    Virtual entities or model
    3 Posts 2 Posters 394 Views 2 Watching
    • T
      TheDro
      I was wondering if it was possible to create a "virtual" entities or model variable where I can make lines and faces without affecting the model I'm working on. The reason for this is that I want to create a cube like this:
      	def cubecomp(x,y,z)
      		orig = Geom;;Point3d.new 0,0,0
      		pts = []
      		pts[0] = orig
      		pts[1] = orig + x
      		pts[3] = orig + y
      		pts[2] = pts[1] + x + y
      		cubeface = entities.add_face pts
      		cubeface.pushpull - z.length, true
      		cube = cubeface.all_connected
      The potential problem I'm afraid of is that if one of the vertices of the cube is on an edge that is already in the model, I will select it with the all_connected method. What I would like to do is something like virtualEntities = Entities.new and use this to build the cube. Later, I want to copy this cube to several different locations.
      Does anyone know if something like this is possible or if there is a safe work around?
        This might be better in the Ruby sections...
        In the meanwhile... It won't work as show as cubeface = entities.add_face(pts) doesn't have entities defined.
        The reference 'entities' could be model.entities or model.active_entities BUT as you surmised it could result in a clash with preexisting geometry...
        It's best in these circumstances to add the new geometry into a new group so it remaining unconnected to other stuff you can always explode the group afterwards if you must have the contents in a particular entities set - or make a component definition etc.
        To add a group use
        ents=model.active_entities group=ents.add_group() gents=group.entities
        then add things to 'gents'...
        cubeface=gents.add_face(pts)
        etc etc You have references to 'group' and 'gents'... just as you started with 'model' and 'active_entities'...
        The geometry inside 'group' is separated from the rest of the model unless you use group.explode...
        • T
          TheDro
          Sweet. Thanks a lot TIG, that should work.
