    [Plugin] Milling Tools
    31 Posts 10 Posters 43.7k Views 10 Watching
      Update:
      • Better internal processing of existing fillets.
      • O Offline
        outland86
        Hey Thomthom
        this is looking really good right on track for milling tools for use with sketchup
        can you email me as i would like to talk with you about a really cool project i am working on that may interest you
        info@makecnc.com
        thanks
        keep up the great work!
        Join the Evolution !
          A new task! โ˜€
          • O Offline
            outland86
            is there no more development for this plugin ?
              I've been ill for more than a week. ๐Ÿ˜• All work has been halted.
              • O Offline
                outland86
                oh sorry
                hope you get well soon
                  I've pretty much recovered - but I now got a bit of backlog of work to do. I'll get back to this plugin - just need to catch up.
                  • dereiD Offline
                    derei
                    this plugin has a lot of use! please continue development.
                    thanks ๐Ÿ˜„ ๐Ÿ‘
                    DESIGNER AND ARTIST DEREI.UK
                    • mitcorbM Offline
                      mitcorb
                      Just out of curiosity, is this in any way related to Fredo6's Bezier tools added polyline tools for dogbone and t-bone polylines? And was work discontinued for that reason?
                        The tools where done in parallel - initiated by a request here at the forum.
                        I simply haven't had time to work on this. Since I don't do CNC work myself it'd ended up as low priority.
                        • mitcorbM Offline
                          mitcorb
                          I don't do CNC work either. I was just thinking maybe Fredo's feature could fill a temporary need? They are obviously different approaches.
                          • dereiD Offline
                            derei
                            I encounter problems with this model. I also tried on a simple rectangle and I get strange results. Maybe I don't know how to use it?
                            It would be useful to get the actual contour line and this plugin to create a path (inner/centered/outer) on how the milling head will perform. In the first post, I've seen some images that illustrate exactly this, but my results were bad.
                            • I don't know why "Milling result.png" is not shown ๐Ÿ˜ž
                            This is worse :(
                            the skp file for headboard.
                              In your attached model, there are errors listed in the Ruby Console. The plugin has not been tested on such complex and curved shapes.
                              You would like the path you see in the preview as actual geometry?
                                This model if yours has revealed several issues with this plugin... ๐Ÿ˜•
                                • dereiD Offline
                                  derei
                                  I would like to draw the actual geometry in Sketchup, but the plugin to alter my edges (offset/inset or leave them unaltered, just fillet corners). Because the milling bit can perform on the left, on the right or on the center of the line.
                                  This plugin could be a very powerful one in the future... (offtopic: Now I have some problems with DXF export from SketchUp and importing in CNC software. Some line elements (especially arcs) are mirrored outside of board perimeter). Maybe AutoCAD and SketchUp export DXF in different manners.)
                                  • dereiD Offline
                                    derei
                                    It's my model...actually is something I do now. The curves have a lot of segments because it will be sent to CNC and I have some problems with arcs in DXF export. Polylines are ok, but if there are less segments, it will reflect in manufactured piece.
                                      I'm thinking that there might be a need of a tolerance limit. If the angle between two edges are within a range close to co-linear it should skip the corner...
                                      • dereiD Offline
                                        derei
                                        Maybe this as a option... because if I set that o CNC, it will make a tangent radius between that two edges in the pieces (radius equal with tool radius). So, if I want that result, to be able to obtain it.
                                          Trying to track down the various issues.
                                          One that I see is that the orientation of the face normal matters. When I flipped the face it was behaving more as expected. but there where still various issues.
                                          • dereiD Offline
                                            derei
                                            Indeed, I would never think on that. Beside Dog-Bone fillet, you could add option for regular rounding. dog-bone is used mainly on metal sheets, to avoid fracturing on cut out corner. But, if I need to carve a piece from a sheet of material (see my headboard), that dog-bone effect is not good. Instead, what is needed is a offset with filleted corners.
