    Rhino and Thea
    17 Posts 6 Posters 2.5k Views 6 Watching
    • michaliszissiouM
      michaliszissiou
      Looking great indeed. πŸ‘
      Now, can you please explain what all these have to do with SU? Especially if you used the rhino2thea exporter.
      Probably because we're old friends and because lot of people uses thea.
      you didn't expect it from me sid. 🀣
      I never posted renders that they didn't have an even simple relationship with SU. Though some members complained that there wasn't really.
      My real crits now. I see lot of n-gons on this topology. This wont make it easy to use displacement maps in some cases.
      The old school "box modeling" is the best way to go. Loop cuts etc. Avoid n-gons as possible. They may make your modeling easy but they tend to be an issue in the end. This goes for SU as well. Artisan plugin is the first SU-addon that produces a clean mesh, indeed.
        sepo
        Haha...you cheeky sod... Well there was Bonsai thread...and I did ask if it OK. If mods are thinking this is not on ..fair enough.
        As far as topology is concerned here we have nurbs...infinetely smooth and surfaces are G3 continuity....so do not see your point. Maybe if I would bring it in SU than yes mesh would be dense on conversion to .3ds or .obj. But what is the point of it? You can render directly from Rhino using Vray, or Brasil, or as plugin to Maxwell Studio, now Thea etc.
        • michaliszissiouM
          michaliszissiou
          In the end, when you render it, you have tri. Nothing else. So, don't expect to have control over subdivisions when displacement happens. Stretched faces!
            sepo
            Possibly...but I can always convert to mesh within rhino to check and if needed I can optimise (called rebuild) in Rhino. Just checked in Rhino...no stretched triangles. I can also convert to T=splines and rebild them afresh , remove any stars (if there is any) and convert to nurbs if I wish so or render directly as T-splines. The choice is huge there.
              dedmin
              On that picture there are not any meshes - only Rhino surfaces. And as far as I know Rhino doesn't support n-gons - just triangles and guads.
              http://news2.mcneel.com/scripts/dnewsweb.exe?utag=&cmd=xsearch&group=rhino.plug-ins&group=rhino.plug-ins&key=ngon+mesh&action=Search
                sepo
                Again Rhino + Thea.... Iphone 4....no pp...raw render.
                • michaliszissiouM
                  michaliszissiou
                  lighting is great now!!! πŸ‘
                  No meshes? what do you mean?
                    sepo
                    What he means is those isocurves you see are only for reperesentation purpose. What you see in Rhino image are nurbs surfaces not meshes. Rhino can show meshes as well but either when you import say SU files, .obj files etc. or convert nurbs to meshes.
                    Thanks....I changed the ISO πŸ˜‰
                      sepo
                      Slightyly differrent render. Added crf, vignette and glare in Thea. Also moved screen for 0.3mm down and added separate glass surface on top..
                      • michaliszissiouM
                        michaliszissiou
                        Glass works fine now. πŸ‘
                        What confuses me is this casted shadow on ground face.
                        • N
                          notareal
                          Some soft shadows would look better, perhaps not enabled for the light source?
