    Problem with camera
    5 Posts 2 Posters 187 Views 2 Watching
    • H Offline
      hlinik
      Hi I have problem with the camera I hope that someone from the Group will hellp me I will be grateful look from front and right is ok but once the camera turned to the left as if I'm cut off from the picture please can someone advise what is wrong?
      http://img141.imageshack.us/g/22931419.png/
      picture on left is ok but picture on right looks as a cut off pls where is a problem?
        Hi Hlinik,
        As much as I can see from those small images Imageshack allows me to see, it looks like it's clipping (which often happens with large models like that). Have a look at Google's suggestions to see if something works.
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36261
        • H Offline
          hlinik
          @gaieus said:
          Hi Hlinik,
          iam trying taht but not funkcion
            Are you in parallel projection camera view by any chance? You can also fix the FOV factor by using the Zoom tool (Z) and holding down the shift key. Move the tool with the left mouse button pressed up and down the screen to see if it comes back.
            • H Offline
              hlinik
              yea men iam useing zoom tool with shift and its ok now reall thx men
