    Clever recycling and repurposing hacks?
    44 Posts 14 Posters 7.4k Views 14 Watching
      Roger
      2-liter soda bottles
      This frame for this bed consists of 2-liter soda bottles and one sheet of plywood with holes drilled to accept the bottle necks. A small amount of highly-liquid black acrylic paint is poured inside the bottles and tumbled until they are coated. All holes and edges of the plywood are eased with a router equipped with a rounding over bit. The upper section represents the standard box springs and mattress.
      Comments on the concept are welcome.
      http://www.azcreative.com
      • pyrolunaP Offline
        pyroluna
        Interesting concept... how do the top and bottom attach to one another? Won't the bottles tend to bend or skew outward?
        You'll probably stay dry if your house floods, considering the amount of upthrust* πŸ˜„
        • not sure that is the right word. buoyancy might be better? or lift? not sure not sure.
          Roger
          Some good questions. Worthy of a rethink. Perhaps it would be better to arrange the bottles in a hexagonal stacking matrix to that all the bottles touch and join them with silicone adhesive. I could be done as one large unit or in units of seven bottles as that configuration would be inherently stable as it would be wider than tall.
          I used to have a small sailboat and kept the areas in the hold, in the cabinets and under the beds filled with empty two liter bottles just in case we would be swamped by a following sea or developed a hole in the hull. The boat has been knocked down sideways in rough conditions on San Francisco Bay.
            tfdesign
            😲 It looks more like one of those devices that crushes you! πŸ˜†
            You're beginning to sound like my dad (who oddly enough, is also called Roger)! 😲 (fortunately he's now almost 70 and I'm 43, so I flew the nest years ago, but he too was obsessed with these 'green' solutions. In fact we visited some remote recycling joint on Vancouver Island in the late 1970's so he could make a report for the British Labour Party, back here (yes, you guys can partly blame my dad for the horror of green politics so inherent in the Labour Party! 🀣 It actually got so bad at home that in the end my mother walked out on him, because (partly- she also had her other other reasons πŸ˜‰ ) he refused to install a working central heating in a barn we had converted to a house- it was bloody freezing in there during the winter! We were one of the first families in Britain to convert an English barn into a house (built by me, my dad and a handful of others). The local farmers caught on and got in on the act in the early 1980's and made even more money than they already owned, then the stockbroker belt of London moved down to Lewes, and the rest is history. So, my British chums, you who are fed up about being lectured about green politics and 'heathy' eating, you can partly blame my dad for that!! Lynchmob? You have my full sympathy! 😲 😒 πŸ˜† )
            Rant over.
            Back to the bed, Why not just use wood? Wood would be far easier to pack away (I presume that the lids screw back on against the top wood part to hold it in place? I'd hate to the one who would have to take those all off again!) And, how will you get the strength from the bottle neck? There will be an immense amount of pressure exerted on the neck of the bottle. You may find that one night you roll over, and land with a thud on the ground, while one side of your bed collapses!
            Another option of course, is "freecycle" πŸ˜‰ πŸ˜„
              tfdesign
              Ah yes, I've been beaten to it!
              Most green sticky-paster ideas, imo are silly. It is better to design something so well, that it'll last. Unfortunately, designing things to last doesn't bode well with capitalism.
                Roger
                Dear Tom the pipe guy, regarding the rant:
                I think I would like your dad a lot. I suspect the lack of central heating had less to do with green than being a clever way to get his son out of the house.
                Now, in regard to the bed. Are you sure you are an architect? Let's assume that two people, springs and a mattress came to 600 pounds. Pro rated over 165 bottles that is a whopping 3.64 pounds per bottle (Did you really mean to use the word IMMENSE? [I didn't think so]). Hopefully you are not allowed to do structural calculations in your office. I weigh about 240 pounds and have jumped on one of these bottles giving it a tremendous shock load. I neither splits or blows off the screw cap. In the local supermarket I have seen these bottles in 1/4 height bottle carriers stacked 5 crates high with no bending or deformation.
                In fact PET plastic soda bottles have a design rating of 200 psi. One atmosphere is 14.7 psi. Soda is around 55 psi (55/14.7 = 3.74 atmospheres)
                A Mercedes C class sedan weighs 2,271 pounds. When divided by 165 bottles, each bottle would only need to carry 13.76 pounds per bottle. Would you be willing to put a few Euros on a capped 2 liter PET bottle being able to support 13.76 pounds? [I didn't think so.]
                You ask why not use wood? I built a couch from Mahogany from a single board. The board cost $500 right from the lumber yard. I also built a quarter-sawn oak coffee table to plans from a wood working magazine. They estimated the cost of wood at $200. I had the local lumber yard cut down some boards for me and went to check out. When they gave me a bill for $200, I smiled and said thanks I hope you can sell boards of this dimension because I am not paying $200 bye, bye. Soda bottles are free for the taking. I am on a fixed income (actually not fixed as for the second year in a row there has been no cost of living increase). I also find the soda bottle aesthetic interesting when not left to chaotically litter a landscape or become part of a land fill. Also they weigh very little (52 grams per bottle) compared to the space they take up. One-hundred-sixty-five bottles plus the plywood weigh less than my current bed frame. Availability speaks for itself. β˜€
                • pyrolunaP Offline
                  pyroluna
                  Hexagonal sounds good. But instead of adhesive, I was thinking you could put a band around them to hold them together. Something that doesn't stretch too much... something like this:
                  http://images-en.busytrade.com/110278500/Stainless-Steel-Clamping-Bands-andamp-Strips-andamp-Straps.jpg
                  No idea about the price though. But probably cheaper than mahogany πŸ˜„
                    Roger
                    Your idea is sparking another idea. That stuff looks a bit like edge banding, but the woven stuff looks like the native made palm hats made by pacific islanders. Here in Phoenix we have millions of palm trees when, in fact, there is only one small grove of native palms hidden in one very remote canyon. So there is tremendous amount of activity and energy that goes into trimming palms and dumping the leaves into landfill. Bottle cluster bands woven from palm leaf would be an interesting reuse.
                      Roger
                      We had that full lunar eclipse near the winter solstice last night. Of course we had thick cloud, so I did not see it. However I looked up some astronomy in anticipation of the event. In the process, I found out that Galileo built the tube of the first telescope from repurposed copper plumbing tubing. That made my day. Galileo changed the course of science and history with a pipe that brought water to his bathroom. I feel totally vindicated in my interest in repurposing.
                        Roger
                        ikea hack
                        Take one Ikea wall vase with draecena (plant) and throw the draecena away. Then add a solig solar lamp. You can use the spike that comes with the solig walkway lamp but I prefer a thick bolt with a decorative acorn nut at the bottom and you just slip the solig over the bolt.
                        Also the plastic covered solar cell degrades in strong UV light, but I find the sun is so strong here in Arizona that you can cover the cell with a white plastic shopping bag when it is charging out doors and still get a full charge. The aluminum plate just screws to any wall indoor or outdoor.
                        I have some material and lighting issues at the moment and will improve the render when I understand what is going on.
                          ledisnomad
                          Nice outdoor light idea! Shouldn't you find a use for the draecena, too? I like Ikea hacks. I was looking for a good, DIY bike rack and found this image through Google image search.
                          [img]IkeaBikeRack.jpg[/img]
                          Unfortunately, none of the blogs it seems to be posted on still have it up or something. I can't find any information about what Ikea product it is made from.
                          This isn't a very elaborate recycling hack, but I like it quite a bit: in my architecture office, we go through a lot of paper. Most of it goes in the recycle bin when it is discarded. Then I see people walking around with new notebooks. Don't get me wrong, I love a good notebook, but all that one-sided paper has another good side! We have a binding machine, so I've taken to cutting the used-on-one-side paper down to 4.25"x11" and binding a stack on the short edge. The long and narrow proportion is perfect for making lists (and I make a lot of lists). Then I can keep my sketch book as an archive of my ideas and not clutter it with a lot of day-to-day mundane stuff.
                            Roger
                            Was only kidding about tossing the plant. However we do forget to add water to the mini vase and they die. The sconce is so simple that I may make my own. I could make a plywood die and feed in aluminum blanks and apply pressure with wood working clamps.
                              ledisnomad
                              Would that work? Wouldn't the aluminum straighten out a bit after you release it? Your form might have to "overbend" the aluminum to take that into account, no?
                                Roger
                                Solig from IKEA
                                You might be right. There are a number of variables involved. However, if you get close you can probably do a little adjustment by hand. Trial and fit.
                                  ledisnomad
                                  Well, if you give it a try, I'd like to see the final result!
                                    Roger
                                    This came to me while I was doing a watercolor sketch of my uncle who was a WWII bombardier.
                                    If you are an artist here is an IKEA hack for you. The round IKEA magnet board makes a great drawing and painting tool. You can use magnets for hold downs. The board rotates easily so you can orient the picture to the stroke of your brush or pencil. However it can trap air when used on a tilted surface which will cause it to fall to the floor. To combat this, I put some furniture pads on the back so it can slide, but not just float on trapped air.
                                    movable art surface
                                    • brodieB Offline
                                      brodie
                                      A bit of an old quote Roger, but I'm not sure I understood this story. They said it'd cost about $200, they cut the wood for you, then when you found out for sure that it'd be $200, you left them with the already cut boards and left?
                                      -Brodie
                                        Roger
                                        -Brodie
                                        Brodie, I think I typed that late at night and didn't proof read it. I was working from some plans in a wood working magazine. The author said the entire coffee table with quarter-sawn oak, hardware and finish should come in at around $200 plus or minus. I went to the lumber store and asked for quarter sawn oak and they said they didn't have it. So then I said give me some white oak regular sawn. When I got to the check out they gave me a bill for $500. Maybe I should have done the math, but $500 vs $200 (a price that came from a current wood working magazine not something found in my garage from 1930)it was a "you can keep it and I'm not coming back moment". I found a small neighborhood mill that sold me the wood for close to $200 and gave them the rest of my business for the time I continued to live in the area. You might not think it ethical, but I really felt that it was me that was getting stiffed.
                                        • brodieB Offline
                                          brodie
                                          Aw, that makes much more sense. Assuming $200 was a fair price for that amount of quarter sawn oak (beautiful stuff), I can't imagine spending $500 for regular oak. I worked at a home improvement store for awhile (Menards, which is only in the midwest but it's basically the same as Lowes or Home Depot). I worked in millwork so I was cutting trim for people all the time. I can't quite equate it to selling $500 worth of wood but it never really bothered me much when I saw a bunch of trim coming back that someone had decided not to get. Then again, I was just a grunt getting paid by the hour so it was all the same to me. We would periodically throw away the pieces smaller than 5' or so because few people needed them and they just started falling all over the place (not really 'throw away,' they all got sent along with defective merchandise back to the distribution center - no one could ever tell me what the heck they did with that stuff but I suspect it wasn't worth as much effort as we spent bundling it up and shipping it back).
                                          -Brodie
                                            Roger
                                            IKEA Cane Rack
                                            I have developed arthritis and in the process collected a number of canes. I always look to IKEA for cheap repurposing solutions. IKEA sells these for $200. The original is to hold used plastic grocery bags.
                                            From top to bottom:
                                            1. Free cane given to me by the Costco pharmacy on Veteran's day. It folds nicely and is good for traveling in the car or in a plane.
                                            2. Best friend who teaches design in the School of Architecture and Design at King Mongkut's University in Bangkok brought this on his yearly visit back to the states. I need to lengthen it as I am taller than the average Thai.
                                            3. A Jaguar cane bought from Cost Plus because I like the funky jaguar carving.
                                              4.The calibrated cane with both inch and centimeter scales on the side. It also breaks down for travel. It is more of a walking stick than a cane. The head contains a compass. It also has a tripod screw for a camera. The calibration comes in handy for photos to be used for photomatching in SketchUp.
                                            4. This is also a monopod/cane conversion. Airport security in Spain almost took it away from me because they thought it was a high-tech shillelagh. However, when I accused them of tilting at windmills they backed down.
                                            • 2 / 3
