π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Spiral Stair Railing
Hi Everybody, I set up a quick way to draw the railings for a spiral stair case, and wanted to share my workflow with you. When you download the file, you will be able to model the side of this staircase:
Just using geometry principles and the bend tool found in Fredo Scale tools. So.. if you think you need something like this, download the file and check it out
Nice work!!
Cheers,
thanks..i'll give it a shot
