    Calculating the final vertices of a nested face
    3 Posts 2 Posters 474 Views 2 Watching
      shotgunefx
      I've tried to boil this down to a small as example as possible, what I need to do is given a face, calculate it's absolute final position in XYZ (taking into account transforms, etc). It's for a paint tool I'm working on that works (and aligns regardless of grouping. I happen to use Sketchup for game mapping and the particulars of the exporter force pretty much everything to be a group.
      A less than compelling example video of the paint tool http://www.youtube.com/watch?v=hb63D7Cmt50
      I've mostly got it working, except for the origin is off when dealing with groups within groups, there is just something I'm not grokking here. So after many hours of head scratching, I figured I'd see if anyone can enlighten me.
      So I take the face, I walk up the hierarchy, adding transforms, (and in theory, transformation origins) and compute the new points. The code below just adds the transformation.origin, I know this is wrong, and it's what trying to solve. I've tried a dozen things (transforming them by the container, etc,) but there is just something I'm not understanding.
      Here's the code
      module WALK
      def WALK.setface
          model = Sketchup.active_model
          @newg = model.entities.add_group
          @s = nil
          if model.selection.empty?
              UI.messagebox "Selection empty"
              return nil
          else
              if model.selection[0].is_a? Sketchup;;Face
                  @s = model.selection[0]
              else
                  UI.messagebox "Face not selected"
      # make sure groups are unique
      Sketchup.active_model.definitions.each{|d|d.instances[1..-1].each{|i|i.make_unique}if d.group? and d.instances[1]}
      def WALK.main
           WALK.GetParent(@s)
      def WALK.GetParent(ent)
         Sketchup.active_model.start_operation("Walk")
         m = model.materials.add "test"
         m.color="red"
         orig = ent
         tpos = Geom;;Point3d.new 0,0,0  # keep track of origin
         trans = Geom;;Transformation.new(Geom;;Point3d.new(0,0,0))    # add transforms to this
         while (ent.respond_to?('parent') )   # walk up hierarchy
              if ((ent.is_a? Sketchup;;ComponentDefinition))
                  if ent.group?
                      t = ent.instances[0].transformation # Get the group's transform
                      tpos += t.origin.transform(trans).to_a  # !!!WRONG
                      trans *= t  # combine transforms
                  ent =  ent.instances[0]     # become the instance
              ent = ent.parent
         vertices = orig.outer_loop.vertices
         newverts = []
         vertices.each do |v|
              np = v.position.clone
              np+= tpos.to_a      # !!! Wrong
              np.transform! trans
              newverts.push  np
         f = @newg.entities.add_face newverts    # create the face
         f.material=m
         Sketchup.active_model.commit_operation
      end # end mod
      if !file_loaded?(__FILE__)
        UI.menu("Plugins").add_item("Select Walk Face") { WALK.setface }
        UI.menu("Plugins").add_item("Make Walk Face") { WALK.main }
      file_loaded(__FILE__)
      It adds two items to the plugin menu
      Select Walk Face and Make Walk Face
      Take the example here
      http://farm6.static.flickr.com/5293/5494975921_63bd7d0e3a_z.jpg
      The geom looks like this...
      Group
      --Group
      ----Wide Cylinder faces
      --Group
      ----Group
      ------Cube faces
      ----Group
      ------ Tall Cylinder Faces
      Seeing backing out of a group clears the selection, here's where Select Walk Face comes in. Click down into the inner group of the cube and select a face and then select Select Walk Face, this simply stashes the face for Make Walk Face
      Now if you actually ran Make Walk Face here, it works fine, making a new face, respecting transforms and in the right place.
      But back all the way out of the group and run Make Walk Face
      and you get this....
      http://farm6.static.flickr.com/5259/5494975933_05f17d3207_z.jpg
      If you've read this far, I commend you πŸ˜„
      Any insight on what I'm not understanding would truly be appreciated.
      -Lee
        Have you tried tr=container.transformation.inverse and applying it to the initial object and then iterating and getting/setting the transformation for the container's container etc until you get to the model level...
          shotgunefx
          That didn't seem to work (inverse), though I may very well have misunderstood what you meant, but what you said gave me an answer anyway. By applying the transform to the points at each container successively, it works perfectly! (or at least in every test so far)
          Which is how I should have tried it initially but I was thinking from a performance standpoint, and forgot the old adage "premature optimization is the root of all evil"
             m.color="red"
             orig = ent
             vertices = orig.outer_loop.vertices.map {|v| v.position.clone}
                      if ent.group?
                          vertices.each_with_index do |v,i|
                              vertices[i].transform! t
                  ent = ent.parent
             f = @newg.entities.add_face vertices    # create the face
             f.material=m
          Thanks again for the help!
