    Reverse face and uv
    3 Posts 2 Posters 419 Views 2 Watching
    • G
      giuseppe500
      Hello.
      I'm creating a sketchup importer in c++ and opengl.
      I have a problem with th UV mapping.
      I see that in sketchup the uvs can be positive or negative , and if i reverse a face the UV changes , but is not only inverted the sign , whats changes and how i can import it in opengl system UV.
      • G
        giuseppe500
        I don't have really clear what are the difference between faces and reversed faces, so in my importer i use an atlas and I calculate the new uv with an
        newU = abs(U) * scaleMatrixU + offsetU;
        newV = abs(V) * scaleMatrixV + offsetV;
        and this in non reversed face seems correct , the problem is when i have a reverse face , the texture UV are wrong .
        if i don't use the abs the UV are wrong at all both in reversed that in non reversed faces.
        But what mean a negative U or a negative V in sketchup?
        is a form of tile or wrap?
        I not understand
        thanks.
          This really is a very basic concept about face orientation... πŸ˜’
          Most exported and 3rd party renderers assume that the part of the face you want to render is the front of that face, with its applied mamterial [if any].
          IF you have a sloppily made model where some faces are the wrong way round - so the back of the face is visible [when most sane people would expect to see the front face] - then it might well look OK in the SKP - Sketchup is quite forgiving... BUT most 3rd party tools will ignore that face's back material completely and simply give it a default material like all of the other back faces which are [usually] unseen [often white/black depending on the app]... and then render the face's front with whatever material it might have [which is then 'unseen'!!!]
          You need to give your SKP and other app's a chance and model appropriately - not sloppily!!!
          You should never need to consider a face's back_material IF your model has been made properly. If you have a thin object - like a glazed-window-pane - then it should have two skins [faces], each of which should face out so you never have to see or consider the 'back_material'... πŸ˜’
