    Organic modeling from photos?
    Scheduled Pinned Locked Moved Organic Modelling
    35 Posts 14 Posters 26.6k Views 14 Watching
      8-perf
      Hello-
      New guy here. This is my first post actually. Just wondering where this rock is located. If its famous enough, there mught already be some 3D data available on it, in the form of DEM data, survey work, or even some simple "terrain" image from Google Earth itself. You might also be able to work it out with enough images using Photomatch. Start off with a square "blocky" version and then refine it later. Just a thought. Good luck with it.
      8-Perf
      • L
        linea
        Looking at that rock, it is quite angular anyway. Give photomatch a go.
        • I
          idraft
          You could give this a try
          http://www.pixdim.com/content/view/120/55/lang,en/
          In beta testing I think, but if not available maybe you could ask them to do it for you, as a promo thing??
          http://www.acvt.com.au/research/videotrace/
          • X
            xrok1
            are you volunteering to climb the rock with 50 stickers? ๐Ÿ˜†
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • L
              layziefj
              You could try this:
              BunnyCDN Node PHX1-1155
              (www.photomodeler.com)
              • N
                notareal
                After reading this I did remember this
                http://make3d.stanford.edu/
                  ding851211
                  good~~~~
                    Aerilius
                    Many Thanks!, it has been solvedlong ago:
                    http://forums.sketchucation.com/viewtopic.php?f=18&t=18244&hilit=+organic
                    I didn't find a better solution than modeling it by hand, until it fits from every perspective to the outlines of the photos. My favorite alternative was the following:
                    Arc3D http://homes.esat.kuleuven.be/~visit3d/webservice/v2/
                    Creates automatically models from many photos. Seems to be promissing and very accurate, but off service.
                    Sketchup photomatch
                    Very accurate, if you have really orthogonal geometry (not in my case).
                    pixdim or http://www.photomodeler.com
                    Similar to photomatch, but using two photos (i.e. stereo photos). Very accurate, if you can place the black/white reference points before taking high resolution photos. Otherwise (photos from web) not accurate.
                    Archipelis http://www.archipelis.com/product.php
                    Good for rounded things, not accurate.
                    Uses only single images and makes a very inaccurate guess of the depth info. But nevertheless impressive.
                    http://www.photo-to-3d.com
                    In the free version, it uses only two images of low resolution and was not able to create any polygons.
                    • N
                      notareal
                      @aerilius said:
                      2. I tried Microsoft photosynth which creates a 3d point cloud and uses it for a slideshow in 3d space. But photosynth can not export the 3d data.
                      Now you can http://binarymillenium.com/2008/08/exporting-point-clouds-from-photosynth.html + http://meshlabstuff.blogspot.com/
                      Might want to look on this http://binarymillenium.com/2008/08/photosynth-export-process-tutorial.html
                      • F
                        felderup
                        http://news.creativecow.net/story/866538 i went looking today... found this...
                        '(Venice, California--June 7, 2011) Lightcraft Technology, a developer of real-time visual effects technology for the film and television industries, announced that it is making its photogrammetry tools available free-of-charge to its clients and to members of the film making community.'
                        if the license allows... i'm up for making virtual dress forms, and imvu stuff. mom does some indie stuff, has had something go into the nfb archives... and she could use some 3d junk... if that's what i'd need to do to justify the terms.
                        • oganocaliO
                          oganocali
                          You may want to give Tgi3D photoscan a try.
                          http://www.tgi3d.com/ Trial version is unlimited free for 30 days.
                          • B
                            bjornkn
                            I have no idea how well that Lightcraft toolset works, but according to the info in that link it is a set of Maya plugins, making it useless if you don't own Maya (which I don't).
                            I have used such photogrammetry software for many years, PhotoModeler and ImageModeler, and now also Tgi3Ds PhotoScan (with plugin for SketchUp), and I can tell you that with PhotoScan making such a model should be much easier/better than with those two other tools.
                            There are also some free "3D scanners" available, but AFAIK they all produce huge, dense point clouds, which wouldn't be very useful for SU/GE work.
                            With PhotoScan you can control exactly how much detail you want in the geometry and how much detail you leave up to the textures (applied right inside SU with PhotoMatch tools).
                            Some of the photos you posted are croppped, which is not good for any photogrammetry software..
                            -- I noticed that the thread is old, so the "case may be closed" already?
                              Photofly ๐Ÿ˜‰ (it's free)
                              [flash=560,349:1n313mio]http://www.youtube.com/v/8YNrQA6eofI?version=3&amp[/flash:1n313mio]
                                Aerilius
                                Salut Pilou!
                                I will add my review of Photofly to this very very old thread:
                                http://forums.sketchucation.com/viewtopic.php?f=169&t=37848&p=334675#p334675
                                I would like to have drone for taking aerial photos of the original subject of my first post ๐Ÿ˜‰
                                • B
                                  bjornkn
                                  You could get a long way with a camera pole too ๐Ÿ˜„
                                  Out of curiosity - is that rock model on GE now? If it is - where is it exactly?
                                  Looks like a very strange formation.
                                  And did you try PhotoScan too?
                                    mac1
                                    Not my area but maybe worth a read โ“ $$ http://www.brainstormllc.com/ but has 30 trial
                                    • B
                                      bjornkn
                                      Photosketch looks nice, but it is advertised as a tool for creating lowpoly buildings inside SketchUp.
                                      Just like SU's own PhotoMatch, but with some automation, like undistorted photos, point clouds and higher precision?
                                      What dense point clouds does is using brute force, just like when using DEMs for generating landscapes. You really often need millions of polys to get a well defined model with crisp details/creases. It often ends up looking like a metaball/blob object.
                                      The beauty/power of PhotoScan is that it gives you the tools to model from photos fully controlled, and even make very dense automatically surface-fitted meshes like with point clouds, if that's what you want.
                                      And it can be used with any object, buildings, complex/concave organic forms, terrain - even with glass and shiny objects (which never works with point cloud mesh generators).
                                      I really doubt that any of the point cloud generators would have any chance to make an automatic model of something like this sharp edged, complicated/overlapping stainless steel sculpture?
                                        It's very easy with a kite! ๐Ÿ˜Ž
                                        From this page
                                        http://kap.online.fr/images/rig1.jpg
                                        http://kap.online.fr/images/rig2.jpg
                                        http://kap.online.fr/images/radio.jpg
                                        http://kap.online.fr/images/eclipse1.jpg
                                          I have forgotten PhotoSculpt ๐Ÿ˜‰ (just 2 images ! ๐Ÿ˜Ž
                                          • B
                                            bjornkn
                                            Kites (aka KAP) are nice if there's wind and you're not close to people/buildings/trees/power lines.
                                            Balloons, blimps, RC helis etc are nice if there are no wind, people/buildings etc
                                            Poles are nice if you want closeups from lower altitudes than possible with a kite, and works fine anywhere, regardless of wind, people/buildings etc.
                                            Besides, it requires a lot less rigging/setup and is a lot cheaper ๐Ÿ˜„
                                            A sturdy telescopic 7m pole may cost you $100?
                                            BTW, PhotoSculpt seems to have a very limited use for modeling, as it can only use 2 photos, and only makes a textured 3D relief.
