    How do I move a Group of entities on their own?
    5 Posts 2 Posters 513 Views 2 Watching
      SJH333
      Please excuse my ignorance, this is all new to me!
      I'm having trouble moving a Group of entities on their own; if I move both my Groups (all entities) everything is OK, but if I move entities from only one Group, SU displays a crazy result.
      I'm really not too sure that I'm understanding, the entities = model.entities
      vs entities = model.active_entities idea, is this my problem?
      Any help would be appreciated. Thanks, Steve.
      I've attached two screen shots, one OK and one very obviously NOT OK!
      Here's my Code:
      # 30/04/2011 SJH_Groups_Add_v02.rb
      puts "Running... SJH_Groups_Add"
        require 'sketchup.rb'
        model = Sketchup.active_model
        #entities = model.active_entities
        selection = model.selection
        # Set some length variables
        rl = 1
        gl = 1
        bl = 1
        rlmid = rl*0.5
        glmid = gl*0.5
        blmid = bl*0.5
        # To convert to SU current Model units
        rl = rl.to_s.to_l
        gl = gl.to_s.to_l
        bl = bl.to_s.to_l
        rlmid = rlmid.to_s.to_l
        glmid = glmid.to_s.to_l
        blmid = blmid.to_s.to_l
        # Create Face points array
        fpts = []
        fpts[0] = [0, 0, 0]
        fpts[1] = [rl, 0, 0]
        fpts[2] = [rl, gl, 0]
        fpts[3] = [0, gl, 0]
        # Create String and counter for incrementing group names
        sjhname = "SJHGroup"
        groupcount = 0
      # ---------- Start Main Code ----------
        groupcount+= 1
        groupname = sjhname + groupcount.to_s
      # Create a Group - mygroup1
        mygroup1 = []                                        # Create an empty array to prevent Bug Splat!
        mygroup1 = entities.add_group                        # Make the array a Group Entities class
        gentities1 = mygroup1.entities                       # Create an array of the Entities in mygroup
        mygroup1.name = groupname                            # Change the Group name
        face = gentities1.add_face fpts                      # Add a face to gentities1
        pullface = face.pushpull -bl                         # Do a push/pull to the face
        tcoordinates = [rlmid, glmid, blmid]                 # Set coordinates for text
        tpoint = Geom;;Point3d.new tcoordinates              # Create a 3d point for text
        mytext = gentities1.add_text "#{groupname}", tpoint  # Add a text label
        model.close_active                                   # Close mygroup1
      # Closed the Group
      # Move everything in the model
        entlen = entities.length
        transform = Geom;;Transformation.new([(rl*2),0,0])
        for e in (0... entlen)
        entities.transform_entities(transform, entities[e])
      # Select mygroup1
        #selection.add(mygroup1)
        groupcount+= 1
      # Create a Group - mygroup2
        mygroup2 = []                                        # Create an empty array to prevent Bug Splat!
        mygroup2 = entities.add_group                        # Make the array a Group Entities class
        gentities2 = mygroup2.entities                       # Create an array of the Entities in mygroup
        mygroup2.name = groupname                            # Change the Group name
        face = gentities2.add_face fpts                      # Add a face to gentities2
        mytext = gentities2.add_text "#{groupname}", tpoint  # Add a text label
        model.close_active                                   # Close mygroup2
      # Closed the Group
      # Select mygroup
        #selection.add(mygroup2)
      # ---------- With this Code it goes crazy ----------
      # Move gentities1 (mygroup1) ONLY
        entlen = gentities1.length
        entities.transform_entities(transform, gentities1[e])
      # Question; How do I move a Group on it's own (using Ruby API Code)?
      # ---------- End Main Code ----------
      puts("\n   END \n..........")
      # end of SJH_Groups_Add.rb
      Capture1-Moved-OK
      Capture2-Move_NOT_OK
      • TIGT Online
        Your request is a little unclear...
        You can move a group simply by applying a transformation to the group.
        This 'transforms' the group within it's context [here the model].
        You can move a group's entities [all or in part] by applying a transformation to them.
        This moves the specified group's entities within the group itself.
        You have a reference to the group - e.g. mygroup1 - so use mygroup1.transform!(tr) - assuming 'tr' is a point-transformation or a translation-transformation, then the group moves to that new location or by that vector to suit... This is the simplest way to relocate whole groups within the model or even when they are within other groups etc...
        A transformation can move to a point, move by a vector, rotate, scale etc...
        When you want to move a collection of entities [say within a group] use something like this...
        ents=mygroup1.entities ents.transform_entities(tr, ents.to_a)
        This transforms all of the group's entities by 'tr' - note how we change the 'ents' to an array [with .to_a] to construct the list that will be changed...
          SJH333
          Thanks Tig.
          I've got it to work with your suggestion:
          # Move (mygroup1) ONLY
            tr = [(rl*2),0,0]            # Set transformation
            mygroup1.transform!(tr)      # Move mygroup1 (apply transformation)
          I was making it more difficult than it needed to be! πŸ˜‰
          I didn't need to touch the Groups Entities.
          Easy, when you know how! πŸ˜„
          Thanks again.
          Attached is the 'moved' (transform!)ed Group.
          Capture3-Working as required
          • TIGT Online
            Try making it as a proper transformation
            pt=Geom::Point3d.new(rl*2, 0, 0) tr=Geom::Transformation.new(pt) mygroup1.transform!(tr)
            To move by a set vector use
            vt=Geom::Vector3d.new(rl*2, 0, 0) tr=Geom::Transformation.translation(vt) mygroup1.transform!(tr)
            Using an array as the transformation might give unexpected results...
            Also the Geom::Transformation model has several other useful methods like rotation and scaling.......
              SJH333
              Now the Penny is dropping! Slowly... πŸ˜‰
              After a day going round in circles, I've had a productive evening...
              For absolute Newbies, here are some Group transformations (thanks yet again TIG):
              # 30/04/2011 SJH_Groups_Add_v03.rb
                rl = 1
                gl = 1
                bl = 1
                rlmid = rl*0.5
                glmid = gl*0.5
                blmid = bl*0.5
                rl = rl.to_s.to_l
                gl = gl.to_s.to_l
                bl = bl.to_s.to_l
                fpts = []
                fpts[0] = [0, 0, 0]
                groupcount = 0
                groupcount+= 1
              # Closed the Group
                UI.messagebox("mygroup1 added.  What's next?")       # User Message to see what happened!
              # Select mygroup1
                UI.messagebox("All entities moved.  What's next?")   # User Message to see what happened!
                groupcount+= 1
              # Closed the Group
                UI.messagebox("mygroup2 added.  What's next?")       # User Message to see what happened!
              # Select mygroup
              # Try making it as a proper transformation (TIG 30/04/2011)
                pt=Geom;;Point3d.new(rl*2, 0, 0)
                tr=Geom;;Transformation.new(pt)
                UI.messagebox("mygroup1 moved by Point3d.  What's next?")  # User Message to see what happened!
              # Move (mygroup2) ONLY
              # To move by a set vector use (TIG 30/04/2011)
                vt=Geom;;Vector3d.new(-rl*2, 0, 0)
                tr=Geom;;Transformation.translation(vt)
                mygroup2.transform!(tr)
                UI.messagebox("mygroup2 moved by Vector3d.  What's next?")  # User Message to see what happened!
              # Rotate (mygroup1) along Red axis
                pt=Geom;;Point3d.new(0, 0, 0)
                vt=Geom;;Vector3d.new(rl, 0, 0)
                an=45.degrees
                tr=Geom;;Transformation.rotation(pt,vt,an)
                UI.messagebox("mygroup1 rotated along Red axis.  What's next?")  # User Message to see what happened!
              # Rotate (mygroup1) along Green axis
                pt=Geom;;Point3d.new(rl*6, 0, 0)
                vt=Geom;;Vector3d.new(0, gl, 0)
                an=45.degrees
                tr=Geom;;Transformation.rotation(pt,vt,-an)
                UI.messagebox("mygroup1 rotated along Green axis.  What's next?")  # User Message to see what happened!
              # Scale (mygroup2) uniform about origin x3
                tr=Geom;;Transformation.scaling(3)
                UI.messagebox("mygroup2 scaled uniform from origin.  What's next?")  # User Message to see what happened!
                tr=Geom;;Transformation.scaling(0.3)
              # Scale (mygroup2) non-uniform about origin
                tr=Geom;;Transformation.scaling(3, 2, 1.5)
                UI.messagebox("mygroup2 scaled non-uniform from origin.  The End! ;o\)")  # User Message to see what happened!
              Attached is a pic of my moved, rotated and scaled Groups. Doesn't seem much but this morning that would have been a pic of a Bug Splat! Happy, happy! πŸ˜„
              Capture4-Rotate-Scale
