    Artisan Plugin (SDS2).....Cave
    47 Posts 19 Posters 17.3k Views 19 Watching
    • Rich O BrienR Online
      That gives me the willies 😲
      • H Offline
        HFM
        Would be brilliant if it would glow in the dark like that in real life πŸ˜†
        • david_hD Offline
          david_h
          Capture.jpglooks so cool! I can't wait either!
          • olisheaO Offline
            olishea
            yeah i wouldn't need a light on my camcorder πŸ˜‰
            stop bastardizing my renders lol πŸ˜› πŸ˜†
            oli
            • michaliszissiouM Offline
              michaliszissiou
              Something its happening with this cave oli, I tried to tell you but you didn't listen. πŸ˜†
              Lot of weird creatures will visit it, I know.
              • david_hD Offline
                david_h
                Think of it as An "Homage"
                Its only cuz they are just so awesome.
                We're not WORTHY!!! πŸ˜›
                • olisheaO Offline
                  olishea
                  thanks man hehe, i'm making a tutorial for this scene...from modeling to rendering to photoshop touch-up. It could literally be made in minutes, although it took me hours of fannying around. πŸ˜†
                  oli
                  • StinkieS Offline
                    Stinkie
                    That's, like, totally awesome, as the Bard would've put it. πŸ˜„
                    • olisheaO Offline
                      olishea
                      it'll be done in march. very simple for rendering etc...there are only 2 materials, water and rock.
                      a view from above. look how clean the mesh is around the column caps, its completely homogenous, no intersecting or anything....thats a typical proxy to the right. Deleting internal faces helps create a clean result. (remove inner faces.rb). this is an early version of the model before I sculpted the floor, notice how it was flat.....you can paint contours into it. πŸ˜„ i removed the walls for clarity....they were made using the free hand tool, push pull and then artisan, about 5 minutes each.
                      http://i654.photobucket.com/albums/uu269/olishea/Picture59.png
                      just messing around:
                      http://i654.photobucket.com/albums/uu269/olishea/Artisan-1.jpg
                      a remake of pollen, to see if its possible in SU.
                      http://i654.photobucket.com/albums/uu269/olishea/pollen_sds2_colour.jpg
                      http://i654.photobucket.com/albums/uu269/olishea/pollen2.jpg
                      oli
                      • E Offline
                        Ecuadorian
                        To beta testers:
                        Does it behave like Wings 3D, where you can toggle from proxy view/smooth view with just a key press?
                        -Miguel Lescano
                        • daleD Offline
                          dale
                          Have we mentioned we can't wait.
                          Really cool stuff.
                          • olisheaO Offline
                            olishea
                            Ecuadorian: you can subsmooth in one click yes....it previews the geometry so you don't have to execute the command unless you are sure.
                            I used Wings3D a lot, thats why I remade some images just to see if SU can do it. Instead of using spheres I use geometric domes instead, resultant subdivision is always cleaner (for these ballsy images haha)
                            here is an image I used to help describe a uni project....an undulating, evolving programme moving between sites of potential intervention.
                            http://i654.photobucket.com/albums/uu269/olishea/5_final.jpg
                            oli
                              michaliszissiou
                              Nice last one oli. πŸ‘
                              A tip for box modeling:
                              Instead of using pushpull and remove inner faces rb, I found more helpful to use [F] command and move tool.
                              • olisheaO Offline
                                olishea
                                thanks michalis, yes you are right.
                                here is another scene I'm working on, kinda like the kunsthaus, graz. http://www.google.co.uk/images?hl=en&xhr=t&q=kunsthaus+graz&cp=11&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1934&bih=1102
                                http://i654.photobucket.com/albums/uu269/olishea/geo_retreat_inter.jpg
                                http://i654.photobucket.com/albums/uu269/olishea/geo_retreat_inter2.jpg
                                oli
                                  michaliszissiou
                                  I'm a little confused, this grid doesn't seem to follow geometry-topology. How is this possible?
                                  • olisheaO Offline
                                    olishea
                                    i intersected the geometry with a grid after subdivision....its just a WIP to get some framing in there, its not supposed to follow the topology
                                    oli
                                    • david_hD Offline
                                      david_h
                                      I don't have a lot of call in my daily workflow to design caves or sea monsters.. . .but this is gonna be so cool!
                                      Oli. .. Now yer just showin' off! πŸ’š
                                      • PixeroP Offline
                                        Pixero
                                        You mentioned "textured in SU" in your first post. Is there any texturing/UV tools in it?
                                        Also is it possible to revert back to the unsubsmoothed version for further editing?
                                        • olisheaO Offline
                                          olishea
                                          No UVs exactly. It was a really good seamless texture, its dirty concrete so its hard to tell if the alignment isn't correct. Any places where it was a bit distorted I used the paint brush tool in artisan. I have the material if anyone wants it, also the thea .mat file.
                                          If you were gonna do this properly, would slice the columns and the top and bottoms (using knife tool)....then cylindrically map the texture onto them. The walls and floor could just be textured seamlessly, no UVs.
                                          Pixero, you are given a preview of the subdivision so you don't actually have to execute the command. I just click space bar and it returns to the proxy. The preview will let you change the amount of iterations also....but once you have executed the subdivision/smoothing then you would have to 'undo' to get back to proxy.
                                          oli
                                          • soloS Offline
                                            Pixero, when you select to subdivide you get a preview and an option to contine (hit enter)
                                            See images, first the basic proxy:
                                            Then here is the 'Preview' of how it will look with 3 iriterations:
                                            And then finally how it looks after subdivision:
                                            • 2 / 3
