    Plugin(export attributes to csv)
    16 Posts 4 Posters 865 Views 4 Watching
      tetsuyahishida
      Hi!All. I'm a newbie and I'm sorry if I'm in the wrong place.
      Now making a plugin based on TIG's
      "exportvertices2csv"
      "VolumeCalculator2"
      The script it self is uploaded in GITHUB
      https://github.com/tetsuyahishida/export2csv
      <What the Plugin can do>
      the script can output
      1.volume
      2.are of the faces
      3.normal vector of the faces
      to csv
      <The Problem>
      But the problem is that it doesn't work on in some PCs!
      The window with the message
      "uninitialized constant Export2csv::Volume”
      can some body help me?
      snapshot
        The class method
        def Volume::calculate(fcs)
        should be renamed as
        def volume(fcs)
        and then called in the 'initialize()' code where
        volume=Volume.calculate(fcs)#calculate volume
        becomes
        volume=self.volume(fcs)
        you are making it all too convoluted...
        PS: whilst I don't mind an acknowledgment in the scripts header, please don't make me the (c) author... that's you ! I accept NO blame 😉
        • Dan RathbunD Offline
          Dan Rathbun
          Why do you distro a copy of sketchup.rb ?
          It does not appear to be different from the Google version, and should not be changed anyhow.
          I'm not here much anymore.
            tetsuyahishida
            Thank you so much for your reply!
            I'm a fan of you. So excited to be able to get in touch with you.
            The Plugin worked flawlessly after the modification.
            Dan Rathbun
            Thank you for your advice.
            It is the same as the Google version.
            I'll push the changes.
            Since using "git" and push it to GITHUB seems to be a very usefull method I think other sketchup user might like using it.
              You shouldn't distribute sketchup.rb - all users will already have it in their Tools folder, so giving it to a user who might then put a duplicate [or worse, 'out of date'] version into their Plugins folder could cause all sorts of unexpected complications that can be avoided by NOT supplying it in the zip-file.
                tetsuyahishida
                Thank you for your advise.
                I've removed sketchup.rb from GITHUB.
                Unfortunately, some other people still can't use the plugin.
                <Error message>
                #<NameError: undefined loca variable or method 'export2csv' for main:Object>
                do you have any idea what's wrong?
                export2csv/export2csv.rb at version0.8 · tetsuyahishida/export2csv
                sketchup plugin. Contribute to tetsuyahishida/export2csv development by creating an account on GitHub.
                GitHub (github.com)
                screenshot
                  Jim
                  The error message is correct - export2csv is not a variable or function - it is never defined. You get the same error if you enter random characters in the Ruby Console.
                  Enter Export2cvs.new to start the plugin from the Ruby Console (the same as how it is executed from the menu and Toolbar.)
                    Jim
                    Also, the Array class already has a .dot method - no need to add one to the Geom::Point3d class.
                    http://code.google.com/apis/sketchup/docs/ourdoc/array.html#dot
                    In fact, it is best not to add or change methods of any of the API classes because those changes may cause other plugins to fail, or worse - to have subtle errors which may go undetected.
                      ...OR alternatively you could make a 'shortcut' method
                      def export2cvs(); Export2cvs.new(); end
                      outside of the Export2cvs class and then typing export2cvs will also run the tool...
                        Jim
                        ...outside of the Export2cvs class
                        You don't want to do that either. Adding a top-level method adds it to the look-up chain for all Ruby objects. So there is a minute chance that if another dev happens to have a export2csv method and makes a mistake (a typo, for example) it is possible that the top-level method gets found and executed instead. This can occur even if the other dev's method is correctly namespaced.
                          @jim said:
                          ...outside of the Export2csv class
                          I know it IS inadvisable to add new methods directly to the top-level, BUT even the API Ruby Examples show this way... so IF this guy is making a script for limited use and he has few other scripts loading then he's unlike to have a clash... BUT perhaps a less common name would be safer, AND of course even the class itself Export2csv.new() might have been used by someone else too... so then it'd be best to have a module holding that class, as it would then be extra-extra safe ! Then you'd have to type TetsuyahishidaTools::Export2csv.new(), BUT then it is very-very unlikely to have been duplicated by anyone else!!
                          Simply use a module to hold the class like this...
                          module TetsuyahishidaTools
                            class Export2csv
                              def initialize()
                              end#methods
                            end#class
                            class Export2tsv ### another Tool!
                            end#class
                          end#module
                          This way you can have several tools under the 'TetsuyahishidaTools' module...
                          PS: Please remove me [(c) TIG] as the 'blame' for this script in the header 😉
                            tetsuyahishida
                            Thank you for your reply.
                            jim
                            The user and he said typing"export2csv.new" solved the problem.
                            He was typing "export2csv"
                            I've immedeately modified the authority. Sorry about my insensitiveness.
                            Still I got three questions
                            First, does "::"of "TetsuyahishidaTools::Export2csv.new()"
                            stands for scope resolution operator?If not, what does it stand for?
                            Second, Why does the "TetsuyahishidaTools Module" have to be a "Module"?
                            Is it because in Ruby, a class can only inherit from a single other class?
                            Or something about nesting rule?
                            Third, are there any way to do the same thing using "include"?
                            Sorry for my poor English and ruby skill.
                            Best regards.
                              Dan Rathbun
                              YES
                                Dan Rathbun
                                Because an instance of class Module, can only be a singleton instance, meaning only ONE copy of the code it encloses, is needed.
                                Think about it. Within your outermost namespace (module), which should be your unique namespace (your company, etc.) you will define nested objects, both of class Class and class Module, and each of those only needs to be defined ONCE.
                                No. But for your info... class Class, is actually a direct child subclass of class Module, so objects of class Class, will inherit some methods from their superclass (class Module.)
                                Also.. what most people do not realize, is that when you define a module, like ...
                                module SomeCode
                                  # method definitions, etc.
                                .. that the Ruby parser actually instantiates an instance of class Module like this ...
                                SomeCode = Module.new do |mod|
                                ... but it's actually done by C-side function calls.
                                  Dan Rathbun
                                  Only module instances can be mixed-in using the include or extend methods... BUT these 'mixin modules' can be mixed into other modules, classes, or instance objects.
                                    tetsuyahishida
                                    Dan Rathbun
                                    Thank you so much for instruction.
                                    I am now studying "Design Patterns in Ruby"
                                    And just learned about Singlton Pattern.
                                    Does every one use Design Pattern making sketchup plugin?
                                    Or maybe use UML?
