    Corinthian order
    55 Posts 17 Posters 14.0k Views 17 Watching
    • michaliszissiouM Offline
      michaliszissiou
      Thank you orgelf
      Testing a new blender build here, using just one subdivision for displacement but using the same displacement map as bumps. Similar to new modo501 solution for fast renders. Not so crisp but really fast render (10 sec) Added SSS and indirect lighting.
      http://www.mediafire.com/imgbnc.php/ba4e594ab41c011f7c2d574380312271a62efcdcbdc8e5cecb26ec7c13872e176g.jpg
        Virtual stones carving at the top! 😎
        • orgelfO Offline
          orgelf
          excellent ! πŸ˜„
          which build did you use ?
          http://www.orgelf.com
            michaliszissiou
            thanks orgelf, r35474. have a closer look in textures palette when nor is enabled (negative values in this case)
            Another one, this at 40k, one sub for displ and the rest as new blender bumps. A 30 sec render.
            http://www.mediafire.com/imgbnc.php/18831fc3e109bc67c4c844d31fb75bc3d8c912c6bc83ab55b4479c962a8080226g.jpg
            • N Offline
              nomeradona
              now i cant follow the workflow. too many new things to me. nevertheless you are far far so far with your workflow. congratulations michalis/ πŸ‘
                michaliszissiou
                Hi nomer πŸ˜„
                Thanks, yeah, its a little complicated workflow. It has to as dealing with hi definition sculpting, decimated and still trying to render all these details. Blender is an experimental project and will always be so. For advanced users. But it has lot of fun.
                • FrederikF Offline
                  Frederik
                  Can't see the image... πŸ˜•
                  Cheers
                  Kim Frederik
                    michaliszissiou
                    And a fast hdr lighted blender render in 30 sec (1920 px)
                      We can see the 2 pictures with rapture! 😎
                        michaliszissiou
                        sorry frederik
                        I'll start hatting all these servers like media fire, like dropbox, like... I don't know how these work, an unpredictable behavior for me. Sorry again.
                        Please, I need some help, can you see this picture here?
                        http://dl.dropbox.com/u/24090090/aphroditehdr2.jpg
                        • FrederikF Offline
                          Frederik
                          Yes - now I can also see the images... πŸ‘
                          May I suggest that you use the board attachment system in the future...
                          This is also to avoid images getting lost in the future when using 3rd party hosts... πŸ˜‰
                          Cheers
                          Kim Frederik
                            rv1974
                            I saw your stuff on zbrush central. Well man this is something outstanding. Respect! πŸ‘
                            I guess the artisan indeed looks a bit lol from your level
                            • orgelfO Offline
                              orgelf
                              yep, I see your pictures . πŸ˜„
                              Very impressive ! πŸ‘
                                michaliszissiou
                                thanks frederik, of course I'll use board att in the future. Its just a test. Though ICC profiles are preserved this way.
                                rv1974, thanks, you can't compare artisan with the blender-3dcoat-zbrush combo, you can't compare SU either. But artisan is easy to use and -which is important to me- exports friendly to zbrush meshes. So its easy to fast sculpt some base in SU, export for broad sculpting and import again.
                                Try an interior scene modeling and start thinking otherwise, here SU is perfect. It took me a week to start modeling in SU and 1.5 year to learn the combo, still learning. Many ways to skin a cat. πŸ˜†
                                  sepo
                                  Looks good ...must give blender a whirl.
                                    michaliszissiou
                                    thank you orgelf, we probably posted same time. sorry.
                                    hey thanks sid, this 'must' is killing me... πŸ˜†
                                      sepo
                                      lol.... I know, IO know, I keep promissing ....ok one of these days....
                                      • 3 / 3
