    Ruby <-> cmd command line: How to get return value?
    4 Posts 3 Posters 4.5k Views 3 Watching
      Aerilius
      Hello,
      I'm just beginning with ruby and have not much practice with it. My aim is to launch a command on Windows cmd (actually later a bash shell) and get a return value into the ruby console. I have found how to launch external programs or for example a batch file, however I didn't find if it's possible to receive a result from the batch script.
      Is there another command or parameter necessary in ruby or do I have an error in the batch script (exit %a%)?
      ruby:
      x="E:/new_batch.bat" UI.openURL(x)
      returns only true
      batch file:
      @echo off
      set a="Hello World"
      ECHO %a%
      exit %a%
      • Dan RathbunD
        Dan Rathbun
        In the console... you can use backquoted strings to run shell commands.
        **dir**
        An aleternate to using backquotes, is to use %x dilimiters. The delimiter character is your choice, or you can choose one of the bracket sets ( ), [ ] or { }, ex:
        listing = %x[dir]
        So a backquoted shell string will return the STDOUT from the shell command (in the example above I store it in the string reference listing.)
        And, before you ask, there's a bug / annoyance in Ruby where we can't suppress having the shell window pop up for a half-second or so.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Also I see you are using Environment variables.
          The set of Environment variables is accessed from Ruby via the ENV hash.
          So on my system:
          ENV['USERNAME']
          Dan
          There are differences between MAC and PC... on a MAC it would be:
          ENV['USER']
          To list the Enviroment variables from Ruby, you can do (cross-platform):
          ENV.each {|k,v| puts "#{k} = #{v}" }
          but it's simpler, to do (for PC):
          set``
            This might be clearer
            ruby:
            x="E;/new_batch.cmd"
            UI.openURL(x)
            returns true
            batch file:
            @echo off
            echo "Hello World"
            echo
            pause
            exit
            Waits for you to close it...
            x="file:/E:/new_batch.cmd"
            will also work...
            Writing the bat or cmd file to the root directory would probably be better if it were into a Temp folder ?
