    Syntax Highlighting in SU WebDialog
    13 Posts 4 Posters 2.0k Views 4 Watching
      Jim
      Here's one:
      Welcome to nginx!
      (codemirror.net)
      Just saw a story that Google Code Hosting is now using this.
        driven
        cheers I'll have a look...
        • Dan RathbunD Offline
          Dan Rathbun
          @jim said:
          Here's one:
          Welcome to nginx!
          (codemirror.net)
          (1) Go to this website: http://eloquentjavascript.net/chapter1.html
          (2) Scroll down till you see the sample JS codebox, that begins:
          var total = 0, count = 1;
          (3) on the right side of the codebox, click the "Load into Console" button...
          Look familiar Jim ?? πŸ˜›
          I'm not here much anymore.
            Jim
            I'm liking code mirror:
            http://i.min.us/ibK4jW.png
              Dan Rathbun
              looks good!
                driven
                that's great
                I started to put it into yours as well, but haven't had much time
                did you make a new SU Ruby library? or point it to something that exist?
                can you PM me a WIP to see if the Mac likes it?
                  driven
                  finally got rid of that off-set box
                  hi Jim,
                  I had a chance to play with CodeMirror in your new box...
                  Managed to get a clean fit, after a lot of looking.
                  I added a choice of 3 colours (shades of grey, really).
                  Border reduction and text-color's are next on list.
                  The pushed inner html is where you can tweek some of the .editbox things and you only need the textarea for pre-loading a template, so I put it back in.
                  I'll work through and update everything to the latest versions before sending.
                  ... and then work around your windows only features...
                  • alexschreyerA Offline
                    alexschreyer Extension Creator
                    Howdy!
                    Can't believe it took me until now to find Codemirror... I am working on adding it to my editor as well. In case you're curious, here's a live preview:
                    404 Not Found
                    (media.alexschreyer.net)
                    I also added the other languages - in case someone wants to edit an HTML web dialog file etc.
                    Cheers,
                    Alex
                    Author of "Architectural Design with SketchUp":
                    http://sketchupfordesign.com/
                      Dan Rathbun
                      Well it's relatively new is is not? When this topic started I think it was still listed as beta.
                      Looking really good Alex!
                      P.S.: Do you have a way to use standard Windows styling instead of that charcoal theme?
                        I still have to make the light and dark themes work. I started with the dark theme first...
                        Because Codemirror has an autocomplete function, I am looking into implementing this, too. What is the function that gives me access to all available methods in SU? I tried the following one but the list is limited to the Sketchup object.
                        puts Sketchup.methods.sort.join("\n").to_s
                        Cheers,
                        Alex
                        P.S. I put in the request to disable the single undo.
                          driven
                          hi Alex, and all
                          just to muddy the waters, after trying to get Codemirror to play nice inside SU on the mac I've been working on Ace editor http://ace.ajax.org/ and it's fantastic... very well supported and with some tweaking, usable 'offline'. It's the same 'engine' in cloud9 which everyone should try out .
                          The css may not work the same on PC's but the js should and for now I'm only after a Mac solution, if you want to try it 'offline' from source, clone 'cloud9' from github, then find this index.html
                          ~/Sites/mysite/cloud9/cloud9/support/ace/index.html
                          It should run the demo in safari, chrome, firefox and maybe IE9 or if you have local host or install cloud9 you can run it with node.js.
                          the ruby support is very good...
                          that's a console for ace at the bottom
                          I've almost finished a new theme called 'blendin', which adds the 'scrollable' line stripes and chameleon tendencies. I'm struggling with the SU interface at the moment and using cut'n'paste...
                            The Ace highlighter looks very good, too. Great to see a few of these popping up now. However, I just fixed my Ruby editor up with Codemirror, so I am not moving...
                            I'll have an updated version of my editor ready after a bit of testing. Here is a picture for now:
                            Cheers,
                            Alex
