    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Crash at image export
    7 Posts 2 Posters 557 Views 2 Watching
    • H Offline
      harnstein
      Hi all,
      for some strange reason sketchup newly crashes when i try to export 2d images. I don't know why or since when i may have changed sth. or added some plugin.
      I tried without any plugins installed (moved them to a seperate folder) as well as a quick reinstallation but had no luck.
      Pdf export works fine. CAD and 3D (3ds) export as well.
      Any suggestions?
      still sketchin'
        What's the size and file type of the images you want to export? Does it crash with smaller ones - or with other models, too?
        • H Offline
          harnstein
          Any size (screenratio or set aspect ratio with thom's tools), any kind (jpg, png, bmp) until now.
          It appeared first at the export of a model with approx. 60 components, 1000 instances, 500000 faces, 1100000 edges.
          Even if i try to export an image of an ordinary box it crashes.
          Hm..
          still sketchin'
          • H Offline
            harnstein
            No idea anyone?
            Unfortunatly it didn't solve itself.. πŸ˜‰
            still sketchin'
              Sorry but I have no clue. Something must have gone really wrong there and I would think about a complete reinstall (if fixing does not help, even a complete uninstall and then reinstall).
              I also had to do this a couple of months ago (although the problem was different) and it helped.
              • H Offline
                harnstein
                Gaieus, thank you πŸ˜„
                probably you're right, that's what i will have to do. reinstalling skp is not that bad.. it's just annoying rearranging all icons and stuff again..
                if you don't hear from me it should be ok again
                -closed-
                still sketchin'
                • H Offline
                  harnstein
                  Ok, got it. Uninstalled / installed several times..
                  Then went to registry and deleted some old relicts, now it works all fine again...
                  _h
                  still sketchin'
