πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Any plugin that can create circular scenes around a circle?
27 Posts 11 Posters 2.9k Views 11 Watching
  • H Offline
    hgdn
    Could anyone tell me somewhere that has a plugin that can create circular scenes around a loop and its camera aiming at center point of circle? Normally, I create one scene at a time and each different let say 30 degree with circle has 12 sides, the more scenes created the smoother the outcome but take sometime to create this tedious boring task....
    As I just try to use object2vr application (http://gardengnomesoftware.com/object2vr.php ) to create an object movie with rendered scene images created by SU+render software and put all sequent rendered images into object2vr to have rendered movie.
    I already tried pano2vr it is so great application and now I am trying to use object2vr as well.
    Any idea thanks!
      Strangely enough I am busy doing two of these exact projects at the moment. I am using 120 renders, this is to be used on an ipad for product interaction.
      The thing is you need to rotate the product, not the camera that way the reflections interact and give a better sense of you controlling the rotation at the end.
      I used Thea render, and created the animation path 12 seconds, 30 degrees each second, 15 frames per second.
      What rendering app are you intending to use?
      • H Offline
        hgdn
        Thanks Peter for giving instructions,
        Twilight is my app, I have never done animation before because of lengthy rendering time required that scares me the most, some people said take a few days to render and produce only a few seconds movie!
        I find pano2vr app is a quick way to show internal result, just one spherical rendered image and good enough to create the movie.
        Now I am thinking is it possible to use object2vr app to show external building with 12 or 24...rendered scene images to create movie?
        But based on what you said it doesn't work in term of controlling reflection interact each other, right?
        I just got a Thea app but I have not given it a try yet, do you know where I can get animation/texture displacement...tutorials as they got only some tutorials on their web site but not all and I saw a lot of your amazing rendered works of using this app, wow! It seems not much vid tutorials about this, found only one or two on youtube?
          Didier Bur
          Have you tried VR exporter ? http://rhin.crai.archi.fr/rld/plugin_details.php?id=467
          DB
            Jim
            There's this bit of code that creates SketchUp Scenes. Full discussion .
            • H Offline
              hgdn
              @didier bur said:
              No, I am using it now and does this plugin provide a way to render images prior to put them in object2vr? As I saw all images created just for using nonrendered images movie??
              As using cubic pano plugin, 6 scenes created automatically and rendered all of them and put in pano2vr for rendered movie. I find this way is so simple and get fast result because I am not familiar with animation yet!
              Any vid tut around of this plugin to understand easier?
              Thanks Didier
              • H Offline
                hgdn
                Thanks Jim for sending a link of full discussions of this topic dated back years ago I will check to see that relates to mine.
                Disoriented newbie!
                  hgdn,
                  What is the product you want to render?
                  Are you going to use HDRi for lighting?
                  24 renders might be too few for a smooth result, I'd say at the very least 60 is needed.
                  • H Offline
                    hgdn
                    @solo said:
                    hgdn,
                    Thearender is what I am interested in now but I don't know enough it yet, specially animation!
                    Yes, using HDRi for scene render
                    To render 1 scene takes at least 1hr or more depending on what size....as you said to be good smooth quality outcome required at least 60 renders...take up a couple days to finish, breathless omg!
                      A couple of days is unfortunately not uncommon. Rendering does take a bit of time, and if you multiple frames to render, then it really gets crazy.
                        Nah, you can run it BSD, I just completed a 12 minute animation in less than 4 hours. For what you are doing (product rotation) I'm sure you can set it up to render fast.
                        Want to share the model and I will take a look and give a better idea?
                        • H Offline
                          hgdn
                          Yes really crazy as the file getting bigger and longer required a massive effort and patience. Thumbs up for all amazing 3d design render movies done and posted on youtube!
                            Let me set a quick scene up and render 120 frames, give me an hour or so and I will show you.
                            I cannot exhibit my clients project so I'll use one of my cartoon characters instead.
                              Okay, done.
                              Here is the final low resolution animation as well as a video of the making of it.
                              Hope it helps.
                              [flash=700,400:10bk5u4x]http://vimeo.com/moogaloop.swf?clip_id=20959197[/flash:10bk5u4x]
                              Making of:
                              [flash=700,400:10bk5u4x]http://vimeo.com/moogaloop.swf?clip_id=20959296[/flash:10bk5u4x]
                              • N Offline
                                notareal
                                solo that a great tutorial. Another option in Thea would be rotating camera around the target, but it's up to scene if this is a viable alternative to turn table. Rotating the camera does allow cache reuse and even faster rendering, as only camera is changed (not the scene, like with the turn table).
                                Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                  Bob James
                                  Pete/hgdn,
                                  I am really, really interested in this because I have just been commissioned to do a big project to provide virtual tours and "fly-over/around" scenes. Since I've never done that before I had to get smart really quick on software and techniques (nothing like pressure to motivate learning πŸ˜„ )
                                  Since I'll be using both SU models and photo panoramas, for virtual tours I've settled on the following:
                                  For SU models:
                                  John Wehby's cubicpanout.rb
                                  Thearender
                                  GoCubic
                                  For photo panoramas:
                                  object2vr
                                  pano2vr
                                  PTgui
                                  For SU models I'm using cubicpanout.rb, then Thea and, finally, GoCubic. I tried using pano2vr for the cubicpanout output, but have not yet figured out what settings to use for a "non-overlapping" set of pictures. But GoCubic works fine.
                                  The big deal here is that nige generously clued me into Kerkythea scripts that allow me to do "automatic" BSD rendering of multiple scenes from cubicpanout.rb in Thea. You just run the script and walk away and let Thea do its thing for however long - but you don't have to be there while it does it (e.g., overnight).
                                  I then put the rendered scenes into GoCubic.
                                  For fly-around/overs
                                  I was going to use flightpath.rb and the follow the same workflow in Thea, but...
                                  Pete, I know you asked me months ago if I'd be doing any animation in Thea. At the time I didn't foresee what I'm doing now. Now I'm very interested in learning how πŸ˜’
                                  Anything you would care to share on how that's done would certainly be appreciated.
                                    I never thought about the cache reuse, yeah, makes a lot of sense, the above rendered at 8 seconds per frame BSD (that's uber fast)
                                      Bob, You may just be in luck.
                                      Somebody (no names mentioned) is right now as we speak creating a script that will allow you to take your SU animation into Thea...ssshh! πŸ˜‰
                                      Happy days are here soon.
                                      • H Offline
                                        hgdn
                                        Peter makes people smiling today, great sharing πŸ˜† !!!
                                          Bob James
                                          πŸŽ‰
                                          Also, thank you for the tutorial - that really helps πŸ‘ For some reason I didn't see it as I went through the first time 😳
                                          One showing notareal's suggestion of the camera being rotated would be nice too πŸ˜†
                                          1 / 2
