    Corinthian order
    55 Posts 17 Posters 17.1k Views 17 Watching
    • orgelfO
      orgelf
      excellent work Michaliszissiou !!
      "as always" as a lot of people said before πŸ˜‰
      http://www.orgelf.com
      • michaliszissiouM
        michaliszissiou
        Thank you orgelf
        Testing a new blender build here, using just one subdivision for displacement but using the same displacement map as bumps. Similar to new modo501 solution for fast renders. Not so crisp but really fast render (10 sec) Added SSS and indirect lighting.
        http://www.mediafire.com/imgbnc.php/ba4e594ab41c011f7c2d574380312271a62efcdcbdc8e5cecb26ec7c13872e176g.jpg
          Virtual stones carving at the top! 😎
          • orgelfO
            orgelf
            excellent ! πŸ˜„
            which build did you use ?
            • michaliszissiouM
              michaliszissiou
              thanks orgelf, r35474. have a closer look in textures palette when nor is enabled (negative values in this case)
              Another one, this at 40k, one sub for displ and the rest as new blender bumps. A 30 sec render.
              http://www.mediafire.com/imgbnc.php/18831fc3e109bc67c4c844d31fb75bc3d8c912c6bc83ab55b4479c962a8080226g.jpg
              • N
                nomeradona
                now i cant follow the workflow. too many new things to me. nevertheless you are far far so far with your workflow. congratulations michalis/ πŸ‘
                • michaliszissiouM
                  michaliszissiou
                  Hi nomer πŸ˜„
                  Thanks, yeah, its a little complicated workflow. It has to as dealing with hi definition sculpting, decimated and still trying to render all these details. Blender is an experimental project and will always be so. For advanced users. But it has lot of fun.
                  • FrederikF
                    Frederik
                    Can't see the image... πŸ˜•
                    Cheers
                    Kim Frederik
                    • michaliszissiouM
                      michaliszissiou
                      And a fast hdr lighted blender render in 30 sec (1920 px)
                        We can see the 2 pictures with rapture! 😎
                        • michaliszissiouM
                          michaliszissiou
                          sorry frederik
                          I'll start hatting all these servers like media fire, like dropbox, like... I don't know how these work, an unpredictable behavior for me. Sorry again.
                          Please, I need some help, can you see this picture here?
                          http://dl.dropbox.com/u/24090090/aphroditehdr2.jpg
                          • FrederikF
                            Frederik
                            Yes - now I can also see the images... πŸ‘
                            May I suggest that you use the board attachment system in the future...
                            This is also to avoid images getting lost in the future when using 3rd party hosts... πŸ˜‰
                            Cheers
                            Kim Frederik
                              rv1974
                              I saw your stuff on zbrush central. Well man this is something outstanding. Respect! πŸ‘
                              I guess the artisan indeed looks a bit lol from your level
                              • orgelfO
                                orgelf
                                yep, I see your pictures . πŸ˜„
                                Very impressive ! πŸ‘
                                • michaliszissiouM
                                  michaliszissiou
                                  thanks frederik, of course I'll use board att in the future. Its just a test. Though ICC profiles are preserved this way.
                                  rv1974, thanks, you can't compare artisan with the blender-3dcoat-zbrush combo, you can't compare SU either. But artisan is easy to use and -which is important to me- exports friendly to zbrush meshes. So its easy to fast sculpt some base in SU, export for broad sculpting and import again.
                                  Try an interior scene modeling and start thinking otherwise, here SU is perfect. It took me a week to start modeling in SU and 1.5 year to learn the combo, still learning. Many ways to skin a cat. πŸ˜†
                                    sepo
                                    Looks good ...must give blender a whirl.
                                    • michaliszissiouM
                                      michaliszissiou
                                      thank you orgelf, we probably posted same time. sorry.
                                      hey thanks sid, this 'must' is killing me... πŸ˜†
                                        sepo
                                        lol.... I know, IO know, I keep promissing ....ok one of these days....
                                        • 3 / 3
