[solved] Scale to length
hello again, sorry for asking another question while my other is still not resolved~ but I had another question that has come up from another step of my tool.
Can I use a length to create a scale transformation? Basically I am trying to scale a component to the length of the line? scale transformation requires a scale factor....
I was thinking I could take then length of the line, ie 12, and then divide it by the length of the component, ie 3, to get a scaling factor of 4? However I got stumped on this part due to units...my component measured 6' 1/4" not sure how I put this value into a variable I can use to divide my line length...
is their an easier way? and if not...could someone enlighten me on how to use the units? (I guess I could just switch the model to mm, but I would rather not as its not intuitive for community members at the urban design scale [my audience])
thanks again!
Sketchup uses Inches internally.
Class
Lengthis in inches. See:
http://code.google.com/apis/sketchup/docs/ourdoc/length.htmlFor conversion between defferent units use the methods of
Numeric(which is the superclass ofFloat, which is the superclass ofLength.) So both those subclasses inherit the conversion methods.
http://code.google.com/apis/sketchup/docs/ourdoc/numeric.htmlJust use a
Floatfor fractions:
6.25Use can get your number from complex fraction like so:
var = 3 + (15.0/32.0)But the fractional display is only in the dialogs and the VCB (Measurements inputbox).. when you get the length of the line in Ruby, it will be a
Float. -
As said...
Irrespective of the Model Info > Units settings the length of the line and the length of the component-instance are always in 'inches' as remembered inside Sketchup [decimal-number], so diving one by the other gives a scaling factor as a decimal number [.to_f] that you can use in the scaling-transformation... -
Off topic, but I like this one-liner:
def inch2modelUnit(v) return [v,v.to_feet,v.to_mm,v.to_cm,v.to_m][Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]] end -
Ah i see the to_f worked perfectly, for some reason I was trying to convert it into feet with decimal places last night, not sure why....my brain was not quite as sharp after about 15 hours of coding/writing last night~
cheers
Korbin
