    Rhino and Thea
    17 Posts 6 Posters 2.5k Views 6 Watching
      sepo
      Hi all
      I have not been posting much for a while. I hope not against the rules to post Rhino model and Thea render.
      I did this model to prepare tut for my Product Design students.
        dedmin
        Rhino πŸ‘ Still, the plugin is rough, but there is a lot a potential - good job! So far the best integrated render is Brazil - but too complicated for my taste.
        • E
          Ecuadorian
          Another πŸ‘ from me. Have you also tried MoI 3D, Sid?
          -Miguel Lescano
            sepo
            Thanks Ecuadorian
            I am really liking Rhino....Moi 3d I have not tried yet but will do.
            • soloS
              Looking great Sid, did you use the rhino2Thea exporter?
                sepo
                Thanks Pete... Yes I used RT plugin. It converted geometry without hitch. Some of the fillets are 0.2 mm radius 😲. Something which our beloved SU can't handle. Riccardo is working hard on the plugin. We already have available Open GL material and Environment (HDRI) previews within Rhino.... Next iteration of the plugin should be quite good. Geometry created with Grasshopper and T-Splines plugins travels fine.
                • michaliszissiouM
                  michaliszissiou
                  Looking great indeed. πŸ‘
                  Now, can you please explain what all these have to do with SU? Especially if you used the rhino2thea exporter.
                  Probably because we're old friends and because lot of people uses thea.
                  you didn't expect it from me sid. 🀣
                  I never posted renders that they didn't have an even simple relationship with SU. Though some members complained that there wasn't really.
                  My real crits now. I see lot of n-gons on this topology. This wont make it easy to use displacement maps in some cases.
                  The old school "box modeling" is the best way to go. Loop cuts etc. Avoid n-gons as possible. They may make your modeling easy but they tend to be an issue in the end. This goes for SU as well. Artisan plugin is the first SU-addon that produces a clean mesh, indeed.
                    sepo
                    Haha...you cheeky sod... Well there was Bonsai thread...and I did ask if it OK. If mods are thinking this is not on ..fair enough.
                    As far as topology is concerned here we have nurbs...infinetely smooth and surfaces are G3 continuity....so do not see your point. Maybe if I would bring it in SU than yes mesh would be dense on conversion to .3ds or .obj. But what is the point of it? You can render directly from Rhino using Vray, or Brasil, or as plugin to Maxwell Studio, now Thea etc.
                    • michaliszissiouM
                      michaliszissiou
                      In the end, when you render it, you have tri. Nothing else. So, don't expect to have control over subdivisions when displacement happens. Stretched faces!
                        sepo
                        Possibly...but I can always convert to mesh within rhino to check and if needed I can optimise (called rebuild) in Rhino. Just checked in Rhino...no stretched triangles. I can also convert to T=splines and rebild them afresh , remove any stars (if there is any) and convert to nurbs if I wish so or render directly as T-splines. The choice is huge there.
                          dedmin
                          On that picture there are not any meshes - only Rhino surfaces. And as far as I know Rhino doesn't support n-gons - just triangles and guads.
                          http://news2.mcneel.com/scripts/dnewsweb.exe?utag=&cmd=xsearch&group=rhino.plug-ins&group=rhino.plug-ins&key=ngon+mesh&action=Search
                            sepo
                            Again Rhino + Thea.... Iphone 4....no pp...raw render.
                            • michaliszissiouM
                              michaliszissiou
                              lighting is great now!!! πŸ‘
                              No meshes? what do you mean?
                                sepo
                                What he means is those isocurves you see are only for reperesentation purpose. What you see in Rhino image are nurbs surfaces not meshes. Rhino can show meshes as well but either when you import say SU files, .obj files etc. or convert nurbs to meshes.
                                Thanks....I changed the ISO πŸ˜‰
                                  sepo
                                  Slightyly differrent render. Added crf, vignette and glare in Thea. Also moved screen for 0.3mm down and added separate glass surface on top..
                                  • michaliszissiouM
                                    michaliszissiou
                                    Glass works fine now. πŸ‘
                                    What confuses me is this casted shadow on ground face.
                                    • N
                                      notareal
                                      Some soft shadows would look better, perhaps not enabled for the light source?
