    Artisan Plugin (SDS2).....Cave
    47 Posts 19 Posters 18.5k Views 19 Watching
    • numbthumbN Offline
      numbthumb
      And you certainly did. Congratulations!
      Comfortably numb...
      • boofredlayB Offline
        boofredlay
        After creating Bobby Bubble I had fun with Oli's cave. ๐Ÿ˜„
          Roger
          Fred and Oli, together you have created the perfect image of how my sinuses felt for most of this week.
          http://www.azcreative.com
          • olisheaO Offline
            olishea
            yeah sorry roger....im always making grungey, snotty, obstructed scenes!
            maybe this will lighten your mood?
            can you tell what it is yet? lol
            oli
              numbthumb
              An excellent looking urchin?
              Comfortably numb...
              • olisheaO Offline
                olishea
                look closer! ๐Ÿ˜ฎ ๐Ÿ˜†
                or click to enlarge (so to speak) ๐Ÿ˜†
                oli
                  numbthumb
                  It still can prick, eh? ๐Ÿ˜†
                  Comfortably numb...
                    That gives me the willies ๐Ÿ˜ฒ
                    • H Offline
                      HFM
                      Would be brilliant if it would glow in the dark like that in real life ๐Ÿ˜†
                      • david_hD Offline
                        david_h
                        Capture.jpglooks so cool! I can't wait either!
                        • olisheaO Offline
                          olishea
                          yeah i wouldn't need a light on my camcorder ๐Ÿ˜‰
                          stop bastardizing my renders lol ๐Ÿ˜› ๐Ÿ˜†
                          oli
                          • michaliszissiouM Offline
                            michaliszissiou
                            Something its happening with this cave oli, I tried to tell you but you didn't listen. ๐Ÿ˜†
                            Lot of weird creatures will visit it, I know.
                            • david_hD Offline
                              david_h
                              Think of it as An "Homage"
                              Its only cuz they are just so awesome.
                              We're not WORTHY!!! ๐Ÿ˜›
                              • olisheaO Offline
                                olishea
                                thanks man hehe, i'm making a tutorial for this scene...from modeling to rendering to photoshop touch-up. It could literally be made in minutes, although it took me hours of fannying around. ๐Ÿ˜†
                                oli
                                • StinkieS Offline
                                  Stinkie
                                  That's, like, totally awesome, as the Bard would've put it. ๐Ÿ˜„
                                  • olisheaO Offline
                                    olishea
                                    it'll be done in march. very simple for rendering etc...there are only 2 materials, water and rock.
                                    a view from above. look how clean the mesh is around the column caps, its completely homogenous, no intersecting or anything....thats a typical proxy to the right. Deleting internal faces helps create a clean result. (remove inner faces.rb). this is an early version of the model before I sculpted the floor, notice how it was flat.....you can paint contours into it. ๐Ÿ˜„ i removed the walls for clarity....they were made using the free hand tool, push pull and then artisan, about 5 minutes each.
                                    http://i654.photobucket.com/albums/uu269/olishea/Picture59.png
                                    just messing around:
                                    http://i654.photobucket.com/albums/uu269/olishea/Artisan-1.jpg
                                    a remake of pollen, to see if its possible in SU.
                                    http://i654.photobucket.com/albums/uu269/olishea/pollen_sds2_colour.jpg
                                    http://i654.photobucket.com/albums/uu269/olishea/pollen2.jpg
                                    oli
                                    • E Offline
                                      Ecuadorian
                                      To beta testers:
                                      Does it behave like Wings 3D, where you can toggle from proxy view/smooth view with just a key press?
                                      -Miguel Lescano
                                      • daleD Offline
                                        dale
                                        Have we mentioned we can't wait.
                                        Really cool stuff.
                                        • olisheaO Offline
                                          olishea
                                          Ecuadorian: you can subsmooth in one click yes....it previews the geometry so you don't have to execute the command unless you are sure.
                                          I used Wings3D a lot, thats why I remade some images just to see if SU can do it. Instead of using spheres I use geometric domes instead, resultant subdivision is always cleaner (for these ballsy images haha)
                                          here is an image I used to help describe a uni project....an undulating, evolving programme moving between sites of potential intervention.
                                          http://i654.photobucket.com/albums/uu269/olishea/5_final.jpg
                                          oli
                                            michaliszissiou
                                            Nice last one oli. ๐Ÿ‘
                                            A tip for box modeling:
                                            Instead of using pushpull and remove inner faces rb, I found more helpful to use [F] command and move tool.
                                            • 2 / 3
