    Thea Render
    49 Posts 15 Posters 5.6k Views 15 Watching
    • olisheaO Offline
      olishea
      shame. The SU exporter didnt work properly for mac a few months back.....it was quickly resolved and works perfectly now....it takes seconds to export a huge model. i'm surprised you have any problems. Thea is absolutely fantastic, its got more than everything you need and the speed is staggering. πŸ˜„
      oli
      • olisheaO Offline
        olishea
        have you emailed the support guys? so let me get it straight...its just your SU exporter that doesn't work? have you tried exporting a simple SU model first?
        oli
        • soloS Offline
          Bruce, which exporter are you using?
          I am under the impression that all issues are fixed, I too had problems but the last two versions have solved all my issues. (win 7 64, IE9, SU8)
          • N Offline
            notareal
            The bad news is the exporter which I was kinda looking forward to...duh..doesn't work on my box
            so for now the in-SU material set-up is not going to happen.
            I am watching the Thea forum for fixes or suggestions although so far the best advise is to rebuild or repair win7, +IE...etc. My microsoft tools as well as the arsenal of on-line microsoft troubleshooters are all telling me that IE9 and Win7 are working perfectly and that is evident in all other apps that I run.
            There been some rare UI corruptions on SU2Thea (one was possible result of a virus), that for my knowledge have not been able to recreate by dev. I think Tomasz will need some detailed info of your system, perhaps even IE registry export. You really have to contact with him.
            Perhaps you could create another user account and try if SU2Thea will work fine with it. Then some user profile related issues (or IE settings) can be eliminated.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              Yes, I read this on the Thea > SU subforum, too (from one or two persons). And there is a Hungarian guys down inthe Hungarian forum with some similar issues about the exporter, too.
              By the way, Bruce, don't you happen to also have a Twilight license? (Material settings with Twilight are exported fine with the Twilight-to-Kerkythea export option and import also fine to Thea).
              Well, anyway, the Thea expo9rter already does (and will) have a bunch of cool settings that this issue must be resolved, not worked-around.
                That is mypost to the Thea forum.
                And I was just about to post this:
                *Bruce, this is a very hot (read new) topic in the Thea forums:
                http://www.thearender.com/forum/viewtopic.php?f=19&t=4864
                The guy seems to have been able to solve his issue by creating a new user account (but read through, it is not too long).
                If this IS the solution for all, Notareal hit the nail on the head! πŸ‘*
                Could you guys stick to the same username all over the place?
                • N Offline
                  notareal
                  Have you changed some IE security settings from default? Disabled some scripting... used some ActiveX Kill Bits? Anything changed from default Win7/IE installation... maybe used registry cleaners? Or set some other browser as default, like crome? Anyhow, it's certainly promising that it's pinpointed to profile, at-least it does offer a workaround that does not require re-installation. Just a new profile... and find out what corrupts the profile.
                  • N Offline
                    notareal
                    Thanks notareal!!!! You are right...I added a new user profile and the Exporter works!!!
                    Now ...to find out how the profile got currupted....kinda scarry but I am back in business so thanks very much again notreal.
                    That is my post to the Thea forum.
                    My own win7 profile was currupt....funny, microsoft couldn't tell me but notareal could.
                    Well... I been working as a systems analyst. But usually I have no need to bother with IE related issues, thanks to strict policies.
                    • N Offline
                      notareal
                      Might be worth to browse trough IE related "Fix it" solutions http://support.microsoft.com/fixit/
                      • Chris FullmerC Offline
                        I had a problem with the exporter not working. Turned out it was a plugin conflict. For me it was one of the sun position plugins. I would recommend removing all other plugins and see if that fixes it.
                          Did you read my post Modelhead? I did have your exact same problem on a PC... ❗
                          • david_hD Offline
                            david_h
                            Question. . .
                            in making the purchase. . .do we buy the license at 158 Euros PLUS the plugin for SU at 19?
                            it's okay, I just need to know what I need to get it going.
                            Thanks.
                            D
                            • daleD Offline
                              dale
                              David
                              Yes you will require both if you want to export directly from SketchUp.
                                Thea is lots of fun once you get the hang of it. Then there's just all the basic rendering stuff to learn with materials - that's the stuff I really lack. I don't have a solid understanding of IOR, Fresnel, absorption, on and on. But thea is lots of fun. I've had some really encouraging success with it rather quickly.
                                • daleD Offline
                                  dale
                                  Fresnel? Isn't that in California?
                                  The manual is supposed to be coming with the release, as are more tutorials, but the response to questions on the forum is excellent, so please ask away (so that I quit looking so dumb 😳 )
                                  • david_hD Offline
                                    david_h
                                    I downloaded everything to give a test drive. .. but If I am going to buy i gotta do it in a week cuz the price goes up. Not a lot of time here. But I was so blown away by what Pete and others showed in Boulder that I am pretty sure I am going to go for it.
                                    Anyway, I can't seem to find the User manual page on the thea website. can anyone help me out?
                                    D
                                      dedmin
                                      It is inside Thea's installation directory - Manual.pdf
                                      • david_hD Offline
                                        david_h
                                        Ah yes. . I see that now.
                                        Duh 😳
                                        Thank you.
                                        • david_hD Offline
                                          david_h
                                          okay. . .so I got this thea desktop thing open and I am looking at it.
                                          scares me to death!
                                          It's okay though. I will get this. Just gotta read the book. (dammit πŸ’š )
                                          One thing. . .when I opened SU, i got a warning . .. i didn't know I did anything wrong when I downloaded the plugin. Any ideas? I assumed the plugin would install automatically where it was supposed to go. Is that not the case?
                                            dedmin
                                            I got the same - just reinstall the plugin.
                                            • 2 / 3
