    Ruby & sectionplane
    3 Posts 2 Posters 450 Views 2 Watching
      pgarmyn
      Hi, i'm just starting in ruby.
      I'm making a script that combines automatic sectionmaterials and projected information on the sectionplane (like beams represented by pointed lines in architectural drawings).
      Is there a way to activate an existing sectionplane in ruby ?
      if @@sel[0].class == Sketchup::SectionPlane
      what to do here ????
      And how activating View/SectionCuts in a ruby ?
      • TIGT Online
        You have quite quickly discovered a problem with the current API - there are VERY limited methods to access the SectionPlane object...
        You can't set/reset the active section by code.
        You will have to make some manual connections between active-sections and Scenes... and then perhaps access a scene to activate its section !
        You can activate a particular view by making that scene [page] the 'selected_page' under model.pages...
          pgarmyn
          Thanks for the immediate reply.
