    Syntax Highlighting in SU WebDialog
    13 Posts 4 Posters 1.8k Views 4 Watching
      driven
      something I've finally got to work, on the mac at least... not the editor bits yet, but highting using html5, css and js
      don't know if there's any interest so I thought I'd post and see... if there is I'll try and use TT's keyword-list to tweak the ruby version... this example just html dictionary
      theme-able...
        Jim
        Here's one:
        CodeMirror
        In-browser code editor
        (codemirror.net)
        Just saw a story that Google Code Hosting is now using this.
          driven
          cheers I'll have a look...
          • Dan RathbunD Offline
            Dan Rathbun
            @jim said:
            Here's one:
            CodeMirror
            (codemirror.net)
            (1) Go to this website: http://eloquentjavascript.net/chapter1.html
            (2) Scroll down till you see the sample JS codebox, that begins:
            var total = 0, count = 1;
            (3) on the right side of the codebox, click the "Load into Console" button...
            Look familiar Jim ?? πŸ˜›
            I'm not here much anymore.
              Jim
              I'm liking code mirror:
              http://i.min.us/ibK4jW.png
                Dan Rathbun
                looks good!
                  driven
                  that's great
                  I started to put it into yours as well, but haven't had much time
                  did you make a new SU Ruby library? or point it to something that exist?
                  can you PM me a WIP to see if the Mac likes it?
                    driven
                    finally got rid of that off-set box
                    hi Jim,
                    I had a chance to play with CodeMirror in your new box...
                    Managed to get a clean fit, after a lot of looking.
                    I added a choice of 3 colours (shades of grey, really).
                    Border reduction and text-color's are next on list.
                    The pushed inner html is where you can tweek some of the .editbox things and you only need the textarea for pre-loading a template, so I put it back in.
                    I'll work through and update everything to the latest versions before sending.
                    ... and then work around your windows only features...
                    • alexschreyerA Offline
                      alexschreyer Extension Creator
                      Howdy!
                      Can't believe it took me until now to find Codemirror... I am working on adding it to my editor as well. In case you're curious, here's a live preview:
                      (media.alexschreyer.net)
                      I also added the other languages - in case someone wants to edit an HTML web dialog file etc.
                      Cheers,
                      Alex
                      Author of "Architectural Design with SketchUp":
                      http://sketchupfordesign.com/
                        Dan Rathbun
                        Well it's relatively new is is not? When this topic started I think it was still listed as beta.
                        Looking really good Alex!
                        P.S.: Do you have a way to use standard Windows styling instead of that charcoal theme?
                          I still have to make the light and dark themes work. I started with the dark theme first...
                          Because Codemirror has an autocomplete function, I am looking into implementing this, too. What is the function that gives me access to all available methods in SU? I tried the following one but the list is limited to the Sketchup object.
                          puts Sketchup.methods.sort.join("\n").to_s
                          Cheers,
                          Alex
                          P.S. I put in the request to disable the single undo.
                            driven
                            hi Alex, and all
                            just to muddy the waters, after trying to get Codemirror to play nice inside SU on the mac I've been working on Ace editor http://ace.ajax.org/ and it's fantastic... very well supported and with some tweaking, usable 'offline'. It's the same 'engine' in cloud9 which everyone should try out .
                            The css may not work the same on PC's but the js should and for now I'm only after a Mac solution, if you want to try it 'offline' from source, clone 'cloud9' from github, then find this index.html
                            ~/Sites/mysite/cloud9/cloud9/support/ace/index.html
                            It should run the demo in safari, chrome, firefox and maybe IE9 or if you have local host or install cloud9 you can run it with node.js.
                            the ruby support is very good...
                            that's a console for ace at the bottom
                            I've almost finished a new theme called 'blendin', which adds the 'scrollable' line stripes and chameleon tendencies. I'm struggling with the SU interface at the moment and using cut'n'paste...
                              The Ace highlighter looks very good, too. Great to see a few of these popping up now. However, I just fixed my Ruby editor up with Codemirror, so I am not moving...
                              I'll have an updated version of my editor ready after a bit of testing. Here is a picture for now:
                              Cheers,
                              Alex
