    My wall dont wants to fillup
    22 Posts 5 Posters 955 Views 5 Watching
      He probably used some plugin for the components (in my version, I hid them on a layer). Maybe TT's selection toys or similar:
      http://forums.sketchucation.com/viewtopic.php?t=14975
      Under Window > Model info > Statistics you can purge all unused components, layers, materials and styles.
      • E Offline
        erzane
        yes now they are, I modified angles on the 3rd pic yesterday, so now all is alright concerning angles
        thanks for having took a look on them and for having changed style with axes, now it's more clear
        the problem is what DaveR suggested
        yes exactly I wanted to see the top and bottom edges of the wall as horizontal.
        thanks for having changing it, now I know how you proceeded
        so, now that's the type of view I wanted, (which looks the most to true pic of my room)
        but this is very difficult to have same view as true picture
        http://img12.imageshack.us/img12/4786/capt11023140230001.jpg
        how did you converted the floor grids to instances of a single component?
        I made 4 pieces but 1 wasen't really well disposed, so thanks for that
        about purging unused stuff which cut file size down by more than 66%
        what does that mean ?
          Yes, I used a plugin to convert the floor grids to instances of the same component. My suggestion would be to make components from the beginning so you don't have to go back and deal with them later.
          Purging is an important thing to do to get rid of unused stuff in your models. Your original model isn't that large but once you start adding in furniture and other details, the file size could get quite large. Anything you can do to keep that under control will be helpful and you may as well learn good housekeeping from the start.
          One thing to consider with the view you are trying to achieve is that it looks like you turned the camera to take a vertical photo. You could create the same view in SketchUp by setting the drawing window to be the same shape (drag the corners) and adjusting the angle of view/focal length of the camera. While changing the size of the drawing window works, it can cause problems with toolbars you have displayed. It's probably easier to leave the drawing window and crop the image you export (File>Export>2D...) using your favorite image editor.
          • E Offline
            erzane
            concerning plugin to convert the floor grids to instances of the same component and purging operations
            ok I see, I will follow your suggestions
            concerning the camera view
            I dont understand 100%, pls can you explain me how to proceed
            p.s. I have an eizo rotative monitor if it can helps ?..
            p.s. yes I turned camera vertical for making true pic of my room
            concerning toolbars I can take them off without prob
            yes I would like to create same view
            what does ''crop'' mean ?
            what does ''drag'' the corners ? how to do ?
            p.s. I tryed to export my pic but I didn't succeeded
            is it a rapport with that Honoluludesktop suggested ?
            p.s. I will come back home in 1 or 2 hours
            thanks again for al your helps guys
              You can change the angle of view or lens focal length for SketchUp's camera by selecting the Zoom tool and typing either the angle of view. (35, Enter would give you a 35° angle of view) or focal length including 'mm' (50mm, Enter would give you the equivalent of a 50mm camera lens).
              If you want to rotate your monitor and work with it that way, you can certainly do so.
              "Crop" means to trim the image after exporting it. It would be similar to trimming a printed photograph with scissors to cut away stuff you don't want to see. Most of the things I draw don't fit the horizontal shape of my drawing window so the exported images get cropped to suit the subject and eliminate unneeded background.
              "Drag" means to move the corners or edges of your drawing window to change its shape.
              What problem did you have as far as exporting an image from SketchUp? You should be able to go to File>Export>2D Graphic and export a JPG or PNG image with no problem.
              Here is an example of cropping.
              First, the image exported directly from SketchUp:
              And then the cropped image:
              • E Offline
                erzane
                ok I see now
                do you think I can have a better view with skp ?
                I feel skp camera view is limited for imitate real view of reality, like on my true pics if you compare both
                • E Offline
                  erzane
                  ok I see now better whats mean those words
                  I will make some tests concerning skp cameras settings and will give you news asap
                  thanks for all your explanations
                  p.s. about exporting 2d image
                  it's ok now I understood which mean this 'exporting' word better
                  in most of the cases I always took a capture of my work for export it,
                  now I know it's better across this menu
                    Gábor, I see you are a member of the French usergroup (guess your location). Do you speak any Hungarian as well?
                    • E Offline
                      erzane
                      yes for sure I speak hungarian, french and english
                      multkor beszéltunk is, emlékszel ra ?
                        Ah igen, bocs...
                        • E Offline
                          erzane
                          semmi baj ^^
                          • 2 / 2
