Offline
                voljanko
                I just meant that is always good to avoid considering floats as exact numbers.
                  macgile
                  a += b
                  to
                  a = a + b
                  i dont understand your explanation Dan !!!!
                    macgile
                    oh yes 😄
                    I thought the result would be near to 0 and not of 4.
                    • voljankoV Offline
                      voljanko
                      Try to add some number,you will see that is zero and not 4.
                        Dan Rathbun
                        A singleton method to increment a float a, by an argument arg, to dec number of decimal places. (It defaults to 1 decimal place.)
                        a = 9.0
                        def a.incr( arg = 1.0, dec = 1 )
                          dec = dec.to_i
                          arg = round( arg.to_f * 10**dec  )
                          # self is object a
                          temp =( round( self * 10**dec ) + arg ).to_f
                          self =( temp / 10**dec )
                        use it like:
                        a = 9.0 b = -1.8 a.incr(b)
                          Jim
                          macguile,
                          The e-016 at the end of the number means to move the decimal place 16 places to the left - making the actual number:
                          0.0000000000000000444089209850063
                          or very nearly zero. The reason the result is not exactly zero is due to floating point errors as linked above.
                            macgile
                            a = 9.0
                            >   dec = dec.to_i
                            >   # self is object a
                            > end
                            use it like:
                            THANK for this solution Dan
                            Best Regard 😄
                              macgile
                              @jim said:
                              macguile,
                              thank i nderstand now 😄
                              regard
                                The Floating-Point Guide - What Every Programmer Should Know About Floating-Point Arithmetic
                                Aims to provide both short and simple answers to the common recurring questions of novice programmers about floating-point numbers not 'adding up' correctly, and more in-depth information about how IEEE 754 floats work, when and how to use them correctly, and what to use instead when they are not appropriate.
                                (floating-point-gui.de)
