    Fyels - Simple File Sharing
    2 Posts 2 Posters 1.4k Views 2 Watching
      Mentioned on Lifehacker here
      http://fastcache.gawkerassets.com/assets/images/17/2011/05/fyels.jpg
      Fyels is a mostly empty webpage, onto which you can drag and drop nearly any file for quick sharing. Other than a 2 GB size limit, there are no other caveats, like waiting times or registrations, so you can just send your file and get on with your day.
      When you share a file, Fyels will give you a password in case you want to delete the file from Fyels' servers later on. To delete a file, you can just re-enter that short link with .delete appended to the end of it. Then, after typing in your password, the file will no longer be accessible through the original link. If you're looking to send a file to a friend with minimal hassle, Fyels is a pretty cool way to get it done quickly.
      (fyels.com)
      • mitcorbM Offline
        mitcorb
        Hey, Rich:
        Thanks for this.
